Question about Canon Pixma MP450 All-In-One InkJet Printer
U051 The following ink catridge cannot be recognized
  • johnnieaway Jan 26, 2009
    U140 The following ink cartridge cannot be recognised
  • 2,692 Answers
Try taking it out and cleaning the electricial contaccts with a pencil eracer.
Posted on Jan 11, 2009
Hi, I refilled cartridge CLI-526M fromCanon Prixma MG5250 and I have the error U130. How can I resolve the error to reprint? Thanks.
FAQ: An Error Message Is Displayed on the LCD
If an error message is displayed on the LCD, take the corresponding action described below.
The following ink may have run out. Replacing the ink tank is recommended. U041 Print head is not installed.Install the print head.U051 / The type of print head is incorrect.Install the correct print head.U052 Some ink tanks are not installed in place. U072 / More than one ink tank of the following color is installed. U071 The remaining level of the following ink cannot be correctly detected. Replace the ink tank. U130 The following ink tank cannot be recognized. U043 U140 U150 The following ink has run out. Replace the ink tank. U163 There are no photos in memory card Contact the support center or service center for ink absorber replacement. Press OK to continue printing Ink absorber full. Service required Timeout error has occurred The device may be incompatible. Remove the device and check the manual supplied with the connected device An unsupported USB hub is connected. Remove the hub. B200Printer error has occurred. See the manual **** Printer error has occurred. Turn off power then back on again. If problem persists, see the manual
Jul 06, 2011 | Canon MG5250 Printer
In canon printer mx 330 ink catridge cannot recognized u051
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
poor ink cartridge contacts.
May 20, 2011 | Office Equipment & Supplies
The following ink cartridge cannot be recognized U051
The FINE Cartridge may not be installed properly, or the Cartridge may not be the compatible with this machine.
See my tip on filling these cartridges. (click my name to find it).
Jan 18, 2011 | Canon PIXMA MP460 All-In-One InkJet...
I have installed a new pg 30 print cartrige in my Canon MP 470 printer and I get a U051 Error print Head is not installed error. How do I reset printer to fix this error?
Hi there !
The ink cartridge is not properly fitted or installed or does not detect the ink catridge, remove again and fitted it correctly.
Also, clean with alcohol the gold chips of the ink cartridge and maybe there is sticky residue when you remove the sticker. Turnoff your printer and plug it on again to refresh the memory.
I hope it helps you.
Jan 13, 2011 | Office Equipment & Supplies
Showing Check Ink U051 COL. Have removed the
Hi there
For troubleshooting purposes,
Perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank
properly. If it does, it will indicate it does not detect the other ink tanks, as
they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are
installed, the cause will be the last tank installed. For example, if
you inserted an ink tank earlier, and you later inserted another ink
tank, and it said two of the same inks were installed, the cause of
the issue is the last ink tank.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | Canon PIXMA MX310 All-In-One Printer
Pixma mx328 check ink u051
The error usually came out after you refill ink on the black cartridge...there is no way you can make the printer work without resetting the ink cartridge..
Try to reset the printer using this procedure.. it will help.
1. turn off the printer..
2. press/hold the stop/reset button..and press/hold power button too..
3 while holding power button, release the stop/reset button..
4. then press the stop/reset button twice..
5. release power button..and wait until the power button lights a steady/still green and says "idle"...
6. open the cover...take out both catridges.. then turn off the printer.
7.put back the cover then turn on...
8. now put the catridges back.. and wait for some time to return to display menu... then try to print...
The printer may still prompt a "black ink volume unknown and color ink volume unknown" but don't worry that won't affect the operation of the printer. And you will able to use your printer, fax and scanner.
Do this every time you refill the ink of the cartridges.
If you find this solution helpful please vote on this on the YES below..thanks..
Dec 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Cartridge problem
Please remove the printer catridge and clean the the extra ink in the catridge holder and in the catridge connection point with the soft cloth without damaging the cables in the catridge and the holder then test it
Jul 22, 2008 | HP PSC 1610 All-In-One InkJet Printer
I have a Pixma MP830 all in one inkjet printer. After I used Catridge World ink tanks, printer would not work. I have since refitted Canon ink tanks, but unit says, "the following ink tanks cannot be...
did buying Canon cartridges rectify the U051 problem? do not want to pay out for more new cartridges (bought last ones from Cartridge world!) and not fix the problem. thanks
May 13, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Canon Pixma MP450 All-In-One InkJet Printer Logo
283 people viewed this question
old marine
old marine
