Why don't you recharge the battery for 24 hours and try it again?
Did you let the battery charge up COMPLETELY before using it the first time?
Do you have another battery you can try?Why don't you recharge the battery for 24 hours and try it again?
You can't post conmments that contain an email address.
could be 1 of 2 problems, the motor or the switch, I would think more the motor. you can get some idea of what the cost would be by going to dewaltservicenet.com and typing in your model number for the parts listing. But also keep in mind that Dewalt has a MAX service rate that they will rebuild the tool up to the MAX rate for it, that includes batterys (or it used to include them)
It's not unusual for Dewalt triggers to go bad and it appears you have correctly tested the trigger. You can test the motor by wiring it directly to the battery but hold on to it and only give it a short burst of power so it doesn't spin out of the case. Dewalt triggers are fairly easy to find online but shop around, they're not cheap.
Test the brushes by catching it in a stalled condition when you have it triggered, then rotate it slightly. If it takes off suspect the brushes or a dead segment on the comutator.
If it doesn't respond to this, then consider the VSR trigger... open it and test by bypassing it when in stalled condition...
I have been rebuilding drills for 10 yrs and have installs hundreds of switches. This is not an issue in a switch like this. If it was, the energy from the motor working should damage the switch more than the static from your body. I would not be concern with it.
It depends on what you mean by intermittent. If the drill takes a few tries to turn on, but works fine once it does, it usually means there's a problem with the switch. If the power is weak and tends to cut out, it generally means there's a problem with the motor - usually brushes. This article might clear things up a bit:
You have burned out the drill motor, it is shorted, the battery smoked due to a direct short, one thing I don't understand why the thermal limiter didn't trip in battery pack, I would contact manufacturer and try to get hem to buy you a new drill.
