Question about Zebra Eltron LP 2824 Thermal Printer
LP2824 feeds a label but wont print on it?
My Zebra LP2824, has the original Zebra drivers installed and feed a label of the correct size but doesnt print anything on it when printing from a windows based application. The thermal labels are correct as it prints on them if I hold down the feed key and turn the machine off and on. Any Ideas would be appreciated. Thanks
  • 2 more comments
  • Anonymous Apr 07, 2009
    same
  • Anonymous Mar 12, 2014
    we are using Zebra Eltron LP2824 with EPL code
    I would like to word wrapp split the Word into two rows.
    Is there any command doing that in EPL code?
  • Anonymous Mar 20, 2014
    Wont print when blue tooth connected to the seaward tester
  • Anonymous Mar 23, 2014
    when i put a card through the printer it will take the card but wont run it all the way through or print on it. I opened it while feeding a card through and the card will just go back and forth on the rollers then the ribbon gets jammed so i have to turn it off just to get the card out.
  • 53 Answers
Can you give more info? it sounds like you driver is set to thermal transfer mode but you have a direct thermal printer (LP not TLP)
Posted on Nov 09, 2007
My Zebra ZDesigner LP2844 feeds a blank label after printing a label. How do I make it stop doing that?
Define your label size correctly. Measure your LABEL exactly, do not include the backing paper or the gap. Calibrate the printer. HOW?
Power off printer. Press and hold the green feed button down and power printer on. Count one, two and release green button. The printer will calibrate and move labels and then print some stuff on the label. Wait until it has comletely stopped. wait another few seconds and the press the feed key once. The printer will print "out of dump". You should now be ready to print again.
Aug 31, 2013 | Zebra LP 2844 Thermal Printer
I have Zebra LP 2844-Z printer and the barcodes
Here are 3 suggestions.
Check that your label size definition is correct, measure your label height in mm and check that your printer driver settings match.
Perform a calibration. How?? when printer is on labels loaded and green light, hold feed key and wait for 2 blinks then release feed key. (If you release it after 1 flash you will print a configuration label)
If you are using Zebra Designer, download latest version of Zdesigner V2. Install latest printer driver V2.63. This driver & Zdesigner allows you to calibrate the printer directly from within Zdesigner. Go to File/Printer settings/ advanced options and click calibrate at bottom of page. when printer calibrates then tick the box USE PRINTER SETTINGS and printer will now work properly.
Jul 01, 2010 | Zebra LP 2844-Z Thermal Label Printer
HELLO: PRINTS ONE LABEL
This could have a couple of different causes. Best thing to do is determine if the problem is with the printer or the software. Turn the printer off and back on again. After the power-on self test is done, just press the feed key. Does the printer feed just one label ? If so, then you know the printer has a good calibration on the size of the label. Now print a label. Does it skip one after printing ? If it does, now you know the problem is in the software because the printer is only going to do what it’s told to do. Check all settings in the label software / printer driver to make sure label size is accurate, correct printer driver is being used, etc.
So first check to see if the printer is ok by itself. If it feeds two labels after powering up, then the calibration is needs to be redone. Also make sure the media sensor is positioned over the label. This can cause skipping as well if out of position.
Hope that helps !
Apr 28, 2010 | Zebra S4M Thermal Label Printer
Keeps on skipping labels, already tried the off button the restart printer while holding feed button. any ideas?
Check the label size is correct in the application and driver etc, check the minimum label size is withing spec. Download drivers from Nice Label website, install and setup correctly
Oct 12, 2009 | Zebra LP 2844 Thermal Printer
Why is my Zebra printer printing every other label?
The labels you are printing have an extra line feed (a blank line) after the last printed line. Remove them.
Remove any "FormFeed" from the label run, if you are doing a "merge".
Line 1 Name
Line 2 Address
Line 3 Address2
Line 4 City St Zip
Line 5 <Blank>
Line 6 <Blank>
Sep 21, 2009 | Zebra LP 2844 Thermal Printer
IT PRINT A LABEL THEN SKIPS A LABEL THEN PRINTS A LABEL
You need to make sure the media and ribbon are installed correctly, and then make sure the printer is calibrated. Once you verify the media is correct, power off the printer and then back on. It should feed a few labels. Then press the button to feed again to make sure it feeds only one. If it does, then the printer is set. Now, when you go to print, if it still acts up, you need to check either the driver settings or the software settings. Label size could be set incorrectly.
Aug 30, 2009 | Zebra Eltron TLP 2742 Thermal Label...
Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
Aug 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
Only printing 1/2 a label
recalibrate the printer in the set up.
Don't just do a quick cal from the front panel.
Make sure your driver is the correct dpi zebra driver, either zebra or my preferred seagull scientific.
by .5 of the label, do you mean width or heigth.
If it is heigth, check to make sure you are set for top of print correctly. Also you will have to back feed for a label that short.
Feb 24, 2009 | Zebra 110Xi III Plus Thermal Printer
Zebra LP2824 not printing
Sounds like you put your printer into line mode. Line mode prints code so you can see what is sent to the printer to look for possible mistakes in the code.
To switch from line mode back to page mode.
  1. Turn printer off.
  2. Press and hold the feed button down. And switch printer on.
  3. Release the feed button when the LED flashes red.
  4. When the LED flashes green, press down the feed button.
  5. When the LED flashes amber release the feed button.
  6. Try printing now that the printer is back in page mode which is used for print your labels; line mode prints the labels code.
  7. Do this fast or else it wont work if you are slow.
Jan 13, 2009 | Zebra LP 2824 Printer
Zebra Eltron LP 2824 Thermal Printer Logo
1,101 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
Joaquim Martins
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
