Question about Motorola Mobility RAZR V3
My cellphone screen looks like its been water damaged
One my phone sometimes out of no where the screen will have blue stripes on it even if i dont do anything to it what is wrong with it
    Brigadier General:
  • 7,752 Answers
Take the phone to a mobile service center and have them replaced the LCD for you.
Posted on Dec 28, 2008
IPhone screen gone greenish tinged? Everything still works, including touchscreen, just has this weird green glow and sometimes vertical stripes?? Please help!
Have you dropped the Iphone or has it been exposed to water damage?
It looks like a actually LCD damage and not a software failure I would recommend you contact Apple.
Here you can find the number to call http://support.apple.com/kb/HE57
Jan 07, 2013 | Cell Phones
N97 blank screen
See this tips and fix it. God bless you
  • The simplest of all the cellphone screen issues to correct is a minor software glitch. These glitches can come out of nowhere and do many strange things to your device. To correct the problem, simply remove the cellphone's battery, wait a few seconds, and then put the battery back in. Power up the device to see if the quick reset corrected the screen issue. Additionally, some devices also have a hard reset that you can do without needing to see the screen. If your device has this kind of hard reset function, and you don't mind losing all of the information in the cellphone, a hard reset can sometimes correct issues that a soft reset will not.
Hardware Failure
  • The most common reason for a cellphone's screen to go black is a simple hardware failure. This can be caused by the actual LCD going bad, by the cable that runs between the LCD and control board going bad, or even just from the cable's connectors coming loose. To fix these problems you need to open up the cell phone and replace or reseat the defective part. The exact process and tools for taking your device apart will vary wildly by model, but most just require a small screwdriver and a simple pry tool. Once the device is open, inspect the LCD and cable for damage; if none is found, simply replace both parts.
Liquid Damage
  • When water comes into contact with an electrified board, the impurities in the water can allow current to flow in directions that it was not intended to, causing a short circuit. Even if your control board isn't damaged by a short circuit, the corrosion caused by the water can impede the flow of electricity and cause certain areas of the cellphone to no longer function. If you find green or brown areas of water damage on the circuitry, cleaning it off can sometimes get your device working again. Use 98 percent isopropyl alcohol and a soft brush to remove the corrosion, then put the device back together to see if anything changed.
Other Recourses
  • If your cellphone is still under warranty, then your best option may be to take it back into the store where you purchased it. Some stores have qualified technicians available to repair your device, while others will simply replace it with another phone. Either way, your cellphone should be working again. Note, however, that this is not an option if you have opened your device to try and repair the screen or if your cellphone has water damage, as these both will void the warranty.
    Instead of a warranty repair or replacement, if you have purchased insurance on your cellphone you can also choose to contact the insurance company. You'll have to pay a deductible, but the insurance company won't care if you have opened or damaged your device.
Oct 15, 2012 | Nokia N97 Cell Phone
My nokia 6300 is water damage. blue lights are blink only and pw ic is heat up....what can i do sir
your cellphone short circuited. that means that your board is damaged when water goes in. ICs tend to short circuit and that could be damaging to your phone. i advise you to have that fixed at a nokia center. and i hope that they can have that fixed.
Nov 02, 2010 | Nokia 6300 Cellular Phone
One day as i was getting ready for work i realized that my phone was turned off ... i may of accidentally turn it off , i would do this some time so not strange to see. but when i turned it back on the...
You will have to get a firmware update. I have fixed alot of these issues. You can try to do it online through htc.com or take it to a local repair shop. If no one can assist you you can try 303.482.1288 wireless image. Make sure you dont have water damage on the phone by checking the water mark on the back of the phone there is a white sticker indicator if it is red then it has water damage. hope this helps
Oct 25, 2010 | HTC TyTN II Smartphone
Hi, I have a Vizio P42. Worked fine for 5 years. Today is has a vertical blue stripe 1.25" wide, 4" from left side of screen. Blue stripe remains even if all inpust cables are removed. Problem is...
it's burning out. that's a sign of tv failing. there is no repair for that if you used it for 5 years, i doubt you would have warranty for that by now, best option is to replace it.
Oct 17, 2009 | Televison & Video
My nokia 7610 phone has been dropped in water
You should detached quickly its battery first. It is to prevent further damage to your unit. And dont try to power it on. Then bring your unit to a cellphone shop to have it dry and clean it for you, they will sometime automatically charge for water damage repair.
For minor damage only battery pack will get damaged. Luckily only cleaning and drying will get it running.
Apr 17, 2009 | Nokia 7610
Somehow got wet but i comes on
it depends....but take it to a mobile service center and have them check n service the phone to see if it is worth fixing or for you to just buy a new one.
Jul 05, 2008 | Motorola Mobility RAZR V3
Motor Razy 3xx cellphone
yup...
its common prob for razr. if you can open your fon, check its flex coonector inside mayb it get loose thats why you dont have any display, if everything is fine... probably you have a defective flex connector or defective LCD...
Oct 26, 2007 | Motorola Mobility RAZR V3
I dropped my cellphone in water....
bake it in the over for 1 hour @ 75 deg C.
Sep 08, 2006 | Sony Ericsson K750
Motorola Mobility RAZR V3 Logo
22 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
