Question about Toshiba 53H71 53 in. Rear Projection Television
53HX71 Replaced STK392-110 about 7 months ago worked well..now convergence failed again
I replaced the STK392-110's about 7 months ago and the TV picture looked beautiful. Yesterday I saw a wavy blink, and the blue horizontal waves started. Today the red and blue have started to fail. I had the ic's professionally soldered and the soldering quality looked outstanding. He used thermal compound quite liberally so I am not sure that's the problem. I think there are two possibilities if the STK's failed again: overheating or a bad quality part. Can you suggest a good part's site, and any other possibilities before I swap them out again? Or is there an upgraded part number to replace these?
Thermal compound should be used SPARINGLY for maximum effect. There should be enough to create a thin film over the entire mating surface. Too much compound reduces the heat transfer from component to heat sink. I buy parts from www.mainelectronics.com They are reputable and I can drop by on my way to work :-)
Posted on Jun 30, 2007
My Sony KP-46WT500 has a yellow arc of color on the upper left side that never goes away even with plug in devices like Wii. It started about 6 months ago and has gotten worse over time. What can I do?...
Very common problems,through out the DLP tv life cycles could happen again again until end of the tv life itself.The tv have a problems known as a convergence picture problems,it is dead.Tv have any colors lines like R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?Yes?Than the tv convergence board it is dead.The tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The Shop will cost u like $300-350 for parts and labors.
Aug 03, 2011 | Sony KP-46WT500 46" Rear Projection...
Red is ghosting to the right. i replaced the convergence tubes about 6 months ago. went with the expensive ones "not the cheapy's" used heat sync putty stuff and everything. the problem is...
Yes,the tv problems it is the same,it is the tv convergence problems again,now it just color it is shaded in shadows pictures,instead of wavies mis colors R,G,B mis alignments.Yes.The tv convergence board it is the problems,must be repair again.
Apr 27, 2011 | Sony KP-57WS500 57" Rear Projection...
Convergence issue Blue not convering correctly, but the other colors do. The blue is warped at the top and bottom of the screen. Is this problem something that can be fixed?
Yes,the covergence ICs and precision resistors can be replaced to rebuild the area. A reputable shop may charge around $300 . If you are technical person,I can guide you further to do yourself!
Jun 04, 2010 | Toshiba 53HX71 53" Rear Projection...
HAVE A JVC AV-56WP30 REAR PROJECTION TV THAT THE PICTURE APPEARS IN A BOWED SHAPE. THIS TV WAS JUST REPAIRED FOR THIS PROBLEM ONE WEEK AGO AND IN 100 MILE DRIVE TO PUT IN APARTMENT IT IS AGAIN NOT WORKING....
The convergence is dead,Must replaced Convergence ICs and resistors.Tell the shop to repair it again.They probally didn't replaced the ICs or resistors.This problems can't come back about a week,at 6 months i can understand.
Jan 11, 2010 | Televison & Video
I have a Toshiba projection tv 53HX71 and I get 2 or 3 red shadows on everything, how do I fix it
The convergence IC's need to be replaced (possiply 2 fuses will also have blown) this is a common problem.
Sep 18, 2009 | Toshiba 53H71 53 in. Rear Projection...
My TN55X81 is showing the same problem.
Replace the IC's with STK 392-110T.
Toshiba has a Service Bulletin on this problem.
Aug 01, 2009 | Toshiba TN61X81 61" Rear Projection...
Toshiba TP48C90 Convergence (replaced ICs, worked for 2 days)
Well, my thought is that there are a ton of knock off generic convergence IC's out there that usually hold up as long as yours did. Professionals like me will only use Sanyo original STK's. The counterfeit STK's out there are everywhere. Do some research on the web to locate Sanyo originals, they are out there.
Jun 11, 2009 | Toshiba Televison & Video
TV Shuts off by iself!
Don't feel bad about Mits. All the projection companies and all the new TVs have markedly poorer reliability than the good old CRT types. You should see all the class action lawsuits against even some of the best companies!
The power supply section is not working.
Common possibilities are:
- Convergences amps have failed overloading the supply
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- CRT tube has failed overloading the supply
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Feb 13, 2008 | Mitsubishi WS-65711 65" Rear Projection...
Phillips 55PW9363 cycling on and off
The power supply is going into a protect mode. There may be a different fault.
Oct 06, 2007 | Philips 55PW9363 55" Rear Projection...
I have No picture but I have audio
have the tech look at your tv once again your problem is in the video section.the ic that controls that and the related circuit are not working parts needs to be replaced.good luck.
Apr 01, 2007 | Sony KP-53V45 53" Rear Projection...
Toshiba 53H71 53 in. Rear Projection Television Logo
69 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
