Question about Nintendo DS Console
My son got a broken stylus stuck in the stylus holder help
The end of the stylus has broken off and the rest is stuck in the ds can anyone help me get it out?
  • lil_gab_98 Dec 28, 2008
    i have a ds which dumb me i stuck a hair clip in the stylus holder how can  get it out?? HELP!
  • rzeznik_girl
    rzeznik_girl Jan 02, 2012
    My daughter got a mini stylus stuck in a ds lite and I tried everything and I went to hardware store and got a long skinny screw and very carefully put it down the hole and lined it up in the middle and screwed it down a little, i tried pulling a few times and the screw came out so I did it a little more down and then I gave it a pull with some pilers and BAM it came out.. Just do it nice and slow
    Scholar:
  • 168 Answers
Yes I can help you, the stylus holder is screwed on to the inside of the backing case.
if you remove the case back you can remove the stylus holder and then the stylus and put it back together.
Be careful when taking it apart and putting it back together not to break the power switch off, it is extremely delicate. turn the speakers all the way down and make surethat the slides are in position before putting the case back on.
Posted on Dec 28, 2008
  • Josh Boyer
    Josh Boyer Dec 30, 2008
    if you want you can ship it to me and I will do it for you, I'll throw in a new stylus as well.
    ninja_freak318@hotmail.com
Posted on Jan 02, 2012
SOURCE:
Alcatel one touch sim stuck in sealed phone, no tray just a slot next to the SD card holder. Can anyone please help me if they know how to get it out??
can you take a pic of the slot and how the sim card is stuck in there? Have you tried a small needle in there to see if you can catch the end of the sim card and then pull it out?
Jun 09, 2016 | Alcatel Cell Phones
My epson stylus photo rx 650 printer gives a error message of "A printer error occurred. Please see your manual. The printer is approx 4 years old but is not used extensively.
Hi Keith,
Based on your follow up comment it seems likely that something is blocking the printhead from getting back to the resting/cleaning pad and could actually be the resting pad holder itself.
I'd recommend shifting the printhead over to the left out of the way and then shine a strong light down into the area over to the right to see if there's any foreign objects stuck down there or anything similar that's getting in the way.
If the resting/cleaning pad has popped out of its holder, you should be able to push it down and back into place with a little care (and a pair of gloves).
I don't have specifics on the RX650 but some models have a sort of train carriage style connection with a shuttle that moves the pad holder. If that's the case here, you can usually push the pad holder down and under the connector to bring it back up into position...
Hope that's of some help.
Martin
Dec 09, 2012 | Epson Stylus RX650 All-In-One Printer
My stylus is stuck im my ds stylus holder
Is it too big for it? If so, you might want to try this: the stylus holder is screwed on to the inside of the backing case.
Oct 16, 2010 | Nintendo DS Console
The top screen is broken
Hi it can be done by you but i suggest taking it to a proffesional since incase something else goes wrong u'll end up spending even more than wat it would cost to get it doin professionally.
Regards.
Jul 08, 2009 | Nintendo DS Console
My ds stylus clip has broken and it does not stay in its place often falls out of the ds holder help
the only way to fix it is either glue something in its place to hold it in, or buy a new stylus
Jun 04, 2009 | Nintendo DS Console
Broken in half got new shell don't know how to put together
much of it is pretty straight forward, the only hard part is putting the ribbon cable thru the hinge for the top screen, without ripping it, best thing to say is put the ribbon cable in first, then the wifi and mic cables (black and white), rest is pretty straightforward.
Apr 17, 2009 | Nintendo DS Lite Console
Filter broke off in the holder
I have recently had to remove one that the end cap had broken off but I don't think you will be able to get this one out. You will need to replace the filter housing. It's not hard to do. You just need to get the part, pull the 2 screws holding it in along with the wire off to the left side, remove the water hoses and install the new housing.
Apr 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Stuck on floor 7 of the tower
***************SPOILER***********************
Jan 05, 2009 | Nintendo Professor Layton & the Curious...
PRINTER CARRIAGE
I have just solved a loud juddering noise on a C44 printer whenever the cartridge carriage moved to the far right "rest" position.
I removed the cover by pushing in the 3 spring clips at the back. Below the cartridge holder there is a unit for collecting ink when the unit self cleans- see diagram on http://www.compassmicro.com/files/S%20C43SX%20(LA)%20exploded%20diag.pdf
page 4 and spare part drawing ref 512.
The piece of plastic containing the hook seen on the right of the unit had become dislodge and the unit no longer sat square in the holder. I removed the unit, replaced the dislodged plastic piece and hey presto problem solved. Hope this helps anyone with the same problem.
Nov 19, 2007 | Epson Stylus C44UX InkJet Printer
Nintendo DS Console Logo
1,435 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
shevantha perera
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
