Question about HP P5750-69001 - System Board/P4 Motherboard
The PC doesn't work
I have a HP Vectra VL420 P5761. My problem is described like this: When a i want to turn in the computer it's not start. i just hear a beep. I had changed the power supply, ram memory and the battery. Also I'd changed the coonfiguration on the dip switch to recover the BIOS, but again, this action failed. I don't know what can i do, please give me some ideas to recover my PC. Thanks
  • 1 more comment
  • Carlos Chequer Apr 25, 2007
    Hello sandrew's!
    I'd reviewed you solution but i can't fix the problem. So I like to send you a sound file with the beeps that i described previously. In order to do that, i need your e-mail address, or tell if there are another way to give that sound file. Thanks
    Hello sandrew's!
    I'd reviewed your solutions but i can't fix the problem. So I like to send you a sound file with the beeps that i described previously. In order to do that, i need your e-mail address, or tell me if there are another way to give you that sound file. Thanks
  • rayven2929 Nov 03, 2007
    Hi , i have the same problem .... i change my power supply because the machine was not powering at all , no i have a sound of a fax.... kind of , and then i bip , can you help me with that ? the machine was working fine before ....
    thx
    Rayven2929@hotmail.com
  • 25 Answers
I know this is about a year later but I just had the same problem too last night.
When you turn on the PC it plays this crazy tone music right? If so, listen to it then at the end you will hear a couple of beeps. In my case my system beep twice at the end. 2 beeps for me indicated Power supply was in protected mode. Luckly I had a spare P4 PS laying around which solved the problem.
If you have different beep code google up "HP Vectra VL420 Beep Code". Standard beep code doesn't apply to this mobo since the BIOS is customized.
My power supply was a standard P4 ATX... no special design from HP you should be able to get one at any computer store. Beware just don't the cheapest one it cuz they aren't build to last and aren't reliable. Trust me I've seen too many people buying cheap power supplies and having them kill their mobo's.
Posted on Aug 15, 2008
If your PC beeps 3 times, It could be bad RAM or A Bad Video Card...
IF PC comes up and starts to do POST or trying to Boot-up, and then you hear hard drive clicks (like its parking the read head)and PC shuts down -- Check to make sure CPU is being cooled down sufficiently (always USE CPU thermal paste or Gel).
I have had 2 power supplies go out in my HP VL420 MT desktop, I finally installed a heftier Power Supply. I found a compatible power supply at Office Depot (I'm sure Staples,or Circuit City carry the same one).It's a
Antec® Basiq™ BP350 350-Watt ATX12V Power Supply It had the correct dimensions and voltage outputs, But with more Wattage capability.
Posted on Dec 07, 2007
    President:
  • 2,961 Answers
If it's just one short beep, then that is a memory check to say ok, but a second beep is normally heard which can indicate the graphics are ok, so check in the bios that your agp graphics card is set to primary graphics controller, if you have one fitted, or if onboard, check that on board is set at primary if not. If you know your graphics are correct, make sure that time and date is set correctly and there are no faulty drives that the bios is unable to identify. If it is a continuous beep then a motherboard or processor failure is indicated.
Posted on Apr 24, 2007
SOURCE:
Hp Vectra 6VL will only start in safe mode
Run the computer in safe mode and then go and shut down unnecessary startup programs, then restart the PC.
Dec 23, 2012 | HP Vectra VL420 PC Desktop
Cannot display on monitor
If your PC gives single normal beep while booting then try connecting your monitor to another working PC. If it doesn't display then check the VGA cable by replacing it with new one. If the beep is not normal then tell us the beep behaviour.
Nov 30, 2011 | HP Vectra VL420 Desktop PC - Intel Pentium...
Salve vorrei i driver aggiornati per il mio Vectra VL420 hp
you can download drivers on this page
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=45011&lang=en&cc=us&prodTypeId=12454&prodSeriesId=45010&taskId=135
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 08, 2011 | HP Vectra VL420 PC Desktop
I cannot find the driver on "Motherboard HP P5750-69 001"
If you Know the Model of this motherboard is in. and search the Driver for it , i guess the PC model is HP Vectra VL420 . if this is right, then click HP vectra driver Download Link try downloading the older version of windows like " windows 2000 or wndows XP. ther is no driver for windows xp proffesionl etc. best of luck
Feb 03, 2011 | HP P5750-69001 - System Board/P4...
I just got this Vectra VL420 from a surplus store. I try to start up I get this funny music and then two beeps. I understand two beeps indicate power problems. But not sure what to do to rectify this....
From memory I would say you are in the right ball park.
I remember now. Error 2 means the power supply is in protect mode.
First check the wiring going to the Motherboard from the PSU. There is a four pin connector that lets the PSU know if all is well with the main board. If that is not connected, that may cause your problem
Try a new PSU. They are fairly cheap. Match the power on the specification panel stuck to the PSU.
If those don't fix it, a new motherboard is the next step.
Hope this helps.
Nov 22, 2010 | HP Vectra VL420 PC Desktop
Computer seens to be on (noisy) but no power button light
Might be youe Power Button LED is faulty or not connected with in in the motherboard.If system getting noisy then might be any wire is touching with CPU Fan .IF its given a beep sound with a interval of time then first re-insert the RAM chip .if still issue then replace RAM with goods one .If still facing same issue then re-connect keyboard & Mouse again.if still issue then Problem with Motherboard.its faulty.
Nov 20, 2009 | HP Vectra VL420 PC Desktop
Hewlett packard vectra vl420 mt 3 melodies music 3 beep
sometime pc no give any error but there is problem.such as monitor,power problem and many more.
Jun 24, 2009 | HP Vectra VL420 PC Desktop
Beeps 2 times & a warbling noise when trying to boot up - unplugging power lead & pressing ON/Off button & reconnecting power lead starts up OK - but it can be OK for several days & th
By warble, do you mean a high pitch non stop noise? If so... I think I went through that bout 2 months ago, it was a easy fix. Ifr it is the same problem
May 29, 2009 | HP Vectra VL420 Intel Desktop PC - Intel...
Beeps 2 times & a warbling noise when trying to boot up - unplugging power lead & pressing ON/Off button & reconnecting power lead starts up OK - but it can be OK for several days & then repeats the p
The Cause of Problem:
The Power Buttons electrical circle sometimes just braked it by one of sensors and the result is the 2 beeps and Power Supply is in protected mode error.
The whole computer is turn off but the power button is turn on and this is the nub of the matter. Because if you want turn on the computer you can't because already turn on but just the Power button and you can't do anything.
The solution:
You need just change the Power Supply and don't do anything just the power cable put into the Power Supply after turn off computer.
Finaly change back the Power Supply.
Apr 25, 2009 | HP Vectra VL420 Intel Desktop PC - Intel...
I have the problem when reinstalling the processor
Trying to reinstall the processor with the heat sink still attached is not a good idea--as pins can very easily be damaged.
You will have to pry the processor from the heat sink. Use a small screwdriver, but do it gently--all around the edges. You can also make it a little easier by getting a hair dryer and heat the whole thing up before trying.
Don't worry about damaging it with the hot air. It runs at a higher temp than a hair dryer.
Apr 18, 2009 | HP Vectra VL420 PC Desktop
HP P5750-69001 - System Board/P4 Motherboard Logo
505 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
