Question about HP Office Equipment & Supplies
Deskjet D1320 printer will not print in color .
The test page prints in color but nothing else will print in color.
  • 5 Answers
SOURCE: DeskJet 950C Pink Printing problem
Assuming that you have the correct print drivers and the color is set correctly on your software. Then the issue is often caused by the ink drying and clogging the injectors. Open the lid and remove the ink cartridges, then unplug the printer. Then get a swab or Q tip and using bottled water (do not use tap water). Moisten the swab and wipe the areas on the printer where the ink cartridge contacts the printer. You should see ink on the swab. After you let it completely dry then place the cartridge back in and turn the printer back on. Try to print again. If it is still not printing with the correct colors then you could have a problem with the injector circuitry. At that point it is cheaper to buy a new printer. You can get refurbished ink jet Dell printers at Dell.com under outlet for usually $30-$40 and a one year warranty.
Posted on Feb 11, 2008
Rain041304
  • 63 Answers
SOURCE: epson c66 will not print black
Do print head cleaning. Contorl panel>right click on c66 and go to printing preferences>maintenance tab>print head cleaning>do it 3 times and then try to print
Posted on Feb 14, 2008
aicaxz
  • 511 Answers
SOURCE: HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
Posted on May 29, 2009
tommya300
  • 724 Answers
SOURCE: HP Deskjet 5740 printer won't print in color.
did you check the printer properties on the computer side?
take off of gray scale I believe this may be the reason
Posted on Jul 31, 2009
rajeish
  • 52 Answers
SOURCE: printer will print test page but nothing else
there is a communication failure between the printer and the computer. uninstall and reinstall the printer driver. your problem will be resolved.
Posted on Aug 04, 2009
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
    If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
Hp deskjet d1320 yellow light keeps blinking
Thank you for suggesting that the cartridge might be bad. I almost got rid of my deskjet D1320 because it was blinking continuously and I could not figure out why. I tried everything from new driver to looking for a paper jam and nothing worked until I tried your suggestion. I tried each of the cartridge separately to find out that the black cartridge was making the light blink but not the color on. I replaced the black cartridge and the printer is fine now
Oct 25, 2010 | HP DeskJet 1220c InkJet Printer
Im having HP Deskjet 6943, I have install black and colour catridge. I print test page its coming ok. But when i try to print colour in MS Word, Excel, Powerpoint i not getting colour, what could be the...
please printer driver setting .. give a print ...select your printer and go to printing preference then go to color tab check for any setting like print in color in gray and print in color ....... select print print in color ......and try ....
Dec 29, 2009 | HP Deskjet 6940 InkJet Printer
Have new ink cartridges, however when I print a test page, nothing but the windows logo prints
You mean, the black color is completely absent from the printed page? Either the black cartridge is faulty and needs to be cleaned, or (less likely) the cartridge carriage is faulty.
Try running the "Printer Head Cleanup" routine from the printer manager maintenance menu.
Aug 28, 2009 | HP DeskJet 952c InkJet Printer
Hp 9800 prints only quarter page
Try sending less pages to print and see what happens.
Try one to test and if it workks then send 24 of the 48 pages and finally the rest.
Aug 28, 2009 | HP DeskJet 9800 InkJet Printer
May 29, 2009 | HP Office Equipment & Supplies
Color test pattern page prints every time I make a copy
IN THE PRINTER SETTINGS YOU MAY HAVE THE "PRINT TEST PAGE" SELECTED
Jan 10, 2009 | HP DeskJet 5550 InkJet Printer
HP deskjet 5550 printer not printing.
could be low on ink or toner. dont you just love that? itll print out a test page which is a waste of ink but wont print out anything else.
Nov 17, 2008 | HP DeskJet 5550 InkJet Printer
We have a HP Deskjet D1320 printer. I can print my email, pictures and items off the internet, but cannot print any word documents or notepad documents. When I print an excel document, I get an incomplete...
I have a HP Deskjet 1300n printer. I can print my email, pictures and items off the internet, but cannot print any word documents or notepad documents. When I print an excel document, I get an incomplete page-the grid lines will print,and text garbage from a adobe program but not all the text. When I do a test print page, I get an incomplete text page, but do not know how to solve this. I have removed and reloaded the printer software-no improvement. There are no new drivers to be installed.
Sep 21, 2008 | HP LaserJet 1300 Printer
Hp 3745 prints only the red color
This is Romeet, id like to try and help. Assuming you have windows XP installed,
go to "Start", select " Printers and Faxes"
go to your printer ( HP deskjet 3745 ) and right click it and select properties.
Click on " Print Test Page ", tell me what color does the Printout come in.
B.Regds
Romeet
Oct 31, 2007 | HP DeskJet 1280 InkJet Printer
51 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
