Question about Dell Dimension 4500 PC Desktop
On my dell pc. getting an unwanted message with internet explorer
THe message says"the feature you are trying to use is on a cd rom or other removable disk that is not available. Insert the Destinations disk" How do I remove this message?
  • Dell Master
  • 6,993 Answers
I think you were trying to install a program, then you did not finish the installation before you removed the CD.
You need to uninstall this program from your computer before the message can remove.
You could also go to "Program files" and delete the program from there directly.
Best wishes.
Posted on Dec 29, 2009
Ever since upgrading to Internet Explorer 8, I find that I cannot print emails, open up many attachments, and retrieve other information. For example, if I click on a link, I get the following message:...
Ther are known conflicts with Vista and IE8 - particularly with Vista 64-bit.
I would suggest uninstalling IE8 and reinstalling IE7 or using an alternative browser such as "slimbrowser" (excellent program) or similar.
IE8 can be uninstall by using Add or Remove Programs module in Windows XP, but in Windows Vista, Windows Internet Explorer 8 is not considered to be a ‘program’. Instead, IE8 is categorizing as an ‘update’. Thus, users will not be able to find Windows Internet Explorer 8 in “Programs and Features” of Windows Vista.
To uninstall Internet Explorer 8, go to Control Panel, and click on Uninstall Programs link or Programs and Features icon. Then on Tasks pane on the left, click on View installed updates link. Locate and select Windows Internet Explorer 8 in the list of installed updates, and then click on Uninstall button. Click on Yes when asked that are you sure want to uninstall the update.
If there is no option of IE8 been found on “Programs and Features” or “Add or Remove Programs” dialog box, or uninstallation of Internet Explorer 8 is unclean (causing error message such as setup cannot continue because a more recent version of Internet Explorer has been detected on this computer when trying to downgrade to IE7), try to manually run the spuninst.exe.
To do so, go to C:\WINDOWS\ie8\spuninst\ folder (your drive letter may be different), and run spuninst.exe.
Restart the computer after uninstallation completed.
Hope that helps :)
Nov 09, 2009 | Dell Studio XPS 435 PC Desktop
Dvd rom problem
Try to turn off the vista's burning feature.
It's not yours or anyones burners....just an update in vista which buggered the policies up
Go to your run command and type (start.....Run.....)
type gpedit.msc
Go to User configuration/Administrative templates/Windows components/Windows explorer
On the right pane, double click on "Remove CD burning features" tick the enabled button, then OK.
Reboot or logoff/logon to apply.
If your vista version does not have the gpedit function, do the following.
Open regedit, go to:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
In the right pane, if it does not already exist, create a new 32-bit DWORD value. Name the new value as NoCDBurning, and assign the value data to 1.
This should fix the problem
Sep 07, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Cd rom wont write to disc,can this be fixed?
Its not a terminal problem but an issue with your CDWRITER or the application you use in performing CD Writing
CHECKLIST
1. Make sure you are using a Blank Empty CD
SOLUTIONS
1. Try formating the Blank disks from Windows Explorer and not from the utility software
2. Check your CDWRITER settings (usually problems do not arise from here) you could set the settings default.
Are there any error messages when trying to write data on the CD?
May 21, 2009 | Dell Inspiron 1501, Turion X2 TL-60 1GB...
My windows explorer keeps failing when i restart my pc.
hi i think its hight time to format ur OS with new XP cd.. try to format ur system and ur problem will get solved....
Jan 24, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Dimension 5150 cd-rom stopped working
Open your tower and reseat all the cables that are running to the CD ROM (generally a flat white cable). Also reseat the other end of the cable to the motherboard too.
Ensure that CD Drive is enabled in BIOS (Press F2 as the system boots up to enter into BIOS) Please get back if you need any further help.
Jan 09, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell will not connect with internet
Using another PC, download MEMTST86 from memtst86.com follow directions to burn it to a CD. Run overnight in your Dell. If you have two memory modules, try removing one then the other and see if the problem goes away. Sounds like a hardware problem.
Dec 25, 2008 | Dell Dimension 2350 PC Desktop
I am trying to create recovery disc I can,t load them on the dvd, it keeps saying the dvd has something on it already, which I know isn't the case. Anothr problem I have is that when I use the computer...
the error you are seeing is because a piece of your software such as internet explorer has been corrupted or deleted the cd rom your pc is asking for is a system resore disc. find yourself an xp disc if that is the os you are using and do a repair that should fix your issue
Aug 19, 2008 | HP Computers & Internet
Phone
go on to text messages where it show a menu eg. mms mesages multimedia messages then down that list there will be a block contact thing click in it and type the nnumber you want to block that should work !
Apr 27, 2007 | Samsung Dell Latitude D600 14.1 LCD SXGA+...
Dell Dimension 4500 PC Desktop Logo
19 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
