Question about GE Spectra JGBP30 Gas Kitchen Range
When i increase the temperature control the oven soots excessive
Soot is observed coming from the vents why does this happen
  • GE Master
  • 5,568 Answers
Check your oven for flame color; what you are describing could be deadly. It is possible that you have an air vent clogged or blocked causing the flame to burn yellow indicating incomplete combustion and possible source of carbon monoxide. This is very dangerous and I would strongly recommend you purchase a carbon monoxide detector. We have one on the main floor and one in our basement.
A defective gas floor furnace in a home in a neighboring town 2 days ago put three children and two adults to sleep during the day and a 64 year-old man died of the fumes. The others are recovering but are all hospitalized. The family moved to Clay, WV from New Mexico only a week ago.
Posted on Dec 28, 2008
Why does black soot collects on top of my electric range?
The oven flame needs to be adjusted so more air will mix with the gas. This is unsafe since the amount of carbon monoxide is greater under the circumstances.
Jan 14, 2014 | Tappan Kitchen Ranges
Jenn-air jdr8895 sabbath error
Faulty range/oven parts aren't the only worry a gas range owner has; the threat of carbon monoxide is very real and should be paid close attention to when doing repairs on the range.
If your range or oven gives off soot, you definitely have a carbon monoxide problem. Soot is the result of inefficient or incomplete combustion. There are always elevated levels of carbon monoxide with soot production. Properly adjusted range/oven parts do not give off soot. You may have poorly adjusted gas pressure, the air shutter may need to be opened, or you may be supplying fuel the oven isn't designed to handle. Don't use natural gas in liquid propane stove or vice-versa.
Increase Engine horsepower.
Jun 02, 2012 | Jenn-Air JJW8230D Electric Double Oven
I noticed soot in my lp gas oven that had been clean. concerned when it started to ruin my food I decided to run the self cleaning cycle again. My whole house filled with toxic soot. My eyes were on fire...
Normally soot is from a range that hasn't been converted for the gas type, like natural or propane. It may be set up for natural when you're on propane or visa versa. Has this range ever worked properly without sooting?
Sep 20, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Jaguar S Type, DPF light will not go out even though it has been replaced
it doesn't rave to ignite and clean the exhaust system even though i press the dpf button
Jan 02, 2011 | 2005 Jaguar S-Type
Fridgatare modle #FGG3054KFB I have a frigidaire range that has been converted to propane. When the oven is turned of it has a strong propane smell and there is alot of moistier inside. The flame is about...
It shouldn't be burning yellow and emitting soot at all;sounds like on of these possible causes-
(a)blocked burner airways(this can lead to yellow tipping and sooting on LPG powered appliances because insufficient air is getting through to the burner causing it;you can also get this effect on LPG barbecues say if dead insects or spiderwebs are in the burner pipes and airways after a period of storage),
(b)incorrect aeration being set when the burner was converted using LPG jets(too much gas and not enough air causing yellow flames/smells and sooting),
or (c) if you use propane cylinder gas a dicky or faulty regulator. I would get it looked at investigating all the possibilities I mention and taking action to correct this where necessary ie clearing the burner airways(if this is causing your problem), adjusting the aeration in the burners until you get a clear noiseless blue flame without any excessive yellow and sooting(but even after good adjustment you may find still get a very slight yellow tip without sooting at the top of the flame;this does happen with propane gas and there is a slight tendancy for this to happen more often with butane-butane tends to display very slight yellow tips on ignition increasing slightly as the burner warms up to full temperature) or if you use propane cylinder gas replacing the regulator if that is necessary.
Nov 22, 2010 | Frigidaire FGB24S5A Gas Single Oven
DPF FULL
The DPF is designed to 'Burn off' the soot deposits that accumulate, but in order for this to happen the exhaust has to become really hot. The DPF will fill up if the vehicle does a lot of short trips and the exhaust fails to get hot. The cure is a long hard drive
May 11, 2010 | 2009 Jaguar XF
Kenmore gas stove. Oven burns big flame which soots
The manifold needs to be cleaned and adjusted could have rust etc in it Not a good thing to do yourself unless you know what you are doing
Jan 24, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Soot in dryer
sounds like you migt have had a flash fire in the vent line. you need to open the dryer and clean out the vent line
Dec 13, 2006 | Crosley CDG6000 Gas Dryer
Open Questions:
See all GE Spectra JGBP30 Gas Kitchen Range Questions
GE Spectra JGBP30 Gas Kitchen Range Logo
184 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
