Question about Thermador MBYB Microwave Oven
Stops after 4 sec.
Starts after time is put in but will shutoff and start cooling after 4 secs.
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number so we can help you.
AFTER SETTING TIME COOK TO 1 MIN 60 SEC AND PUSHING START BUTTON 4O SECS MORE IS ADDED, I.E. TOTAL 2 MINS SHOW ON DISPLAY. CAN I RESET THE THE COMPUTER.
There are sixty seconds in a minute, so 1 min 60 sec is the same as 2 min. If you want 40 seconds less than 2 minutes then set it for 1 min 20 sec or for 80 sec.
Oct 03, 2013 | Danby DMW139 Microwave Oven
Micro wave stops working after 30 secs
Replace the door interlockswitches - or try re-positioning the existing set. They wear after time
Jun 08, 2012 | Neff H5470 Microwave Oven
Khhc2090s trouble
The sensor errors are probably just from opening the door and interrupting the sensor cook cycle.
By the way, you should always press "Stop" before opening the door of a running microwave. Otherwise, the door switches will prematurely fail.
I would first check the door switches and their mounts. See this help file.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can also download manuals, installations info, and parts lists here.
dee77f7.jpgWe're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Nov 25, 2011 | KitchenAid Microwave Ovens
The microwave stops itself everytime at 59 secs if put on for any time over a minute
Change the damper motor and switch. Cost for both approx. $30.00. Must remove cover to gain access to motor & switch.
ZephyrKnight
Feb 17, 2011 | Sharp Microwave Oven Microwave Oven
GE Spacemaker JVM 1631: Starts working and stops 3 sec later??
your magnetron is leaking RF do not use until you replace the magnetron, it is interfering with the pc board
Feb 05, 2010 | GE JVM1631 Microwave Oven
Shuts off
change your electrical wall plug to a diffferent one, do not use extention wire pls, there is insufficient to drive your microwave, thats why it resets and restarts again
cheers
Nov 25, 2008 | GE JVM2070 Microwave Oven
I have a Maytag Model MMV5207BAB over the range microwave oven that crapped out after 11 mos use. No warning, just no power. The outlet is fine I have no power surge problems in my house. This is the...
There is an internal fuse which is located underneath the side\top shell. If you have no lights or control panel, this is the most likely cause. This is not difficult to replace.
Nov 08, 2008 | Maytag Microwave Ovens
Microwave runs, stops and counts down, starts again, etc.
It sounds like its over heating or the magnatron or the Hi voltage transformer. if you open it and start it a fan should be cooling off the magnatron if its not then the fan is bad and thats your problem Worse case is that the power transformers drawing too much current and over heating and shutting down the first problem i explained though I've seen a hundred times. BUT BE very carefull as there is hi voltage inside this puppy and I've seen it grab and throw a grown man across the room!!!! if you know nothing about electrical or electronic devices its best that you leave this repair to a pro. Good Luck
May 04, 2006 | Amana AMV1162 Microwave Oven
Thermador MBYB Microwave Oven Logo
Top Thermador Microwave Ovens Experts
William Miller
William Miller
Chuck
Jerry Greenberg
Jerry Greenberg
Are you a Thermador Microwave Oven Expert? Answer questions, earn points and help others
