Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
BADGER GARBAGE DISPOSAL NO POWER
CHECKED BREAKERS EVERYTHING I CAN THINK OF, NOT GETTING POWER TO TURN DISPOSAL ON.IT JUST STOPPED WORKING..NO WARNING...NOTHING.
WHAT CAN I DO?
  • 3 more comments
  • richard_macl Dec 29, 2008
    Clarification...Problem solved!! Turned out to be simple..... RE-SET BUTTON!!! DUH!!!!
  • dlee258 Jan 19, 2009
    Pushed re-set button - still no power. Email help to:
    dlee258@hotmail.com
    Thanks!
  • snowman_dumb Jan 26, 2009
    I have the same problem. I hear a hum. I look inside I don't think anything jammed. Any ideas. Thanks.
  • Anonymous Apr 08, 2009
    Pekinduck!  You are great.  I found the switch at the bottom and hit and presto it works again.  thanks for your input.  You saved me a lot of money I'd of called an electrician.
  • Stephen Evans May 11, 2010
    have you checked the switch, could be it took a you know what?
  • 32 Answers
Have you checked the circuit breaker on the disposal itself? In the bottom there's a little button that resets the circuit breaker. press it in and see if that works. If the disposal is still jammed you should hear a hum.
Posted on Dec 29, 2008
How to Dismantle an Under the Sink Garbage Disposal
Full user manual for this here. Cleaning it etc.
Don't think you would destroy the seal if you are careful. Sure you could get a spare if you did from their answerline at top of manual.
http://www.scribd.com/doc/9725184/Badger-5-garbage-disposal-user-manual
Sep 14, 2014 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Garbage disposal
My checklist for garbage disposals:
(1) most disposals have a little red RESET switch on the bottom. Once the impeller will turn manually, press the reset button, and you may get back full operation.
(2) 120 Volt wall switch may have burned out. They're only rated for 100,000 operations before they burn out.
(3) If the impeller is difficult to turn, you may try to use an "flywheel wrench", which is just an offset Allen wrench that fits into the bottom of the motor, and can be used to turn the flywheel manually, freeing the impeller and allowing the reset to work.
(4) The circuit breaker in the breaker panel in the basement may have tripped, cutting power to the switch controlling the garbage disposal. If tripped, turn off the switch to the disposal and reset the breaker.
(5) Disposal motor may have died.
This How-To seems like a nice one:
http://homerepair.about.com/od/plumbingrepair/ss/fix_disposal.htm
Nov 26, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My insink erator the red botton will not reset. it won't pop out. The disposal spins but does not dispose of anything. What's wrong? It is less than 6 months old
If the disposal cutter wheel can spin freely but the motor will not operate, and reset is not tripped, then check circuit breaker.
The check for power at the disposal switch.
If disposal is getting electricity, then disposal may have gone bad.
I used to replace disposals, and some went bad right away, and some never stopped working.
Your disposal probably has 2-year warranty. Buy same brand and size and it will connect to same sink strainer basket without changing out everything.
I wrote ez replacement step from days I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Dec 26, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
It wont turn on. It is getting power but stops after 10 seconds. Tried the red reset button but still wont work. Pls. help! Thanks!
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Aug 22, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I think we all bought a piece of junk with the Badger 5.
Maybe....anyone can get a POS at times...
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
heatman101
Jul 11, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: I have a Badger InSinkErator, it suddenly just sto...
Here is a tip the I wrote that may help you to figure out what is going on withyour garbage disposal and why it is not working.
May 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: Just hums and won't run, even after assuring that ...
May 17, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The motor on my Badger 5 disposal was humming but not rotating. I cleaned out all the debris, reset it and now there's nothing - no hum, nothing. Is my badger dead?
The badger 5 has a dislodge device on the bottom right in the very center. An allen wrench will fit if you have lost the tool that came with it.
FIrts you will need to dislodge anything preventing it from turning. (Insert the right size allen wrench and turn both directions) The remove whatever comes loose after dislodging.
Then opush the red reset button on the bottom. Check the breaker that powers up the disposal, as you may have tripped it.
If the breaker is on, the unit is turning freely, and the reset button is pushed, then the next step is to check for power using a volt meter, to make sure the disposal is indeed getting power. If all the above has been done, the unit IS getting power then yes, the disposal needs to be replaced.
Oct 11, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Is there a reset button on the Badger 5
Yes, on bottom a little recessed button should be pushed to reset the device. If the blade is stuck, the reset might not work but just keep tripping the breaker so you have to free up the blades with a broom stick or other item stuck into the disposal (with the power off of course) to turn the blades manually. Then try the reset button again. and hit the switch. Otherwise, check your kitchen's electrical breaker to see if it has tripped as well.
Aug 02, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My gargabe disposol won't turn off.
sounds like the wall switch needs to be replaced.
Apr 05, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
789 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
