Question about Aspire Acer 7520-5324 Laptop
Acer aspire 5110 keyboard and touchpad not working locked in bios
I got aspire 5110 beck from service with new xp and put it to update on internet....then after one reset....on log in ther was a mesage "genuine windows ilegal abuse something" and my keyboard and touchpad not working from startup, so i cant enter in bios or get in windows on log in...please help
  • 1 more comment
  • mirzatabak Dec 28, 2008
    yes I have but I cant instal windows becouse keyboard and touch pad does not work
    I have to unpluged hdd and pluged in fast to trick windows on boot from cd...and blue screen instalig drivers....and then pres enter to continue F3 to quit and one more option before F8 to configure your partition for instaling windows, but my keyboard do not work and I am stuck with first blue screen with options...
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Do you have a Windows XP disc you could use to boot from?
Touchpad, mouse and keyboard not working
Try installing the touchpad driver from here http://www.helpjet.net/files-Acer-Aspire-4810T.html#ATouchpad
Once you are done restart your Acer and see what happens.
If this doesnt resolve the issue it may be a problem with the hardware in which case you may need a new touchpad. otherwise just use a mouse as a fix either temporarily or if it turns out to be to expensive to fix.
Aug 17, 2014 | Acer Aspire 3810T 4810T 5810T
My acer aspire 5542g keyboard is locked, how do i unlock it?
Try using Fn + F7. It turns the touchpad on and off.
Another solution is maybe CMOS or BIOS has locked the keyboard and touchpad and that maybe resetting the CMOS/BIOS by jumper or removing the battery will unlock them.
Nov 16, 2010 | Computers & Internet
Acer Aspire 5100-USB, Touchpad, keyboard all quit working.
Bad motherboard or a failed attempt at a bios upgrade/flash
Jul 21, 2009 | Acer Aspire 5100 Notebook
Keyboard not working
try to update your machine's bios and re-install your keyboard driver and touchpad.
Jun 30, 2009 | Acer Aspire 5100-5022 Notebook
Acer Extesa 6601 Keypad & Touchpad Problem
you need the drivers for the touchpad and keyboard, click on the drivers and utilities section, then allow active x when the pop up appears
http://support.acer-euro.com/drivers/notebook/ex_6600.html
Aug 23, 2008 | Acer Aspire 5100-5022 Notebook
Keyboard + toucpad freezes
Might seem ovious but you may want to try Acer support and look for a new Driver.. Also check under Control Panel...Mouse options... and also check device profiles to make sure windows isn't loading a "docked profile which may disable touchpad and laptop keybaord use.
Feb 21, 2008 | Acer Aspire 5670 Notebook
Acer Aspire 3004 keyboard and touchpad error
Just resolved same problem on Acer Aspire 5000 by removing the battery, then goto device manager and disable "Microsoft ACPI-Compliant Control Method Battery" you can then put your existing battery back into the latop with any problems with the keyboard and touchpad. Mad solution I know but it worked for me
Jan 22, 2008 | Acer Aspire 3000 Notebook
Keyboard locked during bootup
My Acer aspire 3003 keyboard and touchpad both started to lock up recently. I use it with the battery removed, it avoids the problem. The battery wasn't holding much charge anyway.
Jan 20, 2008 | Acer Aspire 5100 Notebook
Keyboard/touchpad freezes when the battery is plugged!!
I SOLVE THIS ISSUE 100% WORKING
THE MAIN PROBLEM IS ON THE CONTACT BETWEEN THE BATTERY WIRES AND LAPTOP
IF YOU MOVE THE BATTERY IT WILL WORK SO SURE THE PROBLEM WITH THE LINK BETWEEN THE BATTERY AND THE LAPTOP
SOLUTION : TO MOVE THE IRON OUT OF THE LAPTOP TO THE RIGHT TILT THEM TO RIGHT SIDE A LITTLE BECAUSE THE BATTERY WIRES IS TO THE RIGHT SIDE (WATCH THEM) NOT IN THE MIDDLE AND AFTER THAT PUT A STICK ON THE BATTERY TIGHTED IN ITS PLACE SO IT WILL NOT MOVE ITS NOT FREEZING NOW THANKS
Dec 21, 2007 | Acer Aspire 5100 Notebook
Aspire Acer 7520-5324 Laptop Logo
1,194 people viewed this question
Top Aspire Computers & Internet Experts
pankaj rautela
pankaj rautela
Jax Planet
Jax Planet
EKASYS IT SERVICES
EKASYS IT SERVICES
Are you an Aspire Computer and Internet Expert? Answer questions, earn points and help others
