Question about Nintendo Wii Console
No picture when connecting wii to mitsubishi TV
I am unable to get a picture, but the sound works, when I try to connect a Wii to my 65 in rear projection Mitsubishi TV. I have tried all possible input slots with no success.
  • 6 more comments
  • mlanctot1 Dec 28, 2008
    Yes I have tried another TV and the Wii does work on other TVs.
  • mlanctot1 Dec 29, 2008
    I have tried hooking my Wii to another tv and it does work but I am still having the issue with my Mitsubishi big screen.
    I am still not able to get a picture when I connect mhy Wii game console to my Mitsubishi tv.
    It has never worked
  • mlanctot1 Jan 03, 2009
    I have fixed my problem without the help of this website and their "expert team." What a waste of my time and money.
  • mlanctot1 Jan 06, 2009
    Like I said before what a waste of time and money
    These guys do not have a clue
    The issue was with the TV itself. The signal PCB is the problem. Unfortunately the board is no longer made by Mitsubishi so they offered to build me one. It would cost over $700 to fix so I decided to buy a new TV and give this one to my son who doesn't care if the analog inputs do not work. I guess that I am sorry for some of the things that I posted but over a period of more than 2 days all I recieved was two questions that were so basic in nature I found them and the process useless. Mike
  • 505 Answers
You probably have a fluid leak on the signal board. This is very common in Mits projections and can sometimes be cleaned up and fixed with no $. The fluid is toxic so use gloves.. anyways.. look inside with a bright flashlight on the signal board. You may find a drop of clear or green fluid there. I use rubbing alcohol to clean it up and works sometimes if you get lucky.. Like i said its toxic so wash up afterwards. Also good to put in some sort of drip shield.
As far as troubleshooting if not a fluid leak, the SD and HD resolutions will go through different processing and will help troubleshoot. In my experience, no video is maybe 90% terminal board or doubler (2hdw) module and 10% signal board, so there likely still hope for your tv. I can help troubleshoot further down to the exact board if you wish to procede.
Posted on Jan 06, 2009
    Sergeant:
    Champion:
  • 201 Answers
I would like to ask you, what was the actual solution was it a ntc pal setting or AV setting? Don't worry you will get your money back sorry for the disappointment
Jonathan
Posted on Jan 03, 2009
  • 470 Answers
The problem on it is the format of your video,, the audio is accessable but the video is not, i conclude the video file is not supported, the solution is convert the video into MPEG-4 format,, convert it into the video converter, im sure it will work.!!!
  • Antonio Buenafe Jr.
    Antonio Buenafe Jr. Jan 09, 2009
    hmm so did not find any of our solution my dear?? don't wary,, we try to research about that problem, because, we are not 100% accurate, hope you understand, but you can get a refund of us
    Antonio Buenafe Jr. Jan 18, 2009
    search the PCB circuit diagram,, there is a possible problem on it
  • 818 Answers
He most you can squeeze out of the Wii is 480p (PAL/NTSC), 480i (NTSC) or 576i (PAL/SECAM), standard 4:3 and 16:9 anamorphic widescreen. This means that you cannot expect 1080p out of it.
The console supports progressive-scan output in 480p enabled Game Cube games, so there won't be any improvements beyond this.
As far as the graphics go, the Wii is said to be slightly more capable than the original Xbox, but bear in mind that it is defined by it's control setup more that it's graphics; the control scheme is perfect for pick-up-and-play, which can make the console great in parties. It is also home for amazingly polished first party games, such as Super Mario Galaxy and in the near future Smash Bros.
If you have an interest in playing games with your whole family (from the young to the elderly), add a little more laughs to your parties, or to indulge in the occasional gourmet game, you certainly can't go wrong with a Wii.
: http://en.wikipedia.org/wiki/Wii#Technical_specifications
  • 15,935 Answers
Have you selected the Input on the actual TV? (ie. Input 1, Input 2 etc.) How about another device... such as a dvd or different game console. Same results? Bad Decoder board. Seek a professional to repair.
Posted on Dec 29, 2008
  • 2 more comments
  • blueextc3221
    blueextc3221 Jan 03, 2009
    FixYa offers a monyback guarantee.
    If you are not satisfied with the solutions.
    Hope you're enjoying your Wii.
    Regards!
  • blueextc3221
    Fixya has a 100% money back guarantee. Just write an email to premium.support@fixya.com
  • blueextc3221
    Troubleshooting (especially electrical) without having the components in front of you is nearly impossible. We can give you suggestions on what to look for, or tips that you may not have thought of. However posing a broad question without model specifics can be much more difficult. Imagine a question like "I was driving down the street and my car died. How can I fix it?"
    This could be one of 1000 possibilities. Sometimes additional questions and answers are needed. We do not know what common solutions you have already tried. With the use of the comment button, there can be a positive interaction between the asker and the FixYa team.
  • blueextc3221
    blueextc3221 Jan 06, 2009
    Sorry we could not be of more help. If you are any good with electronics, a replacement (used) may be a way to replace the board without a huge expense. Im sure we could help you with that.
    Let us know.
    Good Luck
  • 837 Answers
Has it ever worked with the Mitsubishi and now it has stopped working?
  • Jay Glendenning
    Jay Glendenning Dec 30, 2008
    What is the actual model of the tv?
  • Jay Glendenning
    Jay Glendenning Jan 06, 2009
    And as experts we often ask question(s) of the customer and they do not get answered so we cannot always adequately answer and correct your problem.
    Our responses are only as good as the info you give us and how well you answer our questions in return.
    Thanks for using FixYa
    Genius:
  • 1,199 Answers
Did you try another tv to rule out a problem with the wii
Posted on Dec 28, 2008
We are trying to set up wii-through the dvr to play on Sharp LC-PD50U-unable to get it to work.
Connect the Wii directly to the TV either using the HDMI cable or the Hi def cable(5 RCA connectors) that come with the Wii. Then select the input number on the TV to get a picture .
Dec 25, 2012 | Sharp Aquos LC-PD50U 50 in. Plasma...
Video games projection on a Mitsubishi WS-65869
1,2 error code means NO ERROR FOUND. The set is older and may not be compatible with this set---what type of connection is being used and to which rear input?
Dec 16, 2012 | Mitsubishi WS-65869 65" Rear Projection...
I have direct tv and I am trying to hook my wii up so I can watch netflix it is giving me an error 51420
Error Code: 51420
The Wii console is not able to connect to your wired router or modem.
1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
2. Select "Wii Settings".
3. Click the left arrow to get to Wii System Settings 3
4. Choose "Wii System Update"
5. Choose "Yes" to connect to the internet and perform a Wii system update.
2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
6. If possible, try another Wii LAN Adapter. If you are unable to try another Wii LAN Adapter, or are still receiving this error code, please call 1-800-255-3700 for assistance.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51420&system=Wii&locale=en_US
Apr 01, 2011 | Nintendo Wii Console
I am trying to hook my wii to the internet and it is saying unable to connect error code 51420 and i need free advice or help.
For any help click here
Jan 04, 2011 | Nintendo Video Game Consoles & Games
We have sound but no picture on our Wii
Connect a DVD player using red white and yellow to the TV if you get picture and sound, then reconnect the wii red, white, and yellow to the same input.
If only the wii does not show video you will need new red white, and yellow cables. I would try a friends red, white, and yellow cables first even to their TV where their wii is already working.
If new cables are not working you will need to contact Nintendo as there is an issue with your wii. You can't change the wii video to progressive without a component kit, and since you have yellow you obviously don't have a component cable for the wii.
May 15, 2010 | Nintendo Wii Console
No picture from wii
The RX-V800 switches the various video signal types separately.
Since you are feeding S-Video to the TV the composite (yellow) input from your Wii is not going anywhere.
If you cant get S-Video output from the Wii then I'd suggest a simple Composite to S-video adaptor plug ($5 say). It worked for me with a Game Cube.
Cheers
BJ
Mar 19, 2009 | Yamaha RX-V800 Receiver
No Picture after Wii Play: 65'' Mitsubishi HDTV 1080 (WS-65511)
mmm try this.... do u guys have the yellow white red cables hooked up to the front of the tv from the wii console? try loosening them up. worked for me. let's see how long it lasts .... !!!!
Dec 27, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Connected the Wii to new Panasonic 42 in plasma. Had been working fine on Sony Vega 27 in. Now picture quality is terrible and there is no sound. Checked all TV and Wii settings and unable to fix it.
That's probably down to the AV cable. Have you tried it on another TV to eliminate the TV?How are you connecting? Component or Scart adapter? Tried swapping from one to the other to eliminate any possible issues?
Nov 23, 2008 | Televison & Video
Nintendo Wii Console Logo
59 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
