Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Our Bosch diswasher smells (foul odor) after a wash cycle.
The DW drainage line is plumbed into our garbage disposal. Our Bosch DW is only a few months old--purchased from Lowes in Visalia, CA.
Thanks for you help,
Ken Berg
12-27-08
  • tacorob May 11, 2010
    flush the disposal out w/ bleach see if that helps or get the dw re plumbed w a trap to stop the smell from coming back thru
    Novelist:
  • 269 Answers
Check that it doesn't stay damp inside. That allows any trapped food particles to get funky. Clean it, wiping door seals and dispenser compartments, clean the filters, especially the drain filter if any. Then run on its hottest cycle with a cup or so of vinegar in it. That should clear up the smell. In future, let the beast get dry inside after use. Normally it will be pretty dry at the end of the cycle, but if you cut short the drying time to save on electricity, then you will have to leave the machine open for a little while, and open a crack all the time.
Posted on Mar 26, 2014
Make sure the drainage hose is not pushed all the way through the gooseneck in the pipe. Doing so will bypass the standing water which prevents sewer gasses from escaping into the dishwasher.
Posted on Feb 05, 2009
Replace dishwasher
Is your DW plumbed into the garbage disposal as many are? Or does it have the drain line running into a pvc opening in the sink drain line? Remove the drain line to see if water gushes out. If no or minimal water leaves your drain line from the DW, then the problem is internal in the DW. Most likely cause is a plugged screen at the inside bottom of your DW, or the pump is blocked. Best way to resolve is to get a wetvac and just suck all the water out of the inside before you remove the DW. Otherwise you will have water splashing out on your floor. If you can see the screen is plugged up after doing so, then pull the screen out and then turn the DW on. If operating normally it will go into the pump out mode first before adding any water. Turn off the water to the DW under the sink first to eliminate any concern about adding additional water into an already filled up DW. Good Luck!
Feb 16, 2017 | Dishwashers
Tip
Garbage Disposal Smells
What can you do if your garbage disposal starts to stink up the kitchen? Because of the stuff that you put down the disposal and grind up the residue can sometimes start to create a foul odor that can be noticed in and around your kitchen. To combat this problem there are some general things that you can do and also some things that you and grind up in the disposal that will help to keep it smelling great.
One of the things that will make the disposal smell bad is if your dishwasher discharges through the garbage disposal. The food left after the water goes through will soon start to spoil and stink. Make sure that you run your disposal after the dishwasher runs to clean out the food and keep the disposal clean.
Some soft foods like meats and cooked vegetables will also tend to stick to the plate of the garbage disposal. These will cause a smell to develop after a time as they breakdown. To stop this from happening keep harder foods or foods that smell better for last to run down the disposal. This will help to clean the plate and keep the garbage disposal smelling better.
If you are going to be away for a long time, or you are having friends over and want your garbage disposal to smell good, you can use a lemon or lemons rinds. Cut up the lemon and grinds it up before you shut down the disposal. This will have your garbage disposal smelling great!!
There are also commercially produced garbage disposal cleaners, deodorizers, and degreasers, that you and buy at most grocery or hardware stores that are made specifically for this purpose.
http://www.fixya.com/support/r4062599-garbage_disposal_clogged_or_jammed
http://www.fixya.com/support/r4062792-best_way_use_garbage_disposal
on Feb 06, 2010 | Kitchen Appliances - Others
Dishwasher smells like a dirty auto repair shop
Do you have an airgap valve on top of your sink or counter? Some times routed through an exterior wall. Their purpose is to prevent dirty water coming back into the DW and sitting. You can tell by looking under the sink as well. Your DW drain should never go directly to your garbage disposal or peetrap.
Feb 20, 2016 | Dishwashers
Why is there a foul smell in the dishwasher?
You might want to check the drain hose. It should be mounted up, or have a loop that is higher that the garbage-disposal port that it feeds into. If it is not mounted up, or have a high-loop, it is possible that water from the sink and debris from the garbage disposal can backwash into the dishwasher, and that would be the cause of the smell. Alternatively, it is possible that the heater is not working at all, so dishes aren't drying, and the water isn't getting hot enough to kill the bacteria, mold, and mildew that can form if the water isn't getting heated during the wash cycle.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 14, 2014 | Dishwashers
How do we remove the horrible smell in our Bosch dishwasher?
First check out your model to see if it has a built in garbage disposal, if so, make sure it is not mucked up.
Run hot water down your sink drain while running the sinks garbage disposal. Pour baking soda down your sink garbage disposal followed by white vinegar. Let it sit and foam. Run hot water down sink disposer while running. When finished:
Run empty dishwasher with no soap, let dishwasher fill with hot water to wash and then pour 1 cup of white vinegar into the bottom and resume wash. Make sure you take it through the dry cycle. When finished, open dishwasher and let it air for a couple of hours, longer if you live in humid area. Hope these steps do the trick.
Aug 03, 2014 | Bosch Dishwashers
Shx46a05uc
Likely your drain hose goes into your garbage disposer and does not have a rise before it enters the disposer. You will get backwash from your disposer falling back into your dw causing the odor. Simple fix is to make sure the drain hose travels upward a couple inches as it comes out of the disposer. Thanks
Jul 28, 2014 | Bosch Dishwashers
My bosch dishwasher has a terrible from day one. I have tried running vinegar through a wash cycle. My dealer I need to run it a few times. I have had this machine for well over a year and still gives...
Hello and welcome to Fixya.
It "smells" ( just kidding ) like you might have a problem with the way your drain hose is connected by your description.
It is crucial that your Bosch dishwasher have a siphon break or "hi-loop" installed in the drainage between the dishwasher and where it enter's your homes plumbing.
If it does not you can try different cleaners until the cows come home with little effect because the odor is coming from the drain line itself.
Was this unit installed by yourself or someone you know ? Or was it installed by a plumber/professional installer.
In the end it actually makes little difference, I'm just curious. I see professional installers as well as plumbers fail to include this crucial feature over and over.
Let me know. I'll watch for your post. If you are unclear as to what I'm referring to, check your installation guide that comes with all Bosch dishwasher's.
If you do not have any instructions regarding the proper drain/install I can email you a copy, but I would need your email address.
Good luck.
macmarkus :)
Jun 17, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Our jenn-Air built in dishwasher smells foul and has since the first time we used it 4 months ago. we have tried bleach, vinegar, finish brand dishwaher cleaner, less soap, cascade soap, running every day,...
We had similar type of problem (as well as residual water always left in bottom) and after pulling out the dishwasher, found that the drainage tube was incorrectly installed by contractor. It was laying on the floor behind it with a only a slight rise to the garbage disposal inlet. I suspect this contributed to sewer odors as well a water back flowing into the dishwasher. I disconnected drainage tube so that it went up 24+" and then connected to garbage disposal (creates a loop that blocks sewer odors and back flow conditions). I also cleared out the filter at bottom of inside the dishwasher. The Use & Care Guide suggested using baking soda in China/Crystal mode for 10 minutes, opening the front door and letting it sit overnight. I repeated that for 3 nights and it did clear up the remaining odor. Don't know if this will help your issue or not. Good luck!
Jan 09, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Bad smell
It sounds like your dishwasher does not have an air gap. Newer dishwashers come with an air gap installed, but they can be taken out. A quick fix for this is to:
Check the drain line under the kitchen sink. The drain line is supposed to run from the bottom of the cabinet, and run as high in the cabinet as you can get, (up to the bottom of the counter top) then connect the drain. This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher, and garbage disposal.
Please rate this solution.
May 18, 2007 | Bosch 24 in. SHU6802UC / SHU6806UC...
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
406 people viewed this question
Top Bosch Dishwashers Experts
shaun taylor
Carmen Mikulic
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
