Question about Microsoft Windows XP Professional
My computer can't read external hard disk
I have a laptop and a computer..the problem is when i plug in an external hard disk...only my laptop can read that hard disk..my computer can't read it..can u help me to solve the problem??
  • tctwood Jan 13, 2009
    I can read an external drive on one old notebook running Windows 2000 Pro but not on a newer one running Windows XP Pro. The latter can 'see' the drive in Device Manager but it does not appear in 'My Computer' or in 'Windows Explorer'.
    I use a USB mouse on the XP machine and I can read flashdisks on it.
    Any suggestions?
  • Anonymous Jan 19, 2009
    can't read my external hard disk
    Scholar:
  • 53 Answers
I am assuming that you are using Windows XP and USB PORTS on both computers.
First, try to use a different USB PORT on the pc, just to rule out a bad one.
Another thing is that the external HDD may not connect to USB 1.1, only to 2.0 for the speed it needs. Check to see if the pc has USB ports on back of case, those are usually 2.0.
Third thing is to see if any other devices that are USB can connect to your pc. If not, you may want to load the USB DRIVERS back on the pc, as they may be corrupted.
Hope that helps.
Posted on Dec 30, 2008
Backup Plus Potable 500 GB Light Blinking and disk not being read I've got a Seagate 500 GB backup plus external hard disk which is about 2 months old. The hard disk has started to make a slight clicking...
The clicking could be a symptom of imminent failure of the hard drive . Back up all information from this drive as soon as possible. It may be something that a program such as checkdisk can fix but be sure to backup drive before attempting any fixes just to be safe. Hope this helps.
Dec 31, 2013 | Seagate FreeAgent® GoFlex? Black 1TB...
When i turn it on it has a disk read error occurred message
The Toshiba cannot find a boot disk, this problem could be caused by the BIOS could not detect the hard drive because has lost the configuration or the hard drive is faulty or the disk controller is faulty.
Check the BIOS configuration to see if it has detected the hard disk and some BIOS have a utility to test the hard disk, if this is available then run the hard disk test.
Another way to test the hard disk, remove the hard disk from the laptop and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer see it as and external hard drive and you can open the folders and files the the hard drive is OK and the fault is most likely the laptop's motherboard.
If the computer cannot detect or open the files on the external USB adapter then the hard drive is faulty. The hard drive needs to be replaced in the Toshiba and Windows installed to get the laptop working again.
Aug 02, 2009 | Toshiba Computers & Internet
I have a WD external hard drive USB 2.0 750 GB. It was working just fine for many months, and suddenly, my laptop won't "read" it -- it's not listed/detected in "my computer." I thought there was something...
If the device is recognized and not listed as a driver in the Explorer, then the disk is not recognized as having been partitioned and formatted. You can use the Disk Manager to see if there is anything listed on the disk.
Start - > right-click My Computer -> Properties
In the management console, go to disk management and check your disks. The external disk should be there and then you can see the partitions and drives assigned to it.
If there is nothing on it, your MBR could be damaged, which needs to be restored.
Alternatively you could partition and format it, but then you'd loose the data on it, so that is a last resort.
I think a program called Acronis Disk Director Suite can restore MBR's. Have a look at this external hard disk troubleshooting article.
Jun 13, 2009 | Western Digital Elements powered by WD 320...
"Error loading operating system" message
This error means the operating system on the hard disk couldn't load due to possible faulty hard drive or disk controller. The fault could also mean the hard drive needs reseating to make proper connection. Reseat the hard drive and if you still get this error, then you need to determine if the disk controller is faulty.
To do this, remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer see this hard drive as an external drive and you can also see the contents of the drive, then the hard drive is OK and the fault is a faulty disk controller. If the computer cannot detect the hard drive then the hard drive is faulty.
Then get a new hard drive insert it into youe laptop and install Windows to get your laptop operatioal.
Apr 09, 2009 | Sony VAIO VGN-FE660G Notebook
A disk read error occurred. the comp. said press ctrl+alt+del
The computer cannot find the operating system, the disk error message means it cannot find the hard disk, you most likely have a faulty hard disk or less likely a faulty disk controller.
You can test the hard disk by removing it and connecting it to a USB hard drive adapter and plug it into a working computer's USB port. If this computer cannot detect this drive as an external drive then you will know your hard drive is faulty ad you need to buy a new one and install Windows and programs etc..
Jan 25, 2009 | Dell Latitude C400 Notebook
External hard drive can not be read by the computer
The hard drive was originally formatted for a PC and I was using it with Mac products. I had to delete all the information on the hard drive so that I could reformat the external hard drive to work with my Macbook Pro.
Dec 08, 2008 | Seagate (9W2041-337) 40 GB Hard Drive
External hard disk problem
control panel, computer management, storage section, disk management. you may have to download the administrative tools for windows xp/2000/vista to find this. if you have multiple memory card readers, the drive letter assignments to these drives are conflicting with the drive letter that is being assigned to your external hard drive. assign the partition of your hard drive a letter not used down in the alphabet (such as x:) for e*X*ternal.
Sep 25, 2008 | Sony VAIO GRV680 Notebook
Microsoft Windows XP Professional Logo
2,500 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
