Question about Dryers
My Amana Dryer won't work
The dryer drum won't turn and we can't get the back off the dryer to try to fix the problem. If you can help, please do. Thank you in advance.
  • 318 Answers
Your dryer may have a small panel in the front to access the safety thermostats. if not it may be a full front panel with 2 screws at the bottom to get into the unit. there will be an open safety thermostat that has failed. is in the left rear of the unit on the element. make sure you have good air flow and the vent is not pinched off causing the thermostat to fail.
Posted on Dec 28, 2008
Amana electric dryer whining when started
Is ther anything caught between the drum and the back of the dryer. run you finger around the back edge of the drum inside do you feel anything caught
Feb 02, 2014 | Amana Dryers
Frigidaire dryer not working drum won't spin,
Hi How old is it , ? and dose it soun like the motor is running but not turnning the drum ? this would be a bad belt , you will need to do some more investagating for me to help you
Dec 06, 2011 | Frigidaire Dryers
I have an Amana (M# ALE643RBW), when started the dryer squeaks for the first 10 minutes of the cycle, then slows to a squeak every 7 minutes... why? Maybe a bit of lube?
I have the same problem. While I have not fixed it yet, I assume it is a drum roller. Most dryers have two 4 to 5 inch diameter drum rollers which hold up the dryer barrel in the back. These drum rollers are wheels which have rubber on the outside where they touch the drum and a metal hole in their middle. They turn on a metal rod which goes through their middle. As the inside of the wheel turns on the rod, the metal gets eaten away and they squeak. Replacing one or both drum rollers should fix the problem.
Nov 25, 2009 | Amana Dryers
Won't spin or start
Sounds like the screen/sock combo got the tub in a bind and the drum belt broke.
If you want to pursue replacing the belt, let me know.
Apr 30, 2009 | Amana LGA10 Dryer
I HAVE AN AMANA GAS DRYER THAT MAKES A VERY LOUD
Here is the link for the owner's manual, but it doesn't look like much help. Just cut and paste on the address bar of your browser. http://shop.amana.com/assets/pdfs/literature/40125301.PDF
Once you get through looking over the manual, here is how you fix your dryer:
  1. Unplug the power plug, disconnect the gas line, and vent hose, and pull out where you can access all sides.
  2. Take a putty knife and insert it between the top and the cabinet at the front corners to release the spring clips.
  3. Flip the top toward the back making sure the wiring harness to the timer and controls does not get pulled.
  4. Take off the access panel toward the bottom of the cabinet, push the belt tensioner away from the belt, and pull the belt off of the motor pulley.
  5. Lift the drum out of the cabinet, clean and re-grease the ball and socket at the back of the drum, clean off the surface where the belt rides with steel wool.
  6. If the idle rollers turn freely, clean the lint off of the surfaces, put the new belt on the drum and lower back into place.
  7. Put the belt back on the motor pulley, put the bottom cover back on, flip the lid closed, reconnect the gas, vent hose, and plug in.
If you found this solution helpful, please don't forget to rank it.
Mar 27, 2009 | Amana ALG331RAW Gas Dryer
Amana dryer drum.
Look for an obstruction in the blower. You may have to remove the panel and bulkhead to find it. Remove the dryer from its power source before any disassembly.
Feb 18, 2008 | Amana ALE643RB Electric Dryer
Dryers Logo
Top Dryers Experts
