Question about Compaq Audio card Sound Card
Compaq Presario R3000 Sound card problem - I tap on PC to fix
I have a Compaq Presario R3000 laptop.  The sound and microphone will stop working at times.  I found that if I tap the lower right side of the laptop (where the controls and microphone jack is), I can get it working again.
Question:  Is this a part that can be easily replaced or is it built into the motherboard?  Appreciate any help.
    Genius:
  • 2,920 Answers
It can be replaced you just have to have the patience to do it
Posted on Dec 28, 2008
External microphone jack on my presario r3000 not working?
Try a different microphone if this fails look at the properties of your sound device in the control panel and set it for default recorder.
Jun 19, 2014 | Compaq Presario 700 470024-192 Notebook
I have install window xp professional sp2 in notebook compaq presario v3424TU. i have installed the sound drivers but the sound still not coming. thell me the way follow to
Hey mate,
You should look for an external audio card maybe some of the capacitators and transistors in your built in sound device have ceased.
Check the web for external sound card for your notebook.
You have a great night.
Do advise on the results.
Joe
Mar 12, 2010 | Compaq Presario R3000 Notebook
Compaq laptop
Hi
The sound card drivers are most likely missing / not installed.
You can download them from the HP/compaq website
http://h10025.www1.hp.com/ewfrf/wc/prodTopCategory?product=384510&lc=en&dlc=&cc=us
Jul 08, 2009 | Compaq Presario R3000 Notebook
Sound card
Probably the contact between the soundboard and the mainboard; see here
Jan 08, 2009 | Compaq Presario R3000 Notebook
Compaq Presario R3000 Sound card follow-up question
The sound board is connected to the mainboard by a connector and contra-connector, both soldered to their boards.. If you want to do it right, you will have to remove several screws from that bottom corner and left side, under the battery too, so that you can lift up the mainboard's corner (gently!) a bit, and put in back in place firmly. It is located just above the top left side of the battery compartment, when looking at the bottom with the front toward you. A more durable option is to take the bugger apart, and put washers max. 1mm thick under the soundboard to get a better snap-in on those connectors.
Jan 03, 2009 | Compaq Presario R3000 Notebook
Compaq Presario R3000 dim screen but not dark
Sounds like the auto-dim in the BIOS is set too low. Fortunately the Compaq R3000 allows you to adjust the brightness right from the keyboard. Hold down the [FN] function key while tapping the [F8] key will brighten the screen, while [FN]-[F7] will dim it. The settings are different for running on AC power and battery, so you must do each individually.
Dec 31, 2008 | Compaq Presario 700 470024-192 Notebook
External microphone not working
Check first if your sound card is working properly.
My Computer >> Right click...Properties >> hardware >> Device manager >> Sound
Then go to Start >> Control Panel >> Sound and Audio Devices .........hit ADVANCED
one dialog appears MASTER VOLUME >> Go to OPTIONS >> Then PROPERTIES..........
CHECK the MICROPHONE...........Hit OK.............
This will be fixing your problem (if your sound card is working well)
Oct 30, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
289 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
