Question about E-Machines T6524 PC Desktop
T6524 Desktop will not come on
When I turn on the pc all it does is beep. The screen will not light
Help please
  • co_shoppingm Dec 28, 2008
    I have done all of the above. It tried to come on and I have a notice Audit something it clicked off too soon
  • Anonymous Jan 12, 2009
    Help The computer keeps beeping and nothing else happens.
    Scholar:
  • 62 Answers
That could actually be tons of different things.
The first thing you want to start with is make sure that the cable from the computer to the monitor is plugged in.
After that, you want to make sure that the monitor is good. Try using either a different computer with that monitor or a different monitor with that computer.
If that doesn't fix it, let me know and we'll go from there.
Posted on Dec 28, 2008
  • Simon Downey
    Simon Downey Dec 28, 2008
    What operating system are you using?
    If it's Vista, you can pop your disk in, boot from it and it can fix your pc in a few guided steps.
Emachines T6524 will not reboot, get no signal message on monitor
shut down your computer and remove the side cover and remove the memory from the slot and switch on the computer if you hear beeps switch down the computer and insert the memory if you still hear beeps means the tre is an memory failure you need to change the memory while removing memory you didnt hear any beep it means there is problem with your motherboard remove the processor heat sink and the processor clean the surface then insert the processor to the slot apply a thin level of heatsink compound and fix the heat sink then switch on the computer
Dec 29, 2011 | E-Machines eMachines Desktop PC
My T6524 PC will not shut down when I hit the button.
Please check following KB article:
Advanced troubleshooting for shutdown problems in Windows XP
http://support.microsoft.com/kb/308029
Sep 13, 2011 | eMachines T6524 PC Desktop
"NTLDR IS COMPRESSED PRESS CTRL+ALT+DEL TO
Repair PC
press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
Feb 22, 2011 | eMachines T6524 PC Desktop
Want to restore os and start over. Emachine t6524
Have you tried System Restore? Restart your computer and watch for the screen to give you instructions at the bottom. It will say something like: F1 = Boot Menu F10=System Restore
It should walk you through a factory restore, which means it will take it back to factory settings the same as when it was perchased.
Feb 04, 2011 | E-Machines T6524 PC Desktop
Have an e machine t6524 that was rebooting itself now it won't boot up at all. Keeps beeping
Hardware fault. Simple test: if you can boot in the BIOS then the hard disk has died - replace it and reinstall. If you can't the the motherboard has failed - in the end it will be easier and cheaper just to get a new pc.
Oct 11, 2010 | eMachines T6524 PC Desktop
The motherboard is a MSI MS-7184 in a emachine model t6524 and what is happening is when you turn on the computer, it starts and the lights on the keyboard light up and shut off, then it brings you to the...
Hello
Try f2,then let the screen come up.This is your bios settings,dont change anything.
Next hit the esc key,answer yes or y key.Pc should reboot normally.
If this doesnt work hit the f10 key and select your hdd or hard drive in the options,and reboot.
Apr 29, 2010 | eMachines T6524 PC Desktop
MY T6524, will not start I press the button and the hard drive light goes red then nothing comes on the monitor
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Nov 19, 2009 | E-Machines T6524 PC Desktop
I ahve an emachine T6524 and when you start it up the hard drive light comes on yellow and the cpu keeps beeping. It never seems to boot up. Nothing appears on the screen
hello...the exact problem on the CPU/unit is Memory so you need to try clean the memory or try to replace a new memory...Thanks and Good Luck...
May 09, 2009 | E-Machines T6524 PC Desktop
6 beeps at start up
Sounds like a processor or cpu failure.
Beep Codes
Please vote if you found this information useful.
Thank You
Apr 18, 2008 | Dell Dimension 4300 PC Desktop
E-Machines T6524 PC Desktop Logo
81 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
