Question about Sub-Zero 695/O Side by Side Refrigerator
My icemaker comes unloose
Well, I know how to fix this problem but only temporarily. My ice maker makes the ice, but when I try to get some ice out using the button, it does not come out, to fix this I usually take the ice bin out, empty all the ice out into a bag, and unscrew the 4 screws holding in the cover. Once I have done that I see that the revolving metal rod is misplaced, I put it back in place and screw it all back up together and the ice maker works, but for some reason it continually does that about once a week. It really gets irrigating to do that every week. If anyone knows how to do this please help out? Thanks :)
  • 334 Answers
Sounds like the scew or the screw hole in the revolving rod is stripped allowing it to come loose.
If either is stripped, replace it. It may be a good idea to replace both, because if onwe is stripped, the threads of the other are probably not to great either.
Posted on Dec 28, 2008
Whirlpool Ice maker broken
First review this YouTube video about how to fix a current Whirlpool ice maker that does not make ice. Most are fixable. (The maker of the video, Repair Clinic, will work with you to find the exact part needed and sell you that part. Excellent company to work with.
Whirlpool Freezer Won Make Ice Ice Maker Assembly W10190965
You can determine which ice maker you need by checking at the Whirlpool website on icemakers.
Whirlpool Refrigerator Ice Makers Replacement Parts Accessories PartSelect
If you have determined that you cannot fix your existing icemaker, try checking Amazon for a replacement.
Amazon com whirlpool ice maker replacement
Feb 09, 2018 | Whirlpool Refrigerators
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    Jfd2589kes
    Locate and check the valve that feeds water to the icemaker.
    Jul 04, 2017 | Refrigerators
    Water to icemaker overflowing; won't stop
    you have a defective fill valve controller and only a repair service can fix it properly .
    Feb 28, 2018 | Kenmore 21.7 cu. ft. Top Mount...
    Water started pouring out of the icemaker and out the dispenser. When we opened the freezer door water poured out of the icemaker and down the whole freezer. Opened icemaker flap and water stopped. Turned...
    Cindy, it’s either the water inlet valve that fills your ice maker or the ice maker itself that is bad. The ice maker itself controls the valve. It should come on for about 7 seconds to fill the tray. The valves do fail but not as often as ice makers fail. Its also possible that the fill tube to the ice maker is blocked with frozen water but since it made one tray that is unlikely. If you know someone that knows how to test the valve it would eliminate the decision of replacing the ice maker or the valve. Otherwise I would recommend changing the ice maker first. Hope this helps.
    Feb 11, 2018 | KitchenAid Superba KSRG25FK Side by Side...
    Ice maker not making ice
    If you have a whirlpool ice-maker, have you tried making sure the white spin wheel is making contact with the icemaker? It comonly comes loose and results in a loss of power. if you press it in with your fingers, you may see the wheel start spining again, and the ice production process will begin.
    let me know if this helps.
    Mar 30, 2009 | Refrigerators
    ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
    I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
    Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
    Icemaker
    Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
    Let me know if this helps.
    Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
    Ice maker doesn't make enough ice
    Try turning the thermostat all the way down if it works you can back it down.
    Nov 21, 2008 | GE Profile PFS22 33" Artica French Door...
    Sub-Zero 695/O Side by Side Refrigerator Logo
    77 people viewed this question
    Top Sub-Zero Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    Sal De
    John Tripp
    John Tripp
    Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
