Question about Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Watt
My echo wont turn off when im on my clean setting
  • Dellamorte Dec 28, 2008
    i just recieved my line 6 spider 3 15 for christmas...all the reviews i've read about it are all good. but.....when i turn it on the delay/echo function is on automatically when in "clean" channel and on that channel only. I read the manual and saw that you can hold certian buttons before turning on the amp and it will do doifferent things. so when i tried holind down the delay button and turned it on the clean channnel had no delay effect but then won't switch to any other channels, just remains on clean. the line 6 website is down for an answer, someone please help. i have the warrenty and all so i need to know if i need to take it back or if i can fix it on my own.
    Problem Solver:
  • 9 Answers
Hi, try holding down the clean channel button when you start up the amp. If that doesn't work, try turning up the delay, then turning it all the way down.
I have the exact same amp and this always works. If this doesn't work for your amp, you may need to take it in.
Posted on Jan 03, 2009
How to reset korge x5d to factory setting?
Hold PROG and +10 while turning it on.
That should initialize the unit to factory fresh.
Aug 07, 2014 | Korg X5d
Pioneer DJM-800 beat effects fault
do you have the manual.
please check out the settings on turning it on echo mode.
Oct 28, 2008 | Korg Mini Kp Kaoss Pad
What preset effect number is best for karaoke?
Always use echo and reverb, or just reverb for inexperienced singers. If I remember right this is from effect 19 but this is a very inflexible set-up with no control over the effects, just presets. You'll need to listen and decide what is best. You may also try chorus as with a decent effects unit this can be very effective plus a bit of reverb and echo.
Different songs like different effects and we will chop and change even in a single track when live mixing professional acts.
Dec 26, 2013 | Behringer Xenyx 1002fx Mixer 10 Input 2...
User manual for DOD DFX9 DIGITAL DELAY GUITAR PEDAL
Can't find a manual but can still explain. Delays, chorus, flangers, and reverbs are all the same effect except the different names of them will allow you different adjustments. Chorus usually has a width control which controls pitch shifting. Flangers and delays will have a feedback control which simply means, how many times you hear the echo. On reverb units, room size means how long of echo(even though it;s short) you want. Delay is the same with much longer echo, feedback is the same as on flangers except the flangers time is very short meaning the effect is at almost the exact time resulting in feedback causing a metalic sound. I probaly just confused you but good digital delays usually have all the features and will usually do all 4 effects depending on how you set them. If you want delay, set width on 0 and adjust time and feedback. For flanging, adjust width and speed and feedback. Chorusing, adjust time, width, and speed. Reverb, adjust time, set width on 0, and feedback. I see it has a level(mixture, how much effect you hear), and a replay(feedback, how many times you hear it), and a delay knob,(how long the echo will be) The range/mode switch allows for settings of diferent time lengths and INF setting allows for infinite repeat. Hope this helps.
Mar 09, 2013 | Applause MAE148 AcoEle Mandolin Natural...
I just received my RSQ-echo 2000 karaoke machine. When I plug a mic into the front 2 mic inputs, they both have echo, even tho I turned off the echo volume in the back. I assumed that by turning it all...
The control supposedly controls the mix of the echo... this is a reverb type sound. Please note that room acoustics AND if the mic's "hear" the speaker in this, it may create an echo that is NOT under control of the adjustment. Make sure the mic's cannot "hear" the speaker or a reflection off a wall.
Aug 17, 2011 | RSQ NK 2000U
Im trying to connect my mpc 2500 with pro tools 8. im using an mbox 2 pro as my interface. I can get pro tools and the mpc to sync...but i cant seem to understand why i cant hear any of my samples from the...
Check if the Mbox2 has an echo setting that echos the audio from its input. If you want the audio to loop through the PC then it will have to echo there instead. Check that in "Sound and devices" of the PC are all set to transfer via the MBox for voice and playback instead of the internal PC audio system.
Apr 12, 2011 | Akai Mpc2500 Music Production Center
When I connect my Privia PX-130 to my computer (and Logic) it works perfectly but if I connect the audio out (via line out) at the same time, the audio sounds dreadful, even if I'm not going through the...
I SUSPECT that the USB connection is ECHOING the data, causing multiple generators to be active. Those extra ones then are mixed into the line out of the keyboard. In your PC, make sure the echo setting is turned off, OR disable the sending out of audio via the USB. Alternatively, DISABLE MIDI/USB incoming to the keyboard.
Jan 21, 2011 | Casio Privia Px-130 Px130 88 Key Digital...
My Line 6 spider II amplifier sounds crappy. I need a quick fix.
If you are using the factory settings, and you have accidently changed the settings. Look at your manual and it tells you how to get it back to factory settings. If you tweaked the clean channel when you got it, you will have to play around with the settings to get what you want. Hope this is helpful.
Mar 21, 2009 | Music
Electric Guitar wont play through Amp
the buzzing is indicative of an open ground connection, check the cord by substitution or with an ohm meter, if the cord is good look at the connections to the jack inside the amp ( im guessing you built the amp from a kit). Is this a solid state amplifier? Tube amps have lethal votages and should not be experimented on without knowledge of electronic safety. Also if there is more than one input to the amp try plugging the guitar into another one and see if its still the same.
Dec 30, 2008 | Yamaha Electric Guitar
Open Questions:
See all Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Questions
Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Watt Logo
422 people viewed this question
Top Line 6 Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Line 6 Music Expert? Answer questions, earn points and help others
