Question about JVC HD-52G886 52" Rear Projection HDTV
How do i reset my jvc tv
Power light blinks lamp light blinks how do i reset the tv.
  • Hymzjr1987 Jan 27, 2009
    My JVC HD-52G886 52in is having problems, The power light, the lamp light is blinking and no picture comes on how can i reset the T.v. or do i need to bring it some where for repairs?
  • 24 Answers
Either a bad lamp or bad reciver board.If audio amp ic on reciver board shorts ,it will kill part of supply and lamp ballast will not turn on and fire lamp.
Posted on Jan 11, 2009
5 Suggested Answers
SOURCE: jvc tv
when both the blue light and red light are blinking it means 1 of 3 things. 1. lamp replacement. This often works everytime for the repair. TIP!!! DO NOT USE ANY OTHER LAMPS OTHER THAN JVC AUTHENTIC LAMPS. ANY OTHERS AND YOU RISK DAMAGING YOUR TV FURTHER. 2. the fans are not working properly or need to be replaced. They need to be cleaned every so often and they will stop working from burn-out if not done so. This repair will cost you less than 100 dollars. 3. The ballasts are defective and need to be replaced. The ballasts themselves run about 150 dollars. I tell you I have fixed this TV more times than I care to count, not to mention the number of lamps I have gone through. The guy at the TV repair place now knows me by name when i come to buy lamps. :(
Posted on Dec 07, 2008
  • 395 Answers
SOURCE: JVC TV lamp indicator light blinking new lamp
if you purcased a LTI lamp then the possibilty of a bad lamp may be the case. LTI lamps are cheap and are poorly manufactured. if it is a JVC lamp then you may have further problems such as lamp balast, or thermal sensor. clean the fans and filtersfor better air flow. keeping the lanp cool is important for the life of the lamp.
Posted on Apr 19, 2008
  • 1039 Answers
SOURCE: power led and lamp/program led blink stimultaneously. even after unpluging and let tv cool, still no picture
Check lamp.
Posted on Apr 25, 2009
fieldy14
  • 456 Answers
SOURCE: rapid blinking light (lamp) on a JVC model HD
It normally means the lamp is in need of being replaced, and its all depending on the use of the TV as well as how long the lamp life is. You should be able to access the lamp via a small section near the rear or the back of the TV unit, if the lamp is blown or faulty it will look the same as a blown light globe.
To obtain a new lamp contact the brands authorised repair agent as they will be able to get trade prices and in turn, give you the best price,
Also make sure that whoever replaces the lamp resets the lamp use time as the TV will still not start if you don't reset the lamp use time as it will still think it has a faulty lamp. I hope this helps, good luck.
Posted on Dec 05, 2009
TV blue light comes on, then the red light blinks two times, on the 3rd blink, it goes into rapid blinking. I replaced the lamp and it worked for a week, but then the same issue. I put the old lamp back...
some units require a lamp counter reset.the ballast usually starts at extreme output and at certain hour interval the ballast would start to decrease voltage as the bulb ages.to reset on some models can be reset using the remote
Aug 12, 2013 | JVC HD-61Z786 61" Rear Projection HDTV
Blank Screen; Blinking Blue Light.
try to re seat the bulb again dont touch it lens or anything unplug ist as u do then reset timer on it ok in menu maby it just not in tight or came loose after 1st heat
Jan 21, 2008 | JVC HD-52Z585 52" Rear Projection...
Power led and lamp led blink simultaneously on my jvc hd65s998 rear projection tv
You might need to replace your lamp driver, or ballast as some call it. This is what strikes the lamp to make it light.
Mar 20, 2013 | JVC Televison & Video
Lamp turns on lamp light starts blinking then turns off
Check the lamp ballast, it works just like a flourecent light if the ballast is bad it will turn the light off. It comes on a board try searchinng ......ebay or thetvdoctor.comXHRWN5
Feb 23, 2012 | JVC HD-56FB97 HDTV
Power will not come on. when tv is turned on light comes on then begins to blink, no picture and have to unplug to stop light from blinking.
Depending on how old it is it may be a lamp issue. Check your manual to see what the blinking light means. if it's a lamp issue you may need a new lamp and have to reset the lamp timer.
Jan 16, 2010 | JVC LT47X579 47 in. LCD TV
Rapid blinking light (lamp) on a JVC model HD
Dec 05, 2009 | JVC HD-52Z575 52" Rear Projection...
Power light just blinks when I turn it on
lamp is burned out, buy a new one online for $150 or less and install it according to the instuctions sent with the lamp. this is fairly easy to do so dont believe all the repairmen on here telling you to bring it to a pro-they just want your money!! good luck
Nov 07, 2009 | JVC LT-42X579 42 in. LCD TV
Please help!!! Problem with JVC DLP TV
You need to replace the power supply board. The new ones have a bigger heat sink - obviously JVC knows about the problem because they made the new ones bigger. It cost $250 from JVC and I installed it myself - took about 3 hours to do. If you are not tech savvy call a repairman. Hope this helps.
Feb 03, 2009 | JVC HD-52G786 52" Rear Projection HDTV
How old is your TV?
Lamps in DLP TV has specific working hours and physically lamp will look good but won't give light ( actually consume more current and protection circuit stops power supply)
Thank you.
Dec 04, 2008 | JVC HD-52G786 52" Rear Projection HDTV
JVC TV WENT OFF. TURNED IT ON AND THE LAMP LIGHT STARTED BLINKING
If the Fan is clogged up with dirt set will not run fan must be working.
Dec 01, 2008 | JVC AV-30W776 30" TV
JVC HD-52G886 52" Rear Projection HDTV Logo
1,599 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
