Question about Motorola Mobility Universal Bluetooth Wireless Headset H500 Headset
Connecting Motorola H500 blue tooth to Samsung SCH-U410T
Can you tell me if this is possible and can it be done, or do we need a code. My cell phone is a Samsung. and I was given a motorola but no user manual
We live in canada and whatever help you can give us would be appreciated. Do you know if it can even be done,
Thanks Friend
Marlene Valiquette
  • 12 Answers
SOURCE: motorola blue tooth headset
http://www.motorola.com/mdirect/demos/headsets/HS810_HS850_Quick_Start_Guide.pdf
Try that page. It'll show you how to pair it.
Posted on Jan 04, 2008
SOURCE: cell samsung SGH-F250 with bluetooth motorola h500
ACTIVATING THE BLUETOOTH
You must activate the Bluetooth feature of your phone to be able to establish a Bluetooth connection
between your phone and your SuperTooth kit as well as with other Bluetooth devices.
1.
Press Menu > Settings > Bluetooth > Activation > On.
2.
Press Back as many times as needed to return to standby mode.
PAIRING TO THE CELLULAR PHONE (Not possible while charging the SuperTooth)
Pairing will create a link or connection between the two Bluetooth devices - the SuperTooth kit and your phone.
1. Bring the cellular phone at about 20 cm from the SuperTooth.
2. Turn off the SuperTooth and wait for about 4 seconds.
3. While pressing the Answer Button, turn ON the SuperTooth by sliding the Power Switch to the right. Keep the Answer Button pressed for approximately 10 seconds until you hear a distinctive tone and the Bluetooth indicator LED changes from blinking blue to alternately blinking of red and blue. The SuperTooth is now in pairing mode.
4. While the SuperTooth is at pairing mode, access the Bluetooth menu of your phone. Press Menu > Settings > Bluetooth > My devices > Search new device. The phone will then search for pairable devices until it displays them in the list.
5. Highlight SuperTooth then press Select.
6. Enter PIN “0000” then press Ok. (Wait until “Paired with …“ and “Connected” will be shown briefly.)
7. Press Back as many times as needed to return to standby mode. Pairing is successful if the alternating red/blue lights of Bluetooth Indicator stops and then change to plain blinking blue. Normally, the phone would also show briefly on its display if it’s already paired and connected to SuperTooth or if pairing with it failed.
The SuperTooth kit is now ready to use.
Posted on Mar 13, 2009
jazzyboy11
  • 728 Answers
SOURCE: need the code to pair my blue tooth motorola
Try using 0000 as it's the basic code for every bluetooth unless manually change. That is the factory default.
Posted on Dec 31, 2009
casouzaj
  • 1118 Answers
SOURCE: Unable to use new h500 headset
The H500 is a monaural headset, thus good for phone calls only, not for listening to stereo music. You haven't specified which Motorola phone you own. Check in its user guide if it is able to handle stereo bluetooth headsets (i.e. if it bears the A2DP and AVRCP bluetooth profiles), which are suitable for music streams. If your phone is able to handle them, go to the mall (or store, or even online), buy one set which suits you better, pair them with your phone and enjoy!
Just my 2 cents... Carlos
Posted on May 23, 2010
casouzaj
  • 1118 Answers
SOURCE: I got the H500 given to me but not manual to show
Starting with your headset turned off, press and hold the call button for more than 6 seconds, until the indicator light is steadily lit (you'll notice that the light will flash as if the headset was being turned on, but don't release the button at this step). You headset is now in pairing mode. Now, make your phone's bluetooth application search for new devices. After a while, the H500 will appear on the phone screen. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). You just have to pair any two blueotooth enabled devices once. All subsequent connections between them should be achieved by bringing them both within range, with their bluetooth radios turned on. If they fail to do so, a simple press on the headset's call button should suffice to established the link.
Hope it works for you.
Regards, Carlos
Posted on Jun 14, 2010
Can not connect H500 bluetooth with Nokia 2680 slide cell phone. Need Motarola instructions.
Here are the steps to connect your Motorola H500 to your Nokia 2680 phone:
1. Switch off your H500 by pressing the main button for few seconds. 2. Put the H500 in discovery mode. To do this, press and HOLD the main button till it glows a solid blue light (no blinking). 3. Open bluetooth in nokia phone. Go to Menu, settings, Connectivity, Bluetooth. 4. Select "Add a new Device" and search for H500 5. Click on the name select pair. 6. it will ask for pairing code. Enter "0000"
You are done. Revert in case you have any problem
Jun 09, 2011 | Cell Phones
Hello I am trying to hook up a blue tooth to the samsung SCH-U340 but I do not find a blue tooth setting on the phone
The u340 is not bluetooth enabled phone. Thats why you cant find the settings.
"Please leave me a testimonial or feedback if this helped you, thanks"
Oct 27, 2010 | Samsung SCH-u340 Cellular Phone
How do i work bluetooth on a samsung n150
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 25, 2010 | Samsung SCH-n150
May 23, 2010 | Motorola Mobility H500 Wireless Headset
I need a code for the motorola H500
the code is 0000
if that fails try 1234
all blue tooth devices are the same.
if that code fails then there is a problem with the device. Normally these arent repaired its replaced. Warranty will cover a replacement.
Apr 05, 2009 | Motorola Mobility H500 Wireless Headset
Pair motorola H500 to samsung eternity SGH-A867
I have had this problem too. Here is what worked for me.
1) With the Motorola H500 OFF, press and hold the talk key until you see a steady, non-blinking blue light.
2) Keeping that button pressed, turn on the bluetooth on the samsung eternity.
3) It should now find the H500, click on it and select connect.
4) Put in a pass key (I just put in 0000) and your done.
Mar 06, 2009 | Cell Phones
Razr pairing with blue tooth
maybe you need to activate your blue tooth or turn it on in other words. not only that but you should go to your bluetooth profile and see whats going on there
Jun 01, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Ear hook
Contact Motorola and tell them the situation. They will send you new ear hooks. I've done this twice since they don't have replacement parts available publicaly
Mar 16, 2008 | Motorola Mobility H500 Wireless Headset
Hi help plz
What type of phone do you have? When you try pairing with your phone are you sure you have activated the option? If not, here's what to do. Hold the call button on the H500 until the blue light stays on, then with your phone go to the bluetooth option and select search for devices. It should be able to find it then.
Sep 03, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility Universal Bluetooth Wireless Headset H500 Headset Logo
244 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
