Question about Jet 710115K Jwbs 14CS Deluxe 14 Inch 1 1/4 Horsepower Woodworking Bandsaw With Micro Adjustable Blade Guides, 115/230 Volt 1 Phase
Jet model jwbs-14cs bandsaw purchased used, need manual
I just purchased a sweet Jet 14" bandsaw. The plate on it identifies it as a Jet Gold Series Model JWBS - 14CS.
Can anyone point me to an owner's manual for this???
Thanks!
  • bkryzer Dec 29, 2008
    Thanks!
    I'm going to "Craigs List" my request. I'm sure one of my band saw brothers (or sisters) can help me out.
Http://www.cpojettools.com/products/708115k.html
Scroll down and click the "Manuals" tab. Your free PDF awaits...
Posted on Aug 10, 2009
    President:
  • 2,692 Answers
Here is the company webpage for your product. No download area that I found. May have to write to them.
http://www.cpojettools.com/search/20080825144306/index.php/search?terms=+710115K+&submit_x=18&submit_y=8&submit=Search
Posted on Dec 29, 2008
I need to find the size and length of a powermatic bandsaw blade. Model PWBS-14
93.5 inches
Do you not have internet? I found the specs for your model instantly on Powermatic's web site. Don't be so lazy!!
Feb 27, 2015 | Powermatic 14" Bandsaw Model PWBS-14CS
How do i adjust a jet bandsaw jwbs-9 blade tension
You should check your manual. There's a blade tension handle on my bandsaw, which is adjusted every time I need to change tension or change blade. There ways how to check the correct tension, you can pluck the blade like a string on a guitar and if you hear music not like sound, tension is good. Or you can follow the suggestion blade tension on your saw. or you may also use tension gauge.
Jul 19, 2014 | Jet Saws
Upper wheel keeps touching case
Adjust the upper wheel. Refer to your manual for procedures.
Apr 21, 2014 | Jet 708115K / JWBS - 14CS 14'' Bandsaw...
Replace guide bearings on jwbs-18 saw
" That one will be a press fit onto that eccentric shaft. Small bearings like that are easy to drive off with a suitable punch or mandrel. Simply stand it up in the jaws of a vise so the jaw edges contact the outer rim of the bearing and use a hammer to drive it out. Put a washer or similar bit of metal between the shaft end and the punch to protect the face."
Make sure before you put the new bearing on that the shaft is clean and smooth.
Nov 07, 2013 | Jet Machinery Jet Equipment 708750B...
Tire comes off wheel
Are you using new tires? Urethane or rubber? Make sure the adjustment are correct or probably you need to replace the
tires. I am using ulta blue urethane tires because it lasts longer and it doesn't need gluing. Urethanes are more durable
than rubber. I got mine on http://bandsawparts.com/ultra_blue_urethane_tires.cfm .
Jan 31, 2013 | Jet 710115K Jwbs 14CS Deluxe 14 Inch 1 1/4...
I am looking for a Jet 1$" manual. Model
Hi Dean,
The manual is available here:
http://www.retrevo.com/support/Jet-JWBS-14CS-manual/id/23013ci556/t/2/
Click on the red download button.
You just need to enter an e-mail address on the download page for them to send you junk mail !
Hope this helps !
May 07, 2011 | Jet 710115K Jwbs 14CS Deluxe 14 Inch 1 1/4...
I have a Jet 14" closed base band saw. I've been fighting to reduce upper housing vibration. The wheels are balanced and the pulleys are aligned. I've also replaced the standard belt with a linked belt. ...
If nothing is loose, and the blade tension is high enough, you might want to hang a couple of pounds of wieght on a stiff spring on it. It will be trial and error, but I would start with about 3 lbs and a spring about like a screen door spring or stiffer. Where to hang it from is a guess too.
Jan 11, 2010 | Jet 708115K / JWBS - 14CS 14'' Bandsaw...
Top wheel part broke off
I suspect the part you need is 150086 "Upper Wheel Shaft". You can confirm this by checking the exploded diagram for your bandsaw which can be downloaded at http://content.wmhtoolgroup.com/manuals/708115K_man.pdf.
See page 25 for exploded diagram showing wheel shafts, bearings, etc..
It might be worth checking with JET about warranty since I believe that band saw has a 5 year warranty. You can check here for a service center near you.
Jan 10, 2010 | Jet 710115K Jwbs 14CS Deluxe 14 Inch 1 1/4...
Jet 710115K Jwbs 14CS Deluxe 14 Inch 1 1/4 Horsepower Woodworking Bandsaw With Micro Adjustable Blade Guides, 115/230 Volt 1 Phase Logo
1,141 people viewed this question
Top Jet Saws Experts
Marvin
Marvin
woodzowl307
ray gallant
Are you a Jet Saw Expert? Answer questions, earn points and help others
