Question about BenQ FP757-12 17" Flat Panel LCD Monitor
My BenQ FP757-12 monitor stopped working
I took it apart and there is a burned capacitor on the board in space c736. I was wondering what capacitor to replace it with as it is far too burned to tell. The surrounding ones are both labeled as 27j.3kv
  • yellowpuffer May 11, 2010
    I have the same board apart in my hands. It is a 27J 3KV
I have a similar problem , I have tried taking mine apart but cant open the case , I have removed the 4 screws from the back but I still cant seem to be able to split the case , can you give me a clue what I need to do next??
Tx
Posted on Oct 18, 2009
  • max perron Nov 05, 2012
    you tube has many videos showing how to do.Basically you have to pry it apart but do it once then next time easy.
I commend your courage in taking your monitor apart. I hope it was out of warranty when you did it; because it is out of warranty now.
I have no idea where to find the info you are looking for. Monitors are cheap now, though.
Posted on Dec 28, 2008
Screen remains black
the back lights burn out, the invertors burn out. the power supplies burn up. you can usally repair the power supply with new capacitors
Jan 03, 2010 | BenQ FP731 17" LCD Monitor
BenQ FP71E turns off after 2 secs- Logo flashes then turns off
LCD monitors behaving in this fashion more than likely have a faulty inverter. Refer www.lcdparts.net for solutions.
Sep 13, 2009 | BenQ FP71E 17" LCD Monitor
Medion md 7319
look for capacitors with the tops bulging .. these are high failure rate chinese made capacitors .. they made zillions of them and they fail frequently .. replace any that have buldging tops (should be flat with over pressure vent lines impressed)
Nov 19, 2008 | Medion MD 7317 17" Flat Panel LCD Monitor
White screen
dreaded capacitor issue. benq's were famous for it. if you are handy with disassembly and careful you can take it apart and do it yourself. look for any capacitors with rounded tops. i fixed one ... the part is only two dollars or so but it's a good feeling to know you fixed it instead of tossing it.
Robert
Aug 28, 2008 | BenQ FP737S-D 17" LCD Monitor
Kds vs-f14
There is usually an identical resistor somewhere else on the circuit board, so if you cannot read the colors of the burnt one, you can read the colors from an identical resistor on the same board. If you just replace the resistor, it will probably just burn out again or damage another component, you have to find the cause of the resistor burning out, most likely an electrolytic capacitor failing. Look for bloated or seeping capacitors and replace those as well. Also look for broken or burnt toroid coils.
Jul 15, 2008 | BenQ FP731 17" LCD Monitor
Benq fp737s monitor failure
try resoldering the joints on c826 &c824 near the 4 yellow transformers in the power supply.
hope this helps
kevin numbnuts07
May 28, 2008 | BenQ FP737S-D 17" LCD Monitor
BenQ FP72E 17" LCD Monitor Problem
The video card driving the monitor or the video section of the monitor circuitry is getting bad, probably a capacitor on the board.
srich
May 23, 2008 | BenQ FP71E 17" LCD Monitor
Power but no picture
bad capacitors or power board in the monitor
May 10, 2008 | BenQ FP731 17" LCD Monitor
Benq fp737 17
How old are the monitors?
Normally backlights last at least 30,000hrs of working.
Normally problems on Inverter board transistors near yellow inverter transformers.
Samir
Nov 28, 2007 | BenQ FP731 17" LCD Monitor
My ben t705 moniteur.... problem
I DID REPAIR A MONITOR WITH THE SAME PROBLEM. IT TURNED OUT, THAT ONE OF THE TWO HIGH TENSION GENERATORS FOR THE 2 LIGHTTUBES WAS BURNED OUT. BY REPLACING THE POWER TRANSISTORS AND THE 3 AMP. FUSE ON THE MAINBOARD THE MONITOR IS RUNNING AGAIN VERY WELL.
Nov 22, 2007 | BenQ T705 17" LCD Monitor
BenQ FP757-12 17" Flat Panel LCD Monitor Logo
395 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
