Question about ASUS P4PE/L (ASU49J) Motherboard
Format 320 GB HDD problem
I have an Asus P4PE-L motherboard and I'm trying to format a 320 GB PATA HDD. I have upgrade XP to SP2 and ran SeaTools to confirm the drive is ok. It will format on another system but all I can get is a 150 GB partition. The IDE connectors are 40 pin.
  • 1 more comment
  • Dave Chrapco May 02, 2007
    I have an Asus P4PE-L motherboard and I'm trying to format a 320 GB PATA HDD. I have upgraded XP to SP2 and ran SeaTools to confirm the drive is ok. It will format on another system but all I can get is a 100 GB partition. The IDE connectors are 80 pin. What pins on the HDD limit size?
    I' have also tried to format 3 - 100 GB partitions. The first works fine but for the second and third I get "format failed" error.
  • Dave Chrapco Jul 16, 2007
    Reflashed the bios from ver 1.02 to ver 1.07. Still couldn't format 320 GB drive. Then loaded a new XP on new drive as test and BINGO I could see all 320GB of new drive. Then formated c: drive and reloaded XP and now able to format all 320 GB of new drive. So simple, yet so hard
    Problem Solver:
  • 5 Answers
You can also chechk pins on your hdd,the partion plug could be on limited size.Meaning you can only access a limited part of the hdd.
Posted on Apr 24, 2007
    President:
  • 2,961 Answers
Have tou tried the mangement in windows, My computer> right click>manage, then disk management and then right click on your hard drive and then one of the options is to format. Although only 127gb will show and the rest should show as a seperate partition, do the same with this to implement it. If no other partition shows you may have to upgrade your motherboard bios to suport large capacity disks.
HOE DO I REMOVE XP OPERATING SYSTOM FROM HARD DRIVE
Are you trying to upgrade from xp to windows 7? First check if your hardware can support windows 7. You should have atleast 2 GB or above memory, 60 GB of HDD for windows alone so 320 GB HDD would be recommended. Your cpu should be dual core or core 2 duo atleast. If those are checked, upgrade to windows should delete your windows xp.
Or the other option is format the partition of the HDD where windows xp is installed.
Let me know more. So that we on the FixYa can help.
Good luck
May 28, 2014 | Dell Inspiron Computers & Internet
WHAT MEMORY COMPATIBLE?
DDR PC2700 or PC 3200 RAM is compatible.
Up to 1 GB per slot.
Here is a link to Crucial for RAM that is compatible:
Computer memory upgrades for ASUS P4PE Motherboard from Crucial com
Sep 14, 2011 | ASUS P4PE-X Motherboard
Hello, My my motherborad is ASUS p5rd1-vm;RAM1GB and hard disk is PATA 80 GB but the HDD is having some kind of problem and the windows have shown a warning about it several times. Now i want to buy a...
Yes, it's compatible with the motherboard, no, it's not compatible with the XP install disk because it doesn't have SATA support. And since Asus doesn't provides it special driver needed (one that must be put on a floppy) it means that you simply cannot install XP on this disk.
All you can do is to obtain another PATA hdd what ever its size and install XP in it. Then put the new SATA disk in and use it to store all the installed programs and all your files on it. As a bonus you won't lose them if the new PATA disk fails or XP gets corrupted.
Or install Vista or 7 instead of XP, the have support for SATA disks
Jul 28, 2011 | ASUS P5RD1-VM Motherboard
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very low....
Thanks for the details. I have used K8V-MX Asus motherboard and found it very reliable with quite reasonable performance. It definately supports 500 GB Sata drive and there must not be any issues after increasing just the storage. However, Operating System upgrade may result in sluggish performance. Drivers dont seem to be an issue to me either.
I suggest to review a few points detailed as under: -
- K8V-MX Asus Supports RAID, so, check for any RAID Drivers/ settings. (You dont have to use RAID for two Hard Drives of different make, capacity and speed). Try using one disk at a time having same Operating System (e.g. Windows XP) and compare the performance.
- Infact SATA Drives have better data transfer rate than IDE, which results in enhanced performance.
- Some Programs (that you may not be using with 80GB drive) Like antivirus may result in decreased performance.
- Please Review you Operating System environment and software installed. Make sure that the new drive & Operating System are free of any virus, which results in CPU Utilization upto 100%.
- Also, motherboard supports Max 2GB RAM, so you may consider adding more RAM.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
Jan 27, 2011 | ASUS K8V-MX Motherboard
Can you let me know what is the maximum installable HDD capacity 0f Lenovo laptop 3000 C100.Can i upgrade present capcity of 40GB to 320GB ?
If you have windows xp with service pack 3, there is no limit. There is no limit if you run Vistaor Windows 7. If you don't have service pack 3, you are limited to 137 gb.
Dec 20, 2009 | Lenovo 3000 C100 Notebook
Insatlling 2nd HDD
The drive is bad, I had a similar problem with a WD HDD, You can download Seatools and work on it in DOS, http://www.seagate.com/www/en-us/support/downloads/seatools
Apr 29, 2009 | ASUS P4S533-MX Motherboard
Upgrading my computer
Dear Fried its possible.. Go the Boot Menu at your BIOS ( For go the BIOS Press DEL at startup your system) there you may se Hard Disk Priority Option. There you can change Hard disk Priority... you may need setup your sata as first one..
Thanks...
Mar 26, 2009 | ASUS K8V SE DELUXE,...
Hard disk problem
you may try formating into a linux partion first using partion magic and then to any of the windows partition
Jan 18, 2009 | Seagate 40GB EE25 5400.2 Ruggedized PATA...
PATA SATA PROBLEM
This motherboard does support SATA. Check out the specs on the ASUS website:)
http://www.asus.com/products.aspx?l1=3&l2=14&l3=225&model=754&modelmenu=1
Dec 30, 2008 | ASUS K8V-MX Motherboard
How to detect two IDE drives with same brand
You need to set one of the drives to be 'master' and the other to be 'slave'.
This is done by positioning jumpers on the back of the harddrives.
Pretty sure that on the drives is explained somewhere how to position the jumper, for several options.
Good luck,
Please post some feedback.
Apr 23, 2008 | Dell OptiPlex GX280 PC Desktop
ASUS P4PE/L (ASU49J) Motherboard Logo
124 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
