Question about Sony PlayStation 2 Slimline Console
I need to make my ps2 ntsc u/c so I can play rockband
I am not sure what this means or how to activate this feature??
any help much appreciated
No audio and video output
Posted on Dec 30, 2008
After much research there seems to be a compatiility problem with any ps2 that is not a 9000 series(the silver one), a couple of people had said that they cleaned the laser optic with alcohol and a qtip but in most cases if that works the drums still wont work for some reason. I will have to return the game back to best buy because I am not going to buy another ps2 with ntsc compatibility. Activision apparently knew of this problem that most ps2 owners would face and chose to release the game with out any warning etc.... I suggest taking in back to the retailer as many other are doing and maybe Activision will get the message.
Posted on Dec 28, 2008
I live in South Africa and bought a PS3 Baseball game. It works in my PS2 but not in the PS3, because of the zone code. What is the correct zone code
I assume you bought a PS2 game that works on your PS2 system but not on your PS3 system since a PS3 game will never work on a PS2.
Since not all PS3 systems can play PS2 games, you need to first check the model number of your PS3 system. If you look at the back of your PS3, there should be a serial number somewhere that starts with "CECH", followed by one more letter and a couple numbers (e.g. "CECHC02"). Unless the model number starts with "CECHA", "CECHB", "CECHC", or "CECHE", you won't be able to play PS2 games on your PS3.
If your PS3 can play PS2 games, then you need to make sure that the region of the PS2 game matches the region of your PS3. The region of the PS2 game can be found in the upper-right corner of the front of the box the game came in. The four regions are: "NTSC U/C", "NTSC J", "NTSC C", and "PAL".
Once you know the model number of the PS3 and the region of the PS2 game, you can tell if the PS2 game should work on the PS3. Use the following chart to determine if your game and system are compatible:
Last two digits of your PS3 model number: Playable PS2 game region
00: NTSC J
01: NTSC U/C
02: PAL
03: PAL
04: PAL
05: NTSC J
06: NTSC J
07: NTSC J
08: PAL
09: NTSC C
11: NTSC U/C
12: NTSC J
Apr 29, 2012 | Sony Playstation 3 (PS3) Console
Format disc for playstation 2 I bought some UK playstation disc and I get that message what do I do
It means that the PS2 can't read the disc. Playstation 2s in the US are NTSC, while those in the UK are PAL. PAL discs can not be played on an NTSC PS2, and NTSC discs can not be played on a PAL console. This is because the consoles are region-locked and you can only play games from the region the PS2 itself was sold in.
Jan 14, 2011 | Sony PlayStation 2 (PS2) Console
American disc won`t play on my ps2 console in the uk all i get is please insert disc
if your ps2 is not a modded one sorry to tell you but yours is a pal ps2 (means you live somewhere in asia europe)so there is some difference i the american ps2 disc(ntsc) and pal ps2 disc both are designed to play in specific consoles so if you bought they console from ntsc territory(japan ,north america) it should work for sure but sometimes in japan and all they sell pals also but there is still chance try returning the cd to the shop and buy a pal disc or you can mod your ps2 from ps2 technicians (they are all around the world,every console shop has one) and then you can play american disc this is the only chance it will only take a small 25 bucks from you just mod it and u can play games u burned from your computer and also any pal ,ntsc territory original discs also
Dec 25, 2009 | Sony PlayStation 2 Slimline Console
Ps2 will play every game but rockband and rockband 2. i have cleaned with alcohol. vacuum and nothing but frustration!!!!!!!!!!
try this.
worked for some people.
stand the PS2 on it's side before inserting disc.
never move the console with the disc playing, doing so may ruin the disc and laser lens.
hope this helps :D
Aug 03, 2009 | Sony PlayStation 2 (PS2) Console
Rockband freezing ps2
the disk may be damaged , If it has the smallest scratch or smudge on the disk the ps2 will not play it. is it the slim or older ps2 ? if it continues to freeze I would return it as damaged. There should really no reason for it freezing unless it has a damaged disk or your PS2 needs cleaned or repaired. Hope this helps and I hope you get it up and going.
Dec 25, 2008 | MTV Games Rock Band for PlayStation 2
Rock Band for ps2 disc will not load in our ps2
Take it to Gamestop or somewhere they repaired disc i know it maynot be sratch but i read online and goggle i found somewhere they took it there and they try to play it it works but here is my pre. solution i'll be doing more research k
Mar 15, 2008 | Sony PlayStation 2 (PS2) Console
Ps2
Hey buddy FORMAT DISC means PAL games or NTSC games format.
There are 2 formats dics in this world for the PS1,PS2,PSP,Wii,Gamecube.etc
They are [NTSC] and [PAL]
[NTSC] is for North America and Japan ONLY. [NTSC] is Original games.
[PAL] is for Asia Only. Which is copied games form the Originals.
I need to know were did you bought PS2 Console from ?
If you bought it in North America or Japan then you have to buy and play Original games from North America Only.
If you bought your PS2 in Asia then you can play copied games.
It is most likely your PS2 is a NTSC, your PS2 cant read any PAL games so it will say format dics.
Mar 07, 2008 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slimline Console Logo
59 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
