Question about HP Photosmart 435 Digital Camera
Unsupported card error
I have an hp photosmart 435 camera. I am using the original SD card that came with the camera. Now I'm getting an unsupported card error on the lcd. My mother in law took it to Walgreens and they put another card in and it still said the same. Is there anything I can do to correct this problem?
Thanks!
  • 8 more comments
  • morganmaddie Nov 07, 2007
    Same unsupported card error
  • alnotary Dec 19, 2007
    I have the same problem with my HP Photosmart M517. Is this a common error with these cameras.
  • Anonymous Mar 02, 2008
    Gone through 3 new memory cards. Still get Unsupported Card on LCD...WHAT A CROCK OF A CAMERA!
  • Anonymous Mar 23, 2008
    i have i card that is locked can i unlock it
  • bobby03 Jul 18, 2008
    same problem, HP should resolve this. removed card to take pictures off, then put the card back in and it reads "unsupported card"
  • Anonymous Aug 28, 2008
    i the
    I last used the camera about 4 weeks ago and it was fine. I have just turned it on to use again and I am getting an 'unsupported card' message on the screen. It is the same card I have used for recent wedding photographs which I have put onto my computer and there is ample room on the card which is a Fujifilm 128 MB card. There are images on the card which I do not want to lose (10 images). What can I do?
  • Anonymous Dec 03, 2008
    UNSUPPORTED CARD ERROR . TRIED 3 CARDS AND THEY ALL DO THE SAME.
  • Anonymous Jan 24, 2009
    sd card not working
  • Carl Peterson
    Carl Peterson May 30, 2013
    same problem useing my HP photosmart 812 camera
    Novelist:
  • 198 Answers
Hello, This may be related with the sd card reader in the camera. It's pins doesn't make a perfect contact with the ones on the sd card. In order for your camera to recognise the card only 4 pins can be connected. However in this case the camera will give you this error because it can't acces the card (send information to it or receive) because of the missing pins. It will only recognise it as a card. The camera must be dissasembled and the card slot needs to be checked out for 2 things. One is that it makes perfect contact when a card is inserted, the other is that it gives you the right voltage to the card in order to power up correctly. When it will be checked with a voltmeter it will need to show up some 3.8 - 5.8 volts on some pins (i guess pin 3 and pin 7). These check need to be done in a service center, because dissasembling the camera yourself can result in other problems most often damaging the lens unit wich is a very delicate mechanism. Good luck and please reply if you need more info.
Posted on Apr 25, 2007
HP 812 any SD card I use all say unsupported card?
Make sure you're using an SD card, 2GB or smaller. The 435 will not work with higher-capacity SDHC cards.
May 30, 2013 | SanDisk San Disk 4gb Micro Sd Hc Microsd...
Hp photosmart 435 size of sd card
SD cards top out at 2GB, and any of them may be used with the camera. Any larger cards are SDHC cards and will not work.
Aug 22, 2012 | HP Cameras
Sd card for hp 435
128mb. You probably have to order online.
Aug 22, 2012 | HP Photosmart 435 Digital Camera
I want to transfer pictures from my hp 435 camera to memory card,, how?
Connected the camera with the USB cable at pc, open Explorer pc program to view like a "external device", select your files and copy/paste en each folder. Other way could be using some external device to your SD Card.
Additionally, its possible that find other details in this link for HP PHOTOSMART 435 MANUAL User Guide for HP 433 / 435 / 435v / 435xi
Keep us updated.
Sep 29, 2011 | HP Photosmart 435 Digital Camera
I bought a 4gb memory (Sony) card. I t shows unsupported when turned on , is it compatable?
The M415 works with SD cards. Your 4GB card is actually an SDHC card and won't work with the camera. You need to use SD cards, 2GB and smaller.
Aug 25, 2011 | HP Photosmart M415 Digital Camera
I am trying to put a Lexar 4GB card into my HP Photosmart M517 but get "Unsupported Card" each time. What can I do?
The M517 is designed to work with SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they will not work. You need to use SD cards 2GB and smaller.
Aug 04, 2010 | HP Photosmart M415 Digital Camera
My hp photosmart r707 keeps saying the card is unreadable, buti just used it yesterday. i cant reset it either. it wont let me and the computer wont read it
Sounds like you're connecting things like your camera or your card in a card reader and just yanking them out of your computer without using the "safely remove hardware" icon at the bottom right of your computer screen.
Feb 06, 2010 | HP Photosmart R707 Digital Camera
When SD card inserted into camera it says unsupported card.
I looked on the manual ...and doesn't say anithing about cards..except that it has to be an SD...maybe there is something wrong with the camera ..or is not a secure digital ...and is a multimedia ...or the other way around...
try to see if its not locked...and reformat it on the computer ..if the camera don't have the feature to format it ......maybe its too small ...or too little ...or damaged...
Jul 18, 2009 | HP Photosmart 435 Digital Camera
I bought a SanDisk card and when I put it in my camera it says unsupported card. I don't have cables to hook up to my computer. Will a SD card let me, if I can get one to work, transfer my photos onto the...
You might be having trouble with your sd card in the camera because it is too big. Some camera's will only use a certain size card or up to a certain size card. Check your manual for restrictions on the size of SD cards that the camera can use. Also you can buy a sd card reader for about $20 at most stores that sell cameras. Put the card in the reader and then hook it to your computer. You can then transfer the pictures to the computer or to another sd card. Hope this helps.
Jul 11, 2009 | HP Photosmart 435 Digital Camera
SD Memory Card
Simple really you need to buy a new memory card that is compatible with your HP photosmart. The card you have is probably designed for toshiba products specifically.
Jan 29, 2008 | Electronics - Others
HP Photosmart 435 Digital Camera Logo
721 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
