Question about Gateway 7322GZ Notebook
Trying to clean heat sink etc
Hi, my Gateway 7322GZ runs hot and crashes frequently. I intend to clean the heat sink, fan, and re-apply thermal gel. I have opened the machine from the top to expose components. Not sure what to do next ... I have had no success with finding a disassembly guide for this type of laptop. I am trying to generalize from steps related to other machines but this one looks different than those and I'm not sure what to do next. Any thoughts?
  • 25 Answers
I believe it is quite normal for a computer to get hot. That doesn't mean that it should crash though. I think you have some registry errors.
Try these tools.
www.CCleaner.com
http://eusing.com/free_registry_cleaner/registry_cleaner.htm
Or my website
http://sites.google.com/site/turbospeedmycomputer
Posted on Dec 29, 2008
My pc fans runs constantly and the computer is hot
There are several things to look for here.
  • The CPU Heat sink (the big metal block with a fan) may not be making good contact with the CPU surface area.
  • Thermal compound may have not been applied between the CPU surface area and heat sink
  • The heat sink and fan are not sufficient enough to cool your CPU
  • Dust buildup is not allowing proper circulation of cooling air
If this system is not a name brand and covered by warranty then I would remove the heat sink (carefully) and verify that the mounting bracket is not broken or loose. I would check that ample thermal compound is applied, and if not use rubbing alcohol to remove all compound from the heat sink and CPU and purchase a tube of compound to apply yourself. I would also thoroughly clean the heat sink with compressed air.
If the heat issue continues then you will want to consider upgrading to a more powerful cooling solution.
The CPU fan should run constantly but in some systems will run between 50% and 100% speeds assuming a variable temperature control is applied to the system via motherboard or third party installation.
Sep 06, 2011 | Computers & Internet
Help, cpu over heating ,fan and heat sink have been cleand.
The only thing that you did not mention was fresh conductive thermal grease compound, did you take the heat sink off the processor ic and remove the old thermal compound? if you have not done this you will need to complete the repairs and apply fresh conductive thermal compound this will dissipate up to 50% of the heat and should solve your problem. If this fails you need to make sure the processor cooling fan is running properly, or the processor ic may need to be changed because of thermal runner way.
Feb 28, 2011 | Gateway 505GR PC Desktop
My nv7802 overheats and shuts off,fan is running but the heat sink gets very hot
The fan may be running too slow (faulty bearing) or the fan and heat sink assembly may be clogged with dust.
Check the CPU fan to see if it spinsfreely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Dec 30, 2010 | Gateway NV7802U Notebook
Unit gets very hot within minutes of turning on and slows graphics down to a crawl or even crashes the machine.
The cpu processor is getting to hot, check to make sure the cpu fan is working properly, if it is then the laptop must be taken apart. Chances are it is dirty and needs cleaning, the heat sink should be removed from the cpu for cleaning out the old conductive thermal grease and new applied. If the cpu fan is not functioning it must be replaced.
Dec 29, 2010 | Dell Latitude D620 Notebook
My Gateway MA7 (MT6223b) laptop is overheating, and internet freezes. have replaced main fan, but only worked for a short while - any suggestions most welcome
You might need to re-apply some thermal grease onto the CPU's & chipset's surface beneath the heat sink. You might also need to clean the heat sink's vents.
Oct 14, 2010 | Gateway Computers & Internet
Overheating?
you can buy a cooling pad or try cleaning your fan or a heat sink
or change your fan and heat sink
May 19, 2010 | Gateway MT3705 Notebook
My cpu overheats
clean the cpu cooler slots and replace the thermal compound on the cpu ....make sure you clean off the old thermal compound .....only a thin layer of new thermal C will do all most see through ... hope this helps my friend
Oct 25, 2009 | Gateway 504GR PC Desktop
Dell 8400 heat sink / fan issue
You can find professional cleaning solution products at any good computer parts store, or you can rubbing alchohol (the less water content the better) use a lint free cloth like the kind to clean eye glasses.
In my opinion the best thermal paste is Arctic Silver
Sep 23, 2009 | Dell Dimension 8400 PC Desktop
Gateway 7405 GX Fully shuts down at random intervals
It sounds like a thermal shut down when the processor over heats,one thing it might be is that the heat sink is not seated properly on the processor.When removing the heat sink make sure you have thermal paste to place between the processor and heat sink.That should give you a good starting point.
Jul 28, 2008 | Gateway 7405GX Notebook
Fans run all the time
How many HDDs/internal devices are you running off *********** board? If you have an AMD processor, they tend to run hot too. If your computer is running agonizingly slow or shutting down by itself, I would suggest you do the following:
Take your heat sink off your CPU and clean off the heat sink paste and re-applying. If you haven't done this before, you only need to put it on in a VERY light film so you can partly see through it. Applying too much can cause over heating.
Apr 06, 2008 | Computers & Internet
Gateway 7322GZ Notebook Logo
180 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
