Question about Samsung LN-S4041D 40 in. LCD HDTV
Samsung LN-S4041DX 40 in LCD TV
Our above model lcd is about 2 years old. About 2 weeks ago, the screen started to go black but we could still hear the sound as good as normal. We would turn it off and about 6 hours later we would turn it back on and it works for about 10-15 min on average and then like clockwork goes black again. We have to wait about 6-7 hours before we can get these 10-15 minute blocks of picture, otherwise it is only sound no picture. I have read about the backlight inverter going out but in most of the posts, I read the screen would blink at you and then go out. If it was the backlight would we be able to watch it like normal for 10-15 min every 6-7 hours? We really do not want to have to get a new TV, I just want to know whats wrong with it....Any help would be greatly appreciated....
  • Anonymous Jan 08, 2009
    Hmmm, we just discovered our two year old LCD from Samsung is shot, we had the same symptoms. 2 years??!!
  • jhou1128 Jan 28, 2009
    Same problem, almost 2 yrs old, started on Christmas eve. Screen goes black, then lines horizontal/vertical and sometimes nothing.
    Problem Solver:
  • 11 Answers
Hi. You can try to go into service mode and reset the LCDTV to Factory Default. This will clear out all buffer over run's and any software related issues. It may fix the problem or it may not. If this doesnt fix the problem than you need to have a qualified Technician to look at it. The problem is in the AV circuit board, a technician who is qualified to repair electronics at circuit board level should be able to repair this problem rather quickly and inexpensively. Most technicians who do not have the expertise in repairing cicuit boards to component level would rather replace the whole AV board than repair it and this will be rather expensive.So talk to the repair shop before you drop the TV off.
Be very careful when accessing service mode. I suggest to write down all information in all areas before proceeding to a factory reset. If you do not record all values correclty you run the chance of not being able to use the TV again. To go into Factory Service mode, use the original remote and in this sequence push POWER OFF-MUTE-1-8-2-Power ON, the set will turn on and enter service mode, if you hit all previous keys correctly. If it doesnt try again. When you are done hit POWER OFF and this will exit service mode and save the data.
Posted on Jan 28, 2009
Samsung 40" flat screen looses sound
this problem started on my LN-S4051D a couple of years ago. eventually the sound stopped working altogether. I then started using my surround sound speakers for the TV via optical out but soon that stopped working as well. I recently took the TV to a repair shop who said that the main board is bad and needs to be replaced. Labor plus parts was going to cost me $400. I said no thanks and paid for the estimate. Good luck.
Jun 27, 2010 | Samsung LN-S4051D 40 in. LCD Television
LN-S4041D 40 in. HDTV LCD Television: OUR SAMSUNG T.V IS A 40 INCH AND IT CLICKS, CLICKS...
Is there a clicking sound? Unplug the power cord for 20 seconds and see if this helps reset the circuitry. If the clicking continues, go to http://www.fixya.com/support/t722954-samsung_lns4051_dx_makes_clicking. If you can see defective caps on the power board and don't feel comfortable replacing, parts can be ordered at PartStore.com.
May 16, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung 40inch LCD tv doesn't turn on for some time, clicks, clicks, clicks, with standby light coming off and on for some time (~2min) before it finally decides to work.
To all who are having power supply issues: Samsung is now acknowledging a problem with the faulty capacitors. I called 1 800 726-7864 and they said they would repair certain out-of-warranty TVs if the problem is related to the capacitors. I just called and they are sending a service rep out to diagnose the problem
Feb 06, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung LN-T4665F 46" HDTV Screen is BLACK - NO PICTURE
I am a Samsung certified Tech, they do have problems but when the LCD screen was replaced and the main board, they sould have replaced the FR board also
Sep 26, 2009 | Samsung LN-T4665F 46 in. LCD Television
TV clicks constantly, as if trying to turn on/off.
Probably a bad main board or T-CON board or both. If you're trying to fix yourself, try disconnecting the cable (LDVS) from the small board (T-CON) at top center of the LCD panel and see if it still cycles. Note, be very careful with that cable, it is very delicate. If it still is cycling off and on, then it is probably the main board. A slight chance it may be the power board also.
Apr 04, 2009 | Samsung LN-S4051D 40 in. LCD Television
Green color on Samsung ln-t4042
If the whole screen has this tint problem, there is nothing you can do. It must be repaired. You will need to take it in for service.
Mar 15, 2008 | Samsung LN-T4042H 40 in. LCD HDTV
LCD TV
I had a problem with a Samsung 46 inch LCD and it had audio and dim light but no picture and found out that the logic board toward the top (inside tv) was bad and was no longer available and the only way to fix it was to get the entire display panel (the logic board came with it) It was not costwise to repair. Hope this helps.
Dec 28, 2007 | Samsung LN-S4092D 40 in. LCD HDTV
Samsung LN-S4041D 40 in. LCD HDTV Logo
514 people viewed this question
Jerry Greenberg
Jerry Greenberg
