Question about Dewalt 18 Volt Compact Drill Kit
I have a 18V DeWalt cordless drill. I pull the trigger and get intermittent power. Is the switch going out?
  • greybadge Sep 17, 2009
    i have an 18v xrp and it has blown the two battries now it wil not work ,i still have one battrie left but i wil not put it in untill i find the problem
  • David Ford
    David Ford May 11, 2010
    By intermittent power do you mean that it starts up slow and then goes dead and as you continue to depress the trigger you get high speed? Or does it work sometimes and then not
It depends on what you mean by intermittent. If the drill takes a few tries to turn on, but works fine once it does, it usually means there's a problem with the switch. If the power is weak and tends to cut out, it generally means there's a problem with the motor - usually brushes. This article might clear things up a bit:
Whodunnt? The brushes or the switch?
You can get whichever part you need replaced on that same site.
Posted on Dec 31, 2008
Variable speed not working, the trigger is either full on or off. speed switch 1 or 2 works
Replace the switch because a power mosfet inside is defect
650583-6 look for that switch partnumber also ferify it because this is for the model in the netherlands but most time its the same by Makita and its not to expensive will succeed to replace succes. but be careful when pulling out the wires using a thin watch screwdriver to push the unlock holes next to the connector contacts.
Nov 01, 2015 | Dewalt Makita Bhp452 18v Cordless 1/2"...
18v xpr dewalt drill smells like buring then eventually stopped working or Intermittently works.
could be 1 of 2 problems, the motor or the switch, I would think more the motor. you can get some idea of what the cost would be by going to dewaltservicenet.com and typing in your model number for the parts listing. But also keep in mind that Dewalt has a MAX service rate that they will rebuild the tool up to the MAX rate for it, that includes batterys (or it used to include them)
Apr 03, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
How do you know if the trigger is bad? getting dc volts to trigger but nothing out when I press it.
It's not unusual for Dewalt triggers to go bad and it appears you have correctly tested the trigger. You can test the motor by wiring it directly to the battery but hold on to it and only give it a short burst of power so it doesn't spin out of the case. Dewalt triggers are fairly easy to find online but shop around, they're not cheap.
Jan 26, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Have an older dewalt impact driver that needs a new trigger. where can I get one?
You're looking for part number 152274-25. If you type "dewalt 152274" into your search engine, several dealers selling this switch will come up.
Oct 25, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt cordless drill dc988- drill motor works intermitantly when trigger is pulled. Works a little better as it warms up. Im thinking vsr switch, brushes, or motor/armature. please help...
Test the brushes by catching it in a stalled condition when you have it triggered, then rotate it slightly. If it takes off suspect the brushes or a dead segment on the comutator.
If it doesn't respond to this, then consider the VSR trigger... open it and test by bypassing it when in stalled condition...
Mar 20, 2010 | Dewalt 18 Volt Dc988 Hammer Drill,dc825...
Need procedure to replace trigger on dewalt cordless drill
I have been rebuilding drills for 10 yrs and have installs hundreds of switches. This is not an issue in a switch like this. If it was, the energy from the motor working should damage the switch more than the static from your body. I would not be concern with it.
Mar 28, 2009 | Dewalt DC759kar heavy - duty 1/2" 18v...
You have burned out the drill motor, it is shorted, the battery smoked due to a direct short, one thing I don't understand why the thermal limiter didn't trip in battery pack, I would contact manufacturer and try to get hem to buy you a new drill.
Aug 28, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt 18 Volt Compact Drill Kit Logo
461 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
