Question about Samsung TXN2726 27" TV
Color gone There is no color in picture, except for a broad circular area in the middle, mostly green, with a couple of other-colored rings around that. Is this something easily fixable? By me? If not how much and is it worth it. The picture is also not very sharp.
  • Dorothy Roeder Apr 24, 2007
    I picked it up at GoodWill for $15. It is hard to believe that is all that is wrong but I am willing to check it out. It is 27 ". Would this work? from uxcell. Thank you for responding.
    Hand held TV CRT Picture Tube Degaussing Coil Repair Screen / Degausser
    Model Number: a06052600ux0007
    Market Price: $27.99 Our Price: $13.79 Add To Cart
    Hand held TV CRT Picture Tube Degaussing Coil Repair Screen / Degausser New
    Features:
    * High quality guaranteed
    * Degauss the color spots, shadow mask, and aperture color etc on the screen
    * Degaussing coil was sealed with plastic peel for easy use
    * Applied to colorful CRT, monitor, game displayer, PC displayer etc
    * Easy to operate, point at displayer and move it with circle for 20 seconds when press the button
    Specification:
    * Effective magnet: 70MT
    * Operating time: <3 minutes
    * Dimension: 30*30*200(mm)
    * Power: 220V AC
    * Weight: 336g
    Problem Solver:
  • 7 Answers
Try running a small magnet in circles from the centre of the front of the screen, you may find you may be able to "push" the problem off the screen. As snakehead commented, it's likely to be caused by speakers with a lot of magnetic field bleed placed near the front of the TV. If you are feeling brave try this homebrew deguasser! http://woil.ws/fixmonitor/
Posted on Apr 26, 2007
    Genius:
  • 1,074 Answers
You must have placed speakers around your tv. your tv tube has gotten magnetized.you will need a degaussing coil to remove those color stains if you do not have a coil call a tech to remove it for you.good luck.
Posted on Apr 24, 2007
Color picture jumps in and out of normal color mode . . .
You have bad solder connection in or around the Jungle IC and or color processing Circuits. Most commonly the area is the color cyrstal, located on the main board.
Oct 10, 2009 | Televison & Video
I left my tv on when I went to bed and the picture was fine. Then I woke up and turned it off. When I came home and turned it back on, the picture was blurry all around the tv except in the middle of the...
is the blurry all around the picture have different color like a smear of red, blue or yellow?
if it is i think the posistor of your tv is not working. it is the one who activate the degaussing coil around the picture tube the prevent color miss-landing upon opening your tv set.
Aug 11, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Samsug rear projection tv, everything looks green
Dust accumulation in color wheel, light tunnel, chip area can cause green tint.
It is very delicate area, light tunnel and chip can be easily damaged. Remove light engine assembly and color wheel. Blow dust out. Re-assemble. If the gasket around the color wheel housing is not replaced in the right position, or the housing screws not tightened correctly dust will contaminate the color wheel/light tunnel area.
Call someone that has done it a few times. If near Calgary, call me.
easyab
Jul 14, 2008 | Samsung HCM4216W 42" Rear Projection...
Sounds like the deguassing cicuit has failed . This aligns the purity of your colors .Most of the time it is a simple loose connection on the themistor or the degaussing input cord to the board . Or the thermistor is bad . The tv was not dropped ? If it was this could have loosened the shadow mask in the picture , then the only way to repair is the replace the picture tube . Good luck
Mar 04, 2008 | Panasonic CT-36D32 36" TV
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Blue color is now green and oranges are pink
Most likely a CRT coolant leak onto signal pcb.Look for wet
evidence........T.
Oct 25, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Panasonic Color Rings
It sounds like you have a warped shadow mask in your picture tube if your set uses a picture tube. A shadow mask is like a screen wire that lets the three color guns shoot electrons to their respective phosphor dot on the screen to produce the three primary colors which are mixed properly to produce the scene that is being shown. In other words you have a bad picture tube. Stargazer
Aug 12, 2007 | Panasonic CT-27SF37 27" TV
RCA 25: television
Sounds to me like a bad picture tube with circle rainbow like colors.Good luck.
Sep 03, 2006 | RCA F25423 25" TV
Samsung TXN2726 27" TV Logo
200 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
