Question about Samsung HL-S5087W DLP TV
Samsung HL-S5087W DLP 50 inch shutting off
Hi I am a woman and I am trying to fix my Samsung. It has been shutting off lately and becoming worse. I have been searching the internet for possible solutions. I have the TV currently unplugged and the back is off where you replace the lamp. I am going to vacuum out the dust. I noticed a blue switch on the bottom right which looks like it would be pushed down when I put the back on. Is this correct or should I do something with the switch? Also I noticed that someone said that their TV was shutting down due to HD programming problems. How do I check if that is the problem? I have about 4-cables disconnected, the TV on the floor unplugged and want to try anything/everything to resolve this before I spend any money. Do any of you guys or gals have any practical solutions before I put it all back together? I am not mechanically inclined but don't mind learning and don't mind having a screwdriver in my hand. Thanks for your help and advise.. Hurry it's the weekend and there is nothing to do. This is the only TV in the house.
Raelyn
  • 4 more comments
  • Raelyn Frantom
    Raelyn Frantom Dec 28, 2008
    I can only see just one small fan. Could the need to replace the bulb cause the TV to shut down or not? Thanks...
  • Raelyn Frantom
    The red standby light is on when the TV is off and the green light blinks a few times when you turn on the TV. Other than that the temp light doesn't come on at all. Sometimes it takes the TV a minute to turn on while the green light is blinking repeatedly. Other than that I don't know... Thanks for your help.
  • Raelyn Frantom
    Raelyn Frantom Jan 06, 2009
    Hi, Just wanted to reply and say thanks for all your help. I took the back off of the TV where the lamp is, vacuumed and cleaned everything and then removed the sensor switch plug (blue switch) and replugged it it. When I put my TV all back together and connected everything it never turned off again!! It has been a week. Thanks to all these great online help sites I (a woman) fixed it myself and saved our family a ton of money. I believe if people would investigate, learn how to do things on their own and be patient a lot of repair costs would be eliminated. Thats for all your help!! Fixya is a great site....
    Sincerely,
    Raelyn
  • lindatanner Feb 01, 2009
    Hi
    I have the Samsung HL-P5063W 50" DLP.  I replaced the lamp as it had no picture and the words were flashing where you turn it on.  It still doesn't work.  It clicks on and off like it is trying to run.  It does this about 3 times then turns itself off.
  • Anonymous Feb 15, 2009
    samsung 50 inch dlp is 3 years old . the tv turns on but the screen is green. what can i do?
  • Chris Gibbons May 11, 2010
    Your TV could be shutting down to to high temperature. Cleaning it out cannot hurt. Make sure all the fans spin. They are not on all the time. I cannot help you with the blue switch.
  • 505 Answers
Whats the error?
Posted on Dec 28, 2008
HL-S5087W IS WORKING RIGHT NOW, BEAUTIFUL PICTURE BUT AFTER 20 MINUTES THE PICTURE GET OUT. THE LAMP IS NEW.
I went through the same exact thing. I had to replace the DMD board. No problem after that.
Feb 26, 2015 | Samsung HL-S5087W DLP TV
What is high pitched sound with samsung 52 inch dlp tv . works fine
Need to adjust the vs voltage in the power supply is to high, you have to use a multimeter on dc voltage and only go down 10% of the actual voltage.
Dec 18, 2010 | Samsung HL-S5087W DLP TV
Samsung HL-S5087W DLP rear projection TV keeps shut off and won't stay on longer than 30 seconds.
your bulb has reached the end of its life (at least this is what your tv thinks) you need to replace the bulb and or make the think you did. (there is a reset in the service menu for the bulb)
Dec 14, 2010 | Samsung HL-S5087W DLP TV
My dlp tv (model number-hl-s5087w)is making a humming noise
Bad Color Wheel.
Samsung Parts 1-800-627-4368
Mats 1-800-628-1118
Oct 14, 2010 | Samsung HL-S5087W DLP TV
Screen blacks out on samsung DLP
It may be a loose conetion inside the set. Open and carfully check the conections.
Aug 20, 2009 | Samsung HL-S5087W 50" HDTV
Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
May 02, 2009 | Samsung HL-S5087W DLP TV
Color disappears from DLP display
the problem here is the crt cicuit unplug from the wall take off the back its the cicuit board thats pushed on to the tv screen pull it off. you will see R G B its the B one thats faulty it looks like a transistor. call an engeneer and he will put a new one in for you i hope this helps you???????
Apr 23, 2009 | Samsung HL-S5087W DLP TV
Turn tv on and then it will turn itself of can immedately turn back on it is a 50 inch SamSung one year old can any one help with this problem
do a voltage check the transformer & the bridge rectifier and the whole off the power supply use a meter ther may be power starvation
Mar 11, 2009 | Samsung HL-S5087W DLP TV
Samsung HL-S5087W Shuts off
check the vertical amp section
nuwan.
Nov 05, 2008 | Samsung HL-S5087W DLP TV
Samsung HL-S5087W DLP TV Logo
565 people viewed this question
Jerry Greenberg
Jerry Greenberg
