Question about Ruud UAMB Air Conditioner
We have a Roof Mounted RUDD Unit. Yesteday when I went to check the thermostat to see why the house was so cold I heard it making a humming sound. I turned the thermostate to 60 degrees then it stopped making a noise ahen back up to 66 degrees and it started making the same noise again. The heat did not kick in at all. I have the fan set to auto also.
    Sergeant:
  • 359 Answers
Good cks skeeter advised , if these ck out possible fan motor or capacitor
Posted on Dec 29, 2008
  • 306 Answers
You need to check if you have full 220 voltage to unit sounds like one leg of your power is out. You have slow blow fuses on this so turn off the breaker that goes to unit and then pull fuses out and check each one. You can check at the place where the main power comes into unit if you don't mind checking electricity but take your volt ohm meter and check the two power leads on the contactor that is the first thing that the power is connected to. Let me know if that checks out Okay. ken
Posted on Dec 28, 2008
My carrier ac roof top ducted unit started spitting out small amounts of water now and then, I changed filter. Now with ac in off position I am hearing a humming noise coming from the unit, what can this...
Don't really understand what you mean by roof top duct unit .if it's a roof top unit and water is leaking down your vent then you have a clogged drain line .
Mar 02, 2018 | Dometic Rooftop RV Air Conditioner
Hello all My Rudd AC unit will start and run find maybe for 10 minutes and cool air then the fan outside will stop and unit hums or hisses and blows hot air inside vents. I changed out Thermostat and Run...
Welcome to the world of Ruud! Ok James heres the deal. It sounds like the condenser fan motor has failed. Its not a repairable item but the motor is not too expensive. Disconnect the main power at the fuse block on the side of your house next to your a/c. Remove the screws that hold the top fan section and carefully turn the fan/panel assembly over taking care not to stress the wires. Determine how the fan is mounted (probably 4 screws) and go find your new motor. Both Rheem and Ruud use the same motor mounting. Most a/c supply houses have a motor that will fit or go to graingers. Make sure you get a matching run capacitor for that motor. It will have separate wires and not share any wiring with the old capacitor. The old capacitor will have to stay in place since it is also connected to the compressor. The old motor will have 3 wires and the new one 4 (2 brown for the capacitor and 2 others to put on the contactor that the compressor wires go to). If its a heat pump it could be a board and youll need help. good luck
Aug 15, 2013 | Ruud UBHC Air Conditioner
Rudd model ukab-030jaz
You most likely have a small 3 or 5 amp fuse on the circuit board on the indoor unit that has blown. You should turn the power off at the main breaker panel and open the cover and very carefully look for a small blown fuse. It will look like one that you use in your car. Then if it is blown, replace it with the exact same size and rating.
Aug 17, 2017 | Heating & Cooling
When air handling unit stops it would make a shuddering sound.Now it won't run at all. Outside fan is working Tried to run just fan on the thermostat still will not run .It is a RUDD model...
hi,
The indoor blower squirrel cage or the motor went bad....
Open up the air handler and check the blower... you will find the problem right there...
heatman101
Aug 21, 2011 | Ruud Heating & Cooling
Rudd Achiever series model RQNJ-AO42JK 000 mfg
Turn the thermostat as low as it will go and have someone stand out side, they should here the condensor fan and compressor come on at the same time. They are two distinctive sounds so you should
be able to tell if the compressor is running.
If nothing happens and you are skilled with electrical
you can turn power off and remove the electrical
cover to the outside unit. Restore power and carefully
push in the contactor, if the fan and compressor
starts you have a thermostat or low voltage problem.
If just the outdoor fan runs on any attempt, more than likely you need a new capacitor.
Jun 18, 2010 | Ruud Central System Air Conditioner
I recently bought a 4 ton 14.5 SEER Rudd Spilt system using R-410 and matching Rudd furnace. This system replaced a Lennox 10 SEER 4 ton unit. Now that it has gotten hot in Baton Rouge LA 90-93 degrees....
Sounds like the Unit might be low on charge.But without correct readings not sure.
The new unit with 410 will actually cool better due to higher boiling point temp. of freon type.Poor air circulation could also cause problem.Such as dirty filter, too slow fan speed,dirty coil.Also could have obstruction in freon lines either at pump,in line set,or in coil.
Get someone u trust to check it out and ask for their Rudd Dealership Training Credentials.
Jun 15, 2009 | Heating & Cooling
I have a Carrier 38tra048340 ac 4 ton unit outside, heater in attic. Thermostat is Totaline P374-1100. Power went out than back on after a few hours due to vehicle crashing into power pole. AC was running...
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Jun 23, 2008 | Carrier Heating & Cooling
Thermostat for EQK 1350f
CALL THE MANUFACTOR OF THE EQUIPMENT AND THEY CAN SHIP IT TO YOUR HOUSE.
Dec 05, 2007 | Emerson Quiet Kool 10GV13 Air Conditioner
Ruud UAMB Air Conditioner Logo
46 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Dennis Boxerman
Paul
Paul
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
