Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Sony kdf-55e2000 tv keeps shutting off
I turn on my tv and within 30seconds to a minute it will shut off...the light on the front will flash red...does anyone have any idea what the problem may be ?
  • 1 more comment
  • Letonya Streety Dec 29, 2008
    I have a rca 52 inch tv and I will cut the tv on and within two minutes, the green light on the tv will start blinking. After the light blinks on the tv it will shut off. It will stay off for a few minutes then it will cut back on by itself. Then it will start the whole process over and over again. Why does it keep cutting on and off by itself over and over again?
    Yes, I have the same problem except my tv just keep turning on and off by
    itself constantly. until I will just unplug it from the wall. Can someone
    help me with this problem.
  • kennygratts Feb 23, 2009
    KDF-55E2000
    TV keeps shutting off, red light on power display blinks 3 times.
  • 1694 Answers
SOURCE: TV keeps shutting off
javine25,
Please provide make,model,chassis.and age info off back off set,
then I can advise you...............T.
cpor92, are you still needing help??
Posted on Nov 27, 2007
  • 1694 Answers
SOURCE: RCA TV
Solder bad connections...main board with hv transformer on it..
CL035 capacitor and any others...use magnifier........T.
Posted on Dec 02, 2007
  • 51 Answers
SOURCE: Sony Grand WEGA KDF-55E2000
in this set 3 blinks means lamp cover not set properly but i think that your problem is your 6x red blinks that means you have a problem in the audio section in your set(missing a voltage) or a themal fuse open.
Posted on Jul 10, 2008
mistersony
  • 320 Answers
SOURCE: Sony Wega KDF-55E2000 won't turn on
A 5 blink code is a lamp power supply problem, but I would try a new lamp. I'd say about 90% of the time that fixes the problem.Get an ORIGINAL Sony lamp as the aftermarket replacements are ****. If you replace the lamp and still have the problem, you will need to have the lamp power supply/lamp ballast replaced
Posted on Oct 19, 2008
SOURCE: My Polaroid 42 Inch LCD Keeps shutting off.
This might sound a little crazy but, i had the same problem with my rca 50 inch, and he changed the bulb. which are pretty $$$$$125.00 at my tv repair person cost. the real cast was $219.00.Hope this helps you
Posted on Dec 05, 2008
Shuts off and on while trying to watch, the power light flashes 30 times when off then the tv comes back on again
Power supply trouble. The TV keeps trying to start then operates for 2 seconds and shuts down. The cycle keeps repeating until eventually the TV will not start at all.
Nov 27, 2013 | Sony KDF-60X5955
Sony KDF-55WF655 'rebooting'?
Replace the lamp . p/n XL-2200
Oct 05, 2009 | Sony KDS55A2000 55" HDTV
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Sony KDF-E50A10 50 in. HDTV stays on for 25 - 30 minutes then shuts off by itself power stand by light flashes green and turns back on in about 20 seconds by itself. can you help?
Hi, Lamp of TV getting weaker and requires replacement. This shut off by itself will increase day by day until you put new lamp in TV. Always Buy Sony original lamp and avoid aftermarket/ cheap lamp for TV safety.
Jun 09, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10 Shuts off and on every 1- 2 mintues
From what it seems in your question... the problem has already went away... However, I actually know about this. There is a fuse inside the tv near the power button called B-3a... If you replace that fuse it should help fix permanently
Dec 17, 2017 | Sony Grand WEGA KDF-42WE655 42" Rear...
TV turns on for about 5 minutes then shuts off.
The projection lamp is out and needs to be replaced.
Jan 16, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Oct 19, 2008 | Sony Grand WEGA KDF55E2000 55" Projection...
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
283 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
