Question about GE Spectra JGBP30 Gas Kitchen Range
My oven soots alot:
There is an adjustable screw for the needle nose on the temperature control. i adjusted it clockwise while the oven was burning and i observed no change in the yellow flames
  • Andy Notch Dec 31, 2008
    I believed you have hit the nail on the head, i have ajusted the air but no change, i guess the range has had it. Thank you
  • Steven Carter May 11, 2010
    how old and was it converted
  • GE Master
  • 5,568 Answers
The adjustment you attempted was to make the regulator track the temperature setting on the knob.
The yellow flame is caused by poor combustion and could be producing carbon monoxide, an odorless, tasteless and very deadly gas.
It sounds like the path for air is blocked and causing the problem.
For anyone, I recommend a carbon monoxide detector in the home if you have any gas appliances or even unused gas connections. They cost $30-$35 US but flowers for your funeral could run more.   A family near our town lost the father and the wife and 3 kids ended up in the hospital due to this only a few days ago. They had only moved into the house a week ago.
Posted on Dec 28, 2008
What do i set the l & h caburator screws on a homelite sxl
They are always preset at the factory so whwn an owner has to adjust them again, it will never be the same as what they originally set them as.
Here's what to do.
Clockwise, turn both needles until snug, NOT super tight.
Now back both out 1 complete rotation, here is your starting point
Now the L, you adjust this needle while the unit is idling, If the chain is moving alot , you went too far, rotate counter clockwise in quarter turn increments.
The H needle you adjust while pressing the throttle trigger and holding it in. Same as the low you adjust in quarter turn increments.
Oct 14, 2015 | Homelite Garden
Ge oven will not preheat but broiler and stove top still works
Hello.
When an oven won't bake, it's because the bakeelement is burned out. The bake element is the black, pencil- thick tube at thebottom of the oven. When the oven heats, the element glows red. This elementhas an expected life-span of several years. It may last for only one; it maylast for many more. When the element burns out, you need to replace it.
If the bake element is burned out, replacing it should solve the problem.Otherwise, you need to further troubleshoot the oven's electrical system tolocate the defective wire or component. When the temperature is consistent buttoo high or too low, it could be one of several different things.
First checkto see if the thermostat sensing bulb has come loose from its holder. It couldbe lying on the floor of the oven or resting on the heating element. This wouldcause the oven to not heat correctly. If the thermostat bulb is notdislodged, it's likely that the thermostat or sensor is either mis-calibratedor defective. Electronic ovens with a digitaldisplay use a sensor to monitor oven temperature.
To solve temperature problemsfor these models, you may need to replace the sensor. On some digital-displaymodels, you can calibrate the temperature using the key pad. See youroperator's manual for details. Ovens without a digital displayoften use a mechanical system for controlling temperature. On many of theseunits, you can remove the thermostat knob and adjust the knob itself to moreaccurately represent the actual setting of the thermostat.
If, when you remove the knob,there's a screw on the back of it with a small calibration plate, you canloosen the screw, adjust the plate, then tighten the screw again. If the knobisn't adjustable, and the oven temperature is off by more than 35 to 45degrees, you need to replace the thermostat to solve the problem.
Thanks.
Jul 31, 2011 | Ovens
Fridgatare modle #FGG3054KFB I have a frigidaire range that has been converted to propane. When the oven is turned of it has a strong propane smell and there is alot of moistier inside. The flame is about...
It shouldn't be burning yellow and emitting soot at all;sounds like on of these possible causes-
(a)blocked burner airways(this can lead to yellow tipping and sooting on LPG powered appliances because insufficient air is getting through to the burner causing it;you can also get this effect on LPG barbecues say if dead insects or spiderwebs are in the burner pipes and airways after a period of storage),
(b)incorrect aeration being set when the burner was converted using LPG jets(too much gas and not enough air causing yellow flames/smells and sooting),
or (c) if you use propane cylinder gas a dicky or faulty regulator. I would get it looked at investigating all the possibilities I mention and taking action to correct this where necessary ie clearing the burner airways(if this is causing your problem), adjusting the aeration in the burners until you get a clear noiseless blue flame without any excessive yellow and sooting(but even after good adjustment you may find still get a very slight yellow tip without sooting at the top of the flame;this does happen with propane gas and there is a slight tendancy for this to happen more often with butane-butane tends to display very slight yellow tips on ignition increasing slightly as the burner warms up to full temperature) or if you use propane cylinder gas replacing the regulator if that is necessary.
Nov 22, 2010 | Frigidaire FGB24S5A Gas Single Oven
Nose not getting red just a little
You need to adjust air/fuel mixture. At the back of the heater there is a plastic slotted set screw. That is the air mixture adjustment screw. Turn it in clockwise a 1/4 turn at a time until the nose cone gets to be about 90% reddish orange. The heater should also burn cleaner. Hope this helps.
Jan 11, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Kenmore gas stove. Oven burns big flame which soots
The manifold needs to be cleaned and adjusted could have rust etc in it Not a good thing to do yourself unless you know what you are doing
Jan 24, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Dec 20, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Stove to hot burns everything
This is a simple fix as long as the oven is heating properly and the only problem is that the temp seems higher than what the temperature control knob indicates...
Purchase an inexpensive oven thermometer from the hardware store and place it in the center of the oven. Set the temperature control knob to 350 degrees F.
Check the temperature indicated on the thermometer in the oven after 20 minutes. If it's not within 5 degrees of 350, you'll need to adjust the oven's temperature control.
Turn the oven off.
Pull off the temperature control knob. You can usually pull it off by hand, pry it off with a thin screwdriver, or slide a piece of cord up behind it and pull.
Note which kind of temperature control knob you have. There are two types: The first has a screw in the shaft of the knob; the second has an adjustment dial on the back of the knob.
Adjust the temperature with the first type by turning the screw in the shaft with a screwdriver. Turn it clockwise to lower the temperature; turn it counterclockwise to raise the temperature. Turn the screw just a little bit in the appropriate direction.
Adjust the temperature with the second type of knob by turning the dial on the back of the knob. (This dial is held in place with a screw or a clip that will need to be removed.) Raise the temperature setting by turning the dial counterclockwise; lower it by turning the dial clockwise. The notches are typically in 5 or 10-degree increments.
Test the oven temperature again.
Repeat until you're in the right temperature range.
Good Luck!
Mar 20, 2008 | Kitchen Ranges
Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Oven bakes unevenly and burns food
When foods are burned, soggy, or baked unevenly, it generally means heat isn't being distributed evenly throughout the oven, its escaping out the door or the controls are out of adjustment. 1) Remove any aluminum foil from racks or the bottom of the oven. 2) Check the door gasket and, if necessary, have it replaced. 3) Be sure nothing is obstructing the vent. 4) Reposition the oven racks so baking pans aren't too close to the heat sources. 5) Check your baking pans. If they're dark, they may be burning your food. Reduce temperature by 25 degrees F when baking in dark metal or glass pans. 6) Recalibrate the controls.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Open Questions:
See all GE Spectra JGBP30 Gas Kitchen Range Questions
GE Spectra JGBP30 Gas Kitchen Range Logo
131 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
