Question about LG LDF6810 Built-in Dishwasher
I have a Frigidaire Dishwasher, model #FDB635rfs It is not that old, but appears to have quit working. It sounds like it runs the water gets pushed in by the tube on the side but goes straight to the bottom of the washer. It looks like the spray arms are not spinning. Water is not circulating. Element still heats up. Detergent just runs down the inside of the door and doesn't dissolve since water is not circulating through arms. I have just replaced the water inlet valve and it did not help. Is this a motor and pump assembly I am going to have to replace? Thanks for you help. Sincerely, Ann
  • Anonymous Feb 18, 2009
    Water line hooked up, water turned on...but no water is circulating inside of unit when you turn on any cycle and wait.
  • LG Master
  • 5,568 Answers
Don't know about yours but many of the rotating spray-heads are turned only by waterpressure, not a separate motor. The rotator is normally pretty loose and should turn willingly by hand; if it seems stiff and your water pressure is normally lower (most city lines are ~60#, rural from 30-50#) it may not have enough pressure to turn the spray head if a buildup of food has happened.
Not having a motor drive isn't a bad idea because if the washer is carelessly loaded, the worst that happens is no spin, instead of trashing dishes or the machine mechanism.
Posted on Dec 28, 2008
Frigidaire built in dishwasher model PLD2855RFC1. Have to wash dishes pretty much spotless prior to using dishwaser. Glasses come out with what appears to be soap residue regardless if powder or liquid....
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
May 31, 2010 | Frigidaire PLD2855RFC Dishwasher
Dishwasher does not drain completely
Check your main drain system where your finally connect to let off the dish washer water.
Apr 10, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Apparently no water pressure to upper washing arm.
Hi sounds like there is a blockage in the circulation pump which causes low water pressure as it cannot push the water around. You would have to remove the unit and turn on it's side and remove the circulation pump to clear the blockage.
Also check all the holes in your spray arms for any blockages. Best to remove each arm and clean in the sink. Any blockages causes the arms not to turn.
Jan 24, 2010 | Frigidaire Dishwashers
Frigidaire dishwasher model GLD2445RFCO is making noise
I have the same problem with my dishwasher. If you remove the kick plate while it is running, There is an electric motor underneath. If you push up and pull forward on the electric motor, the noise will stop. I used a block to prop it up and the noise stopped. You may want to try it.
Jan 08, 2010 | Frigidaire GLD2445RFC Stainless Steel...
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
Frigidaire Dishwasher Energy Star blinking lights.
Hmmm...don't know why this worked, but it did. When the lights were flashing when I tried to start my Frigidaire dishwasher model#FDB1500LF, nothing would happen...just blinking lights, so I went to the house electrical panel, found the switch for the dishwasher, turned off & on again, and now the dishwasher works.
Go figure.
Feb 16, 2009 | Frigidaire 24 in. PLD2560LCC Energy...
Dishwasher problem - no water in the tub
hi.
The sensore key that control the door of dish washer may be show that the door is open & it doesent let that water come to machine . you should checke the key
Nov 09, 2008 | Frigidaire 24 in. FDB1250RE Built-in...
Dishasher does not drain
If it gravity drains, but the pump does not push out the water.......replace the drain pump. I just repaired an 8-year-old  Frigidaire dishwasher with this very problem, and although it sounded like the pump was operating, it was not....it was just vibrating. I replaced the drain pump and it now works perfectly. I am a service tech with 38 years experience.
Jun 21, 2007 | Frigidaire 24 in. FDB635RF Built-in...
LG LDF6810 Built-in Dishwasher Logo
221 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
