Question about Casio Exilim EX-Z500 Digital Camera
Memory card problem
I have a problem with my camera. When I turn it on to view pictures, or even record images, I get a message on the screen saying "This card is locked". I know its not full, there are only a few pictures on it, so what could be causing this problem?? Thanks for any help. Preeti
  • TRAI Apr 14, 2008
    I AM HAVING THE SAME PROBLEM. CAN YOU LET ME KNOW WHAT TO DO TO FIX IT. THANKD MARIJO
    Scholar:
  • 135 Answers
On SD cards, there is a tiny sliding switch on the card itself, which "locks" the card, preventing files from being added or removed. Try removing the card, and checking this little slide switch. In this photo... http://en.wikipedia.org/wiki/Image:Secure_Digital_Kingston_512MB.jpg ...the lock is the yellow bit on the left-hand side.
Posted on Apr 24, 2007
Why, when i take a picture and try to see it it comes up with a picture error on my sp-600z camera
The manual says:
Problem with selected image
Use photo retouch software, etc. to view the image on a computer. If the image still cannot be viewed, the image file is corrupted.
But try this. Switch of the camera, remove the battery and memory card. Check if all contacts are clean and shiny. On the battery, on the memory card and in the camera. Then replace the battery and memory card and switch on.
I hope this solves the problem.
Jun 04, 2014 | Olympus SP-600UZ 12MP 15x OPT Zoom Digital...
Canon rebel T1i won't take a photo and gives message busy
Try formatting your card in your computer and then in the camera. If problem persists then try another memory card. You need to determine if it is a card or a camera problem
May 12, 2014 | Canon Cameras
I have a panasonic Lumix HD AVCHD lite. Other numbers/title: DMC-ZS7 I thought I had a full memory card when the screen message read "Images will be recorded to internal memory". It...
Your card is probably good. Go into the camera's setup menu and find the picture storage or memory section. Select external memory as default and you should be good to go.
May 14, 2011 | Panasonic Lumix DMC-FZ18K Digital Camera
Can't get a picture on the screen - just shows black. When we turn the camera on the LCD screen displays the function choices and menu options, but will not display any image. If we take a picture using...
Check the SD card, they have sliders on them which lets you "lock" the card so nothing can be put on or taken off of it. Make sure that is off. Then go through the menu on the camera and try to format the card again. If the card is bad it should give you an error message when it tries otherwise you should be good :)
Aug 19, 2009 | Canon Powershot A1000IS 10MP Digital...
Can not view pictures
No this camera does not have any internal memory. All images should be written to the memory card if the memory card is inserted properly. If the memory card is not inserted correctly the camera screen will show a message of No card. Do you see that message?
Apr 27, 2009 | Olympus E-520 Digital Camera
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Error message: file contains no image data
Hello!
I may be able to add some advice on how to solve this unfortunate problem of "file contains no image data". I have been suffering from the same problem. I have recently been on some amazing vacations and the photos I have lost due to this problem have been invaluable to me! I would pay an insane amount of money to get these photos back, but unfortunately I cannot!
I have a nikon coolpix camera. I contacted the nikon coolpix technical support center. I spoke with a representative who asked me what type of memory card I have. As it turns out I have a generic memory card, which is not compatable with nikon. The only memory cards brands that are indicated to be used with the nikon coolpix camera that I have are as follows: Toshiba, Panasonic, Lexmark, and Sandisk. Those are the only 4!
I was told that if you use another memory card besides the memory cards brands that I have listed... that the camera may communicate incorrectly with your memory card, which results in data that is incomplete to support an image. When this happens you will only see a portion of your image, and you cannot get it back. These bad images with incomplete saved information are called "corrupt files". The representative told me that there are some programs that are available to purchase that may be able to correct corrupt .jpg files, but she believes that they are memory card brand specific.
To put it simply, when you do not have to compatable memory card in your camera, it is as if your camera is speaking english and your memory card is speaking chinese and they are not communicating properly (this was the way the representative explained this problem to me). So check your user manual for your specific type of camera or look it up online to see what type or brand of memory card you should be using! I truly hope this helps someone avoid losing invaluable photos!
Nov 29, 2008 | Nikon COOLPIX L18 Digital Camera
Unidentified Image
Usually the only time this message will appear is when you have taken the picture with another camera and try to review it on another. If this is not the issue, try formatting your card. Try another card. It may be a faulty memory card. If none of this works, call Canon tech support for free support.
May 28, 2008 | Canon PowerShot S51S Digital Camera
Images recorded to internal memory
They should be accessible by removing the memory card (if present) and powering up the camera. You should be able to view them using the playback icon (arrow). Access to erasing them should then be through the menu.
Feb 16, 2008 | Fuji FinePix Z100fd Digital Camera
How do I use the memory stick?
Recording Still images To The Memory Stick M.REC mode (Memory RECORD mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to CAMERA. 3. Press the PHOTO button. The still image is recorded to the Memory Card. To View photos on the Memory Card M.PLAY mode (Memory PLAYBACK mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. The last recorded image appears. If there are no recorded images on the Memory Card, NO STORED PHOTO! or NO STORED MPEG4! will display on the screen. 3. Using the (FWD) and (REV) buttons, search for the desired still image. * To view the next image : press the (FWD) button. * To view the previous image : press the (REV) button. * Pressing (FWD) when you are on the last image will take you to the first image and pressing (REV) when you are on the first image will take you to the last image. * Keep pressing (FWD) or (REV) to search for an image quickly.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Casio Exilim EX-Z500 Digital Camera Logo
85 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
