Question about Canon Rebel XT / EOS 350D Digital Camera
My camera say err CF
I read the manual and changed the battery I then got a 99 error then it went back to err CF what can I do to fix it.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 155 Answers
These are steps to Fix Err 99's, have a go and see if resolves your other problem too.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Posted on Mar 19, 2009
Error reading on screen on 1000e
Hello :
Here is what Canon said according some forums :
To isolate the cause of the issue, we suggest that you do the
following:
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
Does the "ERR 99" message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
If the "ERR 99" message only appears when one particular lens is
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
I hope this will help .
please don't forget to rate !
Apr 06, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
I keep getting error 99. I've cleaned the sensors with a new eraser; I've changed the battery and changed the memory card. If I take out the battery and put it back in, I can take a picture. If I pause for...
Hello:
following:
steps:
camera body.
Mar 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Codee error 99 ??
hi,
I do not know if this is going to be of any help. I was actually reading about this error code 99 in canon, and bumped into a forum, where people had share their experiences. You can give it a try. But if your camera is still under warranty, it is best to ring technical support.
"ERR 99" is a general error code displayed by the camera when the camera knows that something is not working properly, but not exactly what.
This error is typically associated with lens communication or shutter mechanism issues. To isolate the cause of the issue, we suggest that
you do the following:
Does the "ERR 99" message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the
camera body.
If the "ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
Hope this helps !!!
Apr 17, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
I am getting an error cf..tried to format card and get error 99
I Googled the error code you're getting, and found a list of things to try and steps to attempt directly from Canon. Try out some of the stuff below, it should help.
To isolate the cause of the issue, we suggest that you do the following:
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most
camera body.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 40d error 99
Try the following diagnosis steps: -
Mar 12, 2009 | Canon EOS Elan 7ne 35mm SLR Camera
Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
Nope, this is not card anymore.
As you know CF is card failure, sometimes this cause to start error 99 , that is lens error , even if there is no problem with the lens.
This happens because the built in software in the camera can get messed up after an error CF.
You fix the problem calling Canon, they will guide through upgrading the firmware in your camera.
First ensure that you are using the camera menu and command to format the new card, and that new cards are properly inserted into the machine.
Call Canon support to get a firmware upgrade.
Feb 13, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Not all CF cards are created equally, so yes, it could be your batch of cards. To determine if the error is CF related, and not anything else, try the following steps which are used to diagnose err 99's
Feb 13, 2009 | Canon EOS 30D Body Only Digital Camera
Error 99 in Canon EOS 350 D
Try the following diagnosis steps, in this exact order. This will isolate the cause of the issue: -
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Dec 01, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Err 99
Although you may have cleaned the lens contacts, did you clean the camera contacts? This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
camera body.
From RICHARD'S NOTES
Dec 04, 2007 | Canon EOS-10D Digital Camera
Err 99
cleaning the contacts ought to be done using a pencil eraser(i am very specific about this)to fix this error
vigorously scrub the lens contacts with an eraser. Then  gently use the eraser to clean the camera contacts (holding the contacts face-down to prevent eraser rubber from falling into the body).Put the lens back on… and the camera shoudl be fixed!
Try this and post back before you rate..
Nov 01, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
252 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
