Question about HP Pavilion dv6000z Notebook
Hp dv 5000 bottom of the screen freezes and gos dark
And curser stops and when close window last sreen stays there and have to wigel screen just rt to make it stop
  • samfarnum Apr 01, 2009
    Screen "freezes" and I need to wiggle the whole monitor part of the laptop (the screen) to get the picture to come back. Definetly not a software issue or motherboard prob.
Compaq presario cq61 screen went dark but can still see window faintly through the dark sreen.
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If no luck, try to remove battery and drain the power, then replace battery and turn on.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it.
Jan 06, 2011 | Computers & Internet
Curser doesn't move... on my Logitech Trackman Wheel - 3-btn Trackball - Wired For some reason my curser used to just drop to the bottom left of the screen during operation which was quite frustrating... I...
Sounds to be a hardware problem. especially if it would move by itself at times, now not at all.
Windows is detecting it correctly, right?
If so, then i would say time for a new one.
Aug 17, 2017 | Logitech Trackman Wheel 904353-0403...
Last night the screen started going dark, then went out, black
If still under warranty, I would suggest going that way as this is a bad matrix driver....
Feb 15, 2010 | Sony Televison & Video
Pavilion dv 1000 won't reboot, stand by nor turn off
I had this kinda problem solved on a Acer 5920 LAptop. The webcam driver was the culprit. Remove the cam driver for the same, the windows driver will take over and then i guess it will work fine. I figure its a driver issue or a TSR program not quitting. If this fails try uninstalling recently addes program or driver.
Jan 05, 2009 | HP Pavilion dv1000 Notebook
Curser freezes
When you said your cursor freeze, does the computer still respond or the whole computer froze. If the computer froze, then it could be anything from, memory, hard drive, cpu, or mainboard. Does the keyboard works, if just the cursor freeze, try using a usb mouse.
Nov 07, 2008 | IBM ThinkPad T40 2373 Notebook
My notebook is showing a light dark sreen but its working fine the only problem i cannot see well sinse the screen is dark when i bring it close to the light i can seen but not clear.thanks
Have you adjusted the brightness? Amend where necessary
Does it happen even on startup? Yes = Monitor Failure repair/replace. No=Graphic settings
Oct 30, 2008 | HP Computers & Internet
HP Pavalion F1503 15"
A quick Google search turned up a couple of sources for generic replacements:
http://www.lcdparts.net/CCFL1.aspx
and
http://www.ccflsurplus.com/laandmoba.html
Looks like they might be promising. A possible source for the original HP part might be Vance-Baldwin (www.vancebaldwin.com). I have purchased other HP parts from them.
Sep 02, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Laptop not showing any display
have you heard windows opening sound comes up ?
If not try reseat the memory.
If you able to see the something on the screen but it's too
dark to read , it could be backlight inverter problem.
what i learn from compaq DV model they have some
motherboard power up problem such as DV1000 / DV2000 etc..........if your laptop still under warranty i suggest you send
it back to the dealer for warranty.
Jul 18, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv6000z Notebook Logo
190 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
