Question about Nikon Coolpix 4500 Digital Camera
I have a Nikon coolpix L4 camera and it will not work. I get an error message " memory card is write protected" can you assist?
  • Anonymous Mar 26, 2009
    no i have the same prolem. flipping the yellow switch doesnt work. i cant format it from the camera and i cant from the camera either
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Mar 09, 2010
Hello there, I have a Nikon Coolpix L4, and I'm trying to use a 4GB memory card in it that was most recently used in a Canon digital camera. I'm getting the error that "this card cannot be...
Sorry to tell you, but your older camera will not work with 4GB or higher SDHC cards. Your camera was designed before SDHC format came out. You'll need to use 2GB or less standard SD cards. These are relatively inexpensive these days, and are easily found on Amazon, just in case your local store no longer carries them. For others reading, there are several other possible causes for memory card problems, with troubleshooting steps that may be viewed here.
Jul 09, 2011 | Nikon COOLPIX L4 Digital Camera
A message always shows "MEMORY CARD IS WRITE
If you take out the memory card and look at it... it has a little button on the side... slide it over.... and then slap it back in the camera and that should take care of the problem.
You can also get the memory card locked/protected message if you are trying to use a SDHC card in a camera that does not support High Capacity (HC). High Capacity is any SD card with over 2GB of memory space.
Hope this helps.
Apr 26, 2011 | Nikon COOLPIX L4 Digital Camera
I have a problem with my memory card which supplied with nikon coolpix l4 and its is 512MB.now 512mb is not available so could i replace it with 2GB memory card.also let me know that 2GB card will support...
The L4 and its software will work with any size SD cards. Make sure you get SD cards, not SDHC cards. SD cards go up to 2GB, while SDHC cards start at 4GB and go up.
Jan 28, 2011 | Nikon COOLPIX L4 Digital Camera
Cannot get write protection off my memory card for my Nikkon Coolpix L4
Oct 04, 2010 | Nikon Coolpix 4500 Digital Camera
My camera says memory card is write protected and I can't get it off to take pictures?
Take a look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 28, 2010 | Nikon COOLPIX L4 Digital Camera
Memory card is write protected
On the side edge of the card, there is a TINY switch. Unlock the switch and the card will no longer be write protected.
May 07, 2010 | Nikon COOLPIX L4 Digital Camera
Nikon Camera does not accept any memory card
Try formatting the card in the camera, not the computer.
Apr 14, 2009 | Nikon COOLPIX L4 Digital Camera
Regarding starting on the camera
This camera is now ten years old, and will only take an SD card, with a max limit of 2GB. It cannot recognise or use a more modern SDHC card, which is what I suspect you have been trying to use.
Sep 23, 2017 | Nikon COOLPIX L4 Digital Camera
Nikon Coolpix L4 Memory card problem
Back up all the pictures on the card and then format the card.. Everything will be back to normal.
Note: While formatting select FAT32 file system as it is more reliable..
Jun 18, 2008 | Nikon COOLPIX L4 Digital Camera
Memory card malfunction
Pictures can sometimes be recovered by sending the card to a service provider, or by downloading software designed to recover the pictures from the card. It is not clear weather the problem is the card or the camera, however to recover the pictures from the card would be the same process. If you do not have one you will need to buy a USB card reader to load the card on the computer. Consider buying another card to test in the camera, if you so wish. If the camera is new enough also consider contacting the manufacturer for warranty assistance. David Millier Advance Camera Repair
Feb 26, 2007 | Nikon COOLPIX L4 Digital Camera
Nikon Coolpix 4500 Digital Camera Logo
108 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
