Question about Nintendo Wii Console
Remote Issue just opened a new wii remote. However cannot seem to turn on. Have changed batteries. When I sync, all four lights at bottom of the control light up, but have trouble turning on the remote.
    Problem Solver:
  • 16 Answers
Small chance of it being broken probaly battery probloms had the same problem for three days
Posted on Dec 28, 2008
The Wii turns on but the remote won't connect to the screen...all lights working also, bought a new sensor bar and still nothing...???
Turn on the Wii console, when at the home screen press any button on the wii remote, if the lights on the wii remote remain dark then it needs new batteries.
If the lights all light up at the same time then stop this means you are not synced. Press the 1 and 2 buttons at the same time to sync, this will work if they have been synced before.
If your four lights still blink blue then you need to open the little compartment on the console that is right below the disc tray. Inside is a little red button, press the button. Now open your battery compartment on the wii remote and take out the battery, then press the red button inside. Put the battery back in and the controller should sync up. If you are still having trouble you will need to contact Nintenedo Technical Support.
Hope this helped!
May 16, 2011 | Nintendo Wii Console
Tip
Syncing your Wii-mote to your Nintendo Wii
So you just bought a new Nintendo Wii Remote Controller but when you click the power button the four blue lights at the bottom just blink huh? Well that just means your Remote needs to be synchronized to your Wii.
Here are simple step by step instructions to do so.
1) Turn on your Nintendo Wii.
2) Open the door on the front of your Wii covering the SD card slot and the SYNC button.
3) Open the battery compartment on the back of your Wii-Remote Controller.
4) Press the red SYNC button on your Wii.
5) Press the little red SYNC button on your Wii-Mote.
6) Wait until a solid blue LED light comes on on one of the four lights at the bottom.
7) If it doesn't work the first time, try again.
Your Wii-Mote should now be synchronized.
on Dec 21, 2009 | Nintendo Wii Remote Controller
I have 3 wii remotes was using one that had batteries it died so i replaced all remotes with new batteries and now none of them will sync or work they just turn off right away
After replacing the batteries, you may have to do a hard sync by pressing the sync button beside the SD slot on the Wii and the sync button on the back of the Wiimote underneath the battery cover. Both buttons are a kind of dark reddish-brown colour.
Mar 25, 2011 | Nintendo Wii Console
All four lights on bottom blinking
you have to sync the remote with the wii to be able to use is.
procedure should be the same as for the original wiimote
Standard Mode SynchronizationNote: Make sure you have placed batteries in the Wii Remote (how to).
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system
Dec 26, 2010 | Nyko Wand? for Nintendo Wii
Wii remotes are not responding to anything. batteries have been changed and lights are flashing but
You need to synchronize them to your Wii. First turn on your Wii. Open the battery compartment on the back of your Wii-mote and the front SD Card door on the front of your Wii. There is a little round red SYNC button on the back of your Wii-mote and a red SYNC button on your Wii in that door. Press the button on the remote and then on the Wii and it should sync. If it doesn't work at first try again. You know it is synched when one of the four LED lights at the bottom of the Wii-mote is solid.
Dec 26, 2009 | Nintendo Wii Console
Wii remote wont work change batteries and all lights at bottom just keep blinking
Sync it.Open the front cover on your Wii, then push the red button there, then open the batteries cover on your Wii Remote and push the red button there.If this not help press and hold the red SYNC button on console for 15 seconds. This will clear all synced Wii Remotes from the console.Then try to sync Wii Remote again.
Nov 04, 2009 | Nintendo Wii Console
My wii remotes wont pick up signal blue lights flash then just go back out again
Hi, check the batter level and then try re-synching the remote's.
Here's instructions for both:
f4bc8924da.gif A fresh set of alkaline batteries should last, depending on amount and type of use, up to 35 hours. This can vary greatly based on certain factors, such as Wii Remote Speaker Volume, Rumble, battery quality and age, and type of game being played.
Important Note: If you are using rechargeable batteries, the only type of battery recommended are Nickel Metal Hydride batteries. When it comes to using rechargeable batteries, you must follow manufacturer guidelines for safety and proper usage. Failure to do so could cause damage to the Wii Remote and void the warranty.
There are two ways to check the Wii Remote's battery levels:
  • Remove the battery cover and press the Red "Sync" button. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength, with one light flashing indicating the lowest level.
    or
  • Use the HOME Menu to check battery level of each Wii Remote:
    1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
    2. Select the Wii Remote Settings option from the Home Menu.
    3. The battery level of all synced Wii Remotes is displayed along the bottom. Four bars indicates a full charge, with one being the lowest charge.
55851daefd.gif Note: Make sure you have placed batteries in the Wii Remote.
  2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
  3. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
This procedure must be followed for each additional Wii Remote added to your system.
I hope this helps
Mike
Jul 30, 2009 | Nintendo Video Game Consoles & Games
Remotes can't be found
When you change the batteries for a Wii Remote (in my experience) you have to re-sync (reconnect) them to the Wii console. To do this, there is a button on the Wii Remote by the batteries that either says sync or will show curved bars on I think i red button. This same button should be located on the Wii console. You have to push the sync button on the Wii then on the remote to sync them together. This should solve your connection problem.
Apr 29, 2009 | Nintendo Wii Console
Cursor does not appear
exchange it
    Cursor not appearing
    Please note that our experience shows that this troubleshooting is best performed using only one (1) Wii Remote at a time.
  • Some games do not use the cursor feature of the Wii Remote; Make sure the game you are attempting to play uses the cursor by reading the game's instruction manual. You can also exit out of the game to return to the Channel Menu and use the Wii Remote to see the cursor. If the cursor still does not appear, continue with the steps below.
  • Trying to use multiple Wii Remotes in the Mii Channel or Photo Channel? These Channels only allow the Wii Remote designated as "Player 1" to function.
  • Verify that the Wii Remote's pointer lens is free of obstructions and contamination (stickers, heavy smudges, etc.). The pointer lens is the tinted rectangle at the end of the Wii Remote.
  • Check the battery power level by turning off the Wii console, then opening the battery cover of the Wii Remote. Press and release the red "SYNC" button to check battery strength. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength. Our experience has shown that as your battery strength decreases to one (1) or less lights flashing, the cursor may not appear. For troubleshooting, if possible, try using fresh batteries so that all four lights illuminate. For guidelines on using batteries, please click here. If after inserting brand new batteries, you are still seeing less than all four LEDs flash, then your Wii Remote will need to be repaired. Please click here for repair information.
  • Is the Wii Remote properly synced?
    Press the POWER button on the Wii Remote to see if the Wii console powers on.
    • If it does, the Wii Remote is synced with the system. Please skip to the next section.
    • If the power doesn't come on, power on the system manually and try syncing the Wii Remote.
      • If the Wii Remote will not sync, there is likely a problem with the Wii Remote. Please click here for repair information.
      • If the Wii Remote will sync and the cursor still does not appear, try another Wii Remote if possible.
        • If at least one Wii Remote is working, there is likely a problem with the first Wii Remote and it will need to be repaired. Please click here for repair information.
        • If you have only one Wii Remote, or none that are working, please continue troubleshooting.
  • Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup).
  • Check the cord on the Sensor Bar for any frayed wires or kinks, and verify that the Sensor Bar is free of obstructions.
  • Check the button functionality, and that the Sensor Bar is operating correctly, by accessing the Wii Main Menu. Use the "+" and "-" buttons to scroll side-to-side through the Wii Channel screens.
    • If you are able to scroll with the "+" and "-" buttons, but the cursor is not appearing, then there is likely a problem with the Sensor Bar. Please click here for additional Sensor Bar information.
    • If there is no response, there is likely a problem with the Wii Remote. Please click here for repair information.
Dec 11, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
41 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
