Question about JVC KD-AV7010 DVD Multimedia Center Car Video Player
Sound cuts out for bass notes in songs..
I have a 93 civic that im almost positive i have all wires ran correctly..according to wiring diagram... everytime i rewire stereo it works great until i play it turned up for awhile them is turns all sonds off completely.. then when i turn it back on you get sound but only when the volume is low or there is no bass in the song ... when i hit my brakes my headunit glitches on and off .. SOUNDS electirical but ive tried everything .. ANYONE HAVE A SOLUTION.. if so please email me.. tjslasher@hotmail.com
  • 132 Answers
SOURCE: wire harness diagram
www.scosche.com will give you the cars wires, u may want to just by a harness adapter, cutting wires=bad
Don
Posted on Jan 02, 2008
SOURCE: JVC KD-AVX33 stopped transmintting sound to speakers.....
it could be the unit getting hot? i found this was happening on mine? leave vents on cold or open them up when on hot to cirrculate air as best you can... hoped this helped!!!
Posted on Jan 17, 2008
tripletauto
  • 1450 Answers
SOURCE: HEEEEEELP!!
this wire is designed to be grounded when oparking brake is on this is so you cannot watch dvd while driving as that is illegal. Some people wire this up on a toggle switch to a ground so they can flip the switch and make it work whenever they want. I cannot tell you to just wire this to a ground as that would be illegal!!!!!! ;) supposed to wire it to the switch on park brake this wire grounds when brake is on
Posted on Sep 11, 2008
SOURCE: JVC KD-NX5000 NOT WORKING PROPERLY
I had the same problem, where the Sat radio, the bluetooth and the ipod were all non-functional. Turns out, they all go through one central hook-up, so you have to make sure that connection is good.
When mine did not show up or function, I looked at the install under the foot board of the front passenger seat that the installer did, and nothing looked out of whack. Upon closer inspection, one of the cables was had been pressed out of it's proper place and loosened enough to cause a bad connection.
I don't care for the install, but there was no problem with the equipment, so check all of your connections. Even to the point of pulling them out and reconnecting them to see if that fixes the problem.
Robert
Posted on Oct 06, 2008
  • 3 Answers
SOURCE: How can I get DVD's to play
just hook it up the same ground as the cd player
Posted on Dec 02, 2008
I have a 2000 oldsmobile alero and I can't get sound out of my rear speakers good speakers and connection just no sound
OLDSMOBILE ALERO 2000 speakers - Sonic Electronix
www.sonicelectronix.com/oldsmobile-alero-2000-car-speakers.html
OLDSMOBILE ALERO 2000 speakers - find speakers that fit your ... sound. This size is capable of delivering exceptional mid-bass that can't be found in smaller ...
2001 Oldsmobile Alero Car Radio Stereo Audio Wiring ...
www.modifiedlife.com/2001-oldsmobile-alero-car-radio-stereo-audio-wi...
Easy Plug and Play Wiring Adapter. ... 2001 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram ... If you can't find your car audio wire diagram, car stereo wire diagram or car radio ... Right Rear Speaker Positive Wire (+): Dark Blue ... olds alero and I have replace the stock stereo and have found that the sound out put ...
Request a Oldsmobile Car Radio Stereo Wiring Diagram
Jan 21, 2016 | Oldsmobile Cars & Trucks
I need awireing diagram for a premiun sound (jbl) stereo with cd player for a 93 thunderbird
you should get a wiring harness to save you the trouble, however i just put in a kenwood in a 1997 thunderbird, if you cut the black wiring cover all the speaker wires are wrapped together and the other wires will be 12v constant acc, ground, etc. here is a diagram Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Orange/Blue
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire : Orange/Green
Left Front Speaker Negative Wire : Black/White
Right Front Speaker Positive Wire : White/Green
Right Front Speaker Negative Wire : Black/White
Car Audio Rear Speakers Size: 5x 7 speakers
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire : Pink/Green
Left Rear Speaker Negative Wire : Pink/Blue
Right Rear Speaker Positive Wire : Pink/Blue
Right Rear Speaker Negative Wire : Green/Orange
Feb 03, 2013 | 1993 Ford Thunderbird
My amp won't play bass everything is hooked up
I have a similar problem with my 2012 civic, I hooked up my 1800w kenwood mp to my 2 12" w6s and 1 song plays and sounds great, the rest of my songs have no bass from the subs, just the car speakers sound normal so I dont know what the hell thats all about. I thought it was a wiring issue but I can play the one song all day and it sounds perfect so any suggestions? thanks in advance
Jan 29, 2012 | Sony Car Audio & Video
I have 1993 honda accord im try to swap a 2000 honda civic radio but my honda accord all we have for speakers cables are red blue green yellow and white,i can't figure it out wich one goes were the 2000...
All cars with 4 speakers have 8 speaker wires (4 positive and 4 negative). The colors of the wires for these two cars are not the same. The only way to know which wire goes where is to get wire diagrams for both cars. Before cutting up your wire harness, check that the radio you're installing will bolt into your car and fit. Just swapping the mounting bracket may not work.
Mar 12, 2011 | 1991 Honda Accord
It comes on but no base sound and wont turn up
You have to fill in the details about what you're feeding it (the source and how IT's set up). It won't just >>create<< bass.
From the manual:
If you used the high-level (speaker) inputs and there
is no sound from any of the speakers:
• Check that receiver/amplifier is on and a source is playing.
• Check that powered subwoofer is plugged into an active electrical outlet and is switched on.
• Check all wires and connections between
receiver/amplifier and speakers. Make sure all wires
are connected. Make sure none of the speaker wires are
frayed, cut or punctured.
• Review proper operation of your receiver/amplifier.
If there is low (or no) bass output:
• Make sure the connections to the left and right “Speaker
Inputs” have the correct polarity (+ and –).
• Make sure that the subwoofer is plugged into an active electrical outlet and switched on.
• Adjust the crossover point.
• Flip the Phase Control switch to the opposite position.
• If you are using a Dolby Digital/DTS receiver or processor, make sure that the subwoofer adjustments on the receiver/processor are set up correctly.
• Slowly turn the Level Control clockwise until you begin to hear the desired amount of bass.
If you used the line-level inputs and there is no sound
from the subwoofer:
• Check all wires and connections between receiver/amplifier and subwoofer. Make sure all wires are connected. Make sure none
of the wires are frayed, cut or punctured.
• Make sure that you have configured your receiver/processor so that the subwoofer/LFE output is on.
Apr 07, 2010 | JBL PB12 Subwoofer
They also try to play the bass
a crossover cuts the certain tones out of the sound.example: the high side cuts out low and mid tones,or the mid side cuts out high and low. The only problems this could be is that the crossover is not set right or not wired right. These speakers should be plugged into the high side of the crossover. If wired right and set right then your crossover is no good.
Mar 23, 2010 | Kicker KS13 Car Tweeter
1989 Honda Civic hard starting and dies for no reason. Cooling fans not working. Trouble codes are #6 coolant, #10 air intake temp, #16 fuel injector. Can anyone lead me to a solution for these problems?
6
Accord Civic CRV CRX Del Sol Odyssey Prelude
85-98 86-98 97-98 85-91 93-97 95-98 85-98 ECT Sensor (Engine Coolant Temperature)
defective circuit or unplugged / defective sensor
10
85-98 86-98 97-98 85-91 93-97 95-98 85-98 IAT Sensor (Intake Air Temperature)
16
90-95 88-95 n/a 88-91 93-95 95 88-95 Fuel Injector System
defective circuit or unplugged / defective fuel injector
check your wiring for dirty connections or broken wires, you may have wires that are rubbed through or connectors that are not making full contact. you will need an ohm meter and check wires for continuity. a wiring diagram will be needed.
May 15, 2009 | 1989 Honda Civic
Phntom bass sounds
uhhh....try you change your wire setup
Sep 17, 2008 | Infinity BASSLINK Car Subwoofer
Wiring harness
you should never cut the wires on your factory harness... metra and other companys have harnesses that fit your car and would provide you with a correct wire color code you need to hook up a aftermarket stereo keep that in mind but i will post the wire diagram u are looking for
Aug 08, 2008 | 2002 Honda Civic
JVC KD-AV7010 DVD Multimedia Center Car Video Player Logo
151 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
