Question about Electrolux EOG6330 Gas Single Oven
Gas oven - fan constantly on
Hello. I have just had an Electrolux built-in single gas oven fitted. Trouble is - since plugging in, the fan is constantly on. I have been trying to find out if there are any service manuals for this oven?
    President:
  • 1,462 Answers
Assume this is the casing fan. this is controlled by a fan stat which may be faulty. however, this fault should be covered under guarantee so call service agent
Posted on Apr 24, 2007
WE HAVE AN ELECTROLUX DD060GA DOUBLE OVEN THE TOP OVEN IS WORKING BUT THE BOTTOM OVEN DOESN`T EVEN COME ON WHEN YOU TURN THE KNOB THERES NO GAS AND NO SPARK AND THE LIGHT WONT COME ON EITHER, CAN YOU...
Good Morning Friend,
I understand that your Electrolux double oven, model# DD060GA, is having trouble with the bottom oven coming on. I also see that your top oven works just fine. This appears to be a UK Electrolux double oven. I suggest contacting the manufacturer directly. They will be able to better assist you in getting your bottom oven functioning correctly.
-Best Regards-
WP
May 21, 2014 | Electrolux EOG7330WN Gas Double Oven
Very noisy cooling fan.
The only way to fix it properly is to replace the cooling fan I have tried every other way possible at some point
Apr 21, 2012 | Electrolux EOG6330 Gas Single Oven
My Electrolux Eog6330xn oven cuts out after about an hour and the ignighter then constantly sparks. the oven then has to be turned off to cool down before it will relight. Any advice.
Hello there Gary and welcome to FIXYA
Usually when an oven won't bake properly or stops baking , it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself. The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame. I would disconnect the power to the oven then unplug the wiring assy and remove the part then clean all of the terminals really good then reassemble it then try the oven again if it still does not work properly i would go ahead and replace that part ok
Please keep me posted on how this is going i can give you more help but this is the most common problem ok?
Best regards Mike
Nov 07, 2011 | Electrolux EOG6330 Gas Single Oven
Electrolux Gas Oven EOG6330; Cooling fan still on several hours after oven turned off. Solution, please.
hi the change over stat is probably faulty one of the wires from the cooling fan will go directly to it. there are 3 wires on it. just replace it. 311 23 97-00/9 is the part no approx £18 +vat
Feb 09, 2011 | Electrolux EOG6330 Gas Single Oven
Maytag 24 " wall oven gas trouble code F5
Hi ngwhite,
The trouble code F5 is a Watchdog and hardware conflict. You need to replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
Aug 02, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
Gas connection on bottom of oven does not accept std 1/2'' flex hose?
all gas connections are flair fittings if the 1/2 inch is to large a 3/8 inch is the mext size down. if the 1/2 is too small the next size up is 5/8
Sep 03, 2009 | Frigidaire 24" Single Gas Wall Oven with...
Electrolux gas single oven
due to safety feature you should have oven door closed,turn dial to 1,ignite then turn to 5or 6 hold it in for a few seconds and release.this should solve your problem
Jul 27, 2008 | Electrolux EOG6330 Gas Single Oven
Electrolux EOG6330 Gas Single Oven Logo
199 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
