Question about Koss KS3102 System
Koss ks3102 hts turns on but no sound
Hi, I've had a KS3102 home theater system for about a year now. All of a sudden, the thing stopped making any noise. It turns on, reads cds/dvds, and can switch btw tuner stations, but the no sound is made at all. I tried plugging speakers I knew worked into the receiver, and it still made no noise. I've also tried to reset the AV inputs as sugg. by another q earlier, but I do not have a digital option, only analog, coax, and optical. Can anyone please help!?!?
    Problem Solver:
  • 13 Answers
I had the same problem. For about 4 months I could hear it going bad...it would take more and more time to "warm up" and eventually no matter what sequence of switch clicks I made it would no longer have audio. I lucked out and bought two of these when they were on sale so I had a good way to swap around parts. I switched power boards and found that to be the problem. I found that the 5Volt pin did not have a good 5volts, but instead had about 3 or so volts. the first thing behid the +5V pin is a diode, I noticed that I had 5V on the other side of the diode, so I bypassed it (shorted it) and now the system works fine. Although eventually i will determine what value that diode was and replace it properly. If anyone knows the value of that diode let me know..thx
Posted on Jul 02, 2007
    Genius:
  • 1,074 Answers
The system audio output is faulty call a tech and let them look at your set for repair.good luck
Posted on Apr 24, 2007
SOURCE:
Sharp DVD 'cannot read disc'
Sounds like the laser is bad.
May 29, 2013 | Onkyo HT-SR800 System
Davaz900kw sony
cd's use a different laser than dvd's when playing. You would need to have the optical pickup replaced.
Jan 10, 2013 | Sony DAV-DZ100 System
My bose lifestyle 48 system suddenly stopped playing new DVDs...is there a problem with the head..I bought it only in 2008
is the discs just spinning and then stopping when you put them in the drive?
there may be a chance that the lens might just needs cleaned. suggest a dvd lens cleaner but on the down side there is a strong possibility it may be a faulty lens. dvd players aren't built to last.
always clean the dvd player from dust and keep in an open space.
Jun 11, 2011 | Bose Lifestyle 48 System
HTS6500/37 will not read DVD' s led screen reads no disc, however system will play CD's
If it plays CDs but not DVDs then the Laser is failing and just a matter of time before it stops playing CDs also.
Apr 27, 2011 | Philips Audio Players & Recorders
Philips lx9000r 25S ome theater system Has suddenly stopped playing DVDs from Region 2 (no disc error) It will play DVDs from region 0 and CDs. Do not know access code, so cannot follow manual to change...
The Access Code is 0000 as default unless it's been changed
I think you'll find if it's not playing Region 2 DVDs that it's the same old Philips fault in that the laser has gone / is going.
Apr 13, 2011 | Philips LX9000R System
Samsung Home cinema HT-TXQ120 system won't read CDs and DVDs.
Hi.
I have had the same problem.
Just unplug the systme and plug it back in.
Jan 03, 2010 | Samsung HTP-1200 System
Sa-mt1, picture freeze after ab 50 min-1h,than stops;
First of all,if you are using rental dvds, there might be scratch which your dvd player might have an issue to read it;however,if you have tried many dvds in this player and you are having this issue, it is time to move on to another dvd player.
I recommend a Pioneer dvd player.
solutiondoct
Oct 25, 2008 | Panasonic Home Theater System System
Panasonic home theater sound system SC-HT720 won't read or play dvds or cds
mine does the same.the display flashes "prog" and --:-- on cd's,dvd's and even the cleaning disk it almost sounds like it isn't getting enough power to spin the disk.
Jun 23, 2008 | Panasonic Home Theater System System
Cd Player
i need to know if it was playing cds before then i will be able to help, my email is nicodhem@yahoo.com
Mar 23, 2007 | RCA RTD 130 System
Koss KS3102 System Logo
304 people viewed this question
Top Koss Audio Players & Recorders Experts
Steve Allison
Steve Allison
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
