Question about Hawking Computers & Internet
Hawking wireless router (HWRN1A300N) will not connect ot internet
When I went to the command prompt and typed "ipconfig" I got the IP Address and there was also a message that said "unable to contact your DHCP server". I use Comcast as the ISP. I can get to the internet by connecting directly to the Comcast Modem via ethernet.
    President:
  • 623 Answers
First of all - your ISP has nothing to to with DHCP. DHCP is handled internally by your router (or DHCP server).
If you did not configure your router otherwise, it should hand out an IP address automatically.
If you ipconfig shows that you have an IP address, then I assume that this address is manually configured.
You should set everything to automatic until you know it works.
So...
Go to your start menu -> Control panel -> Network connections.
Right-click on "Network Connections" and choose "open".
Look for your "Local Area Connection", if you are wired into the router, or something like "Wireless Network Connection" if you're using wireless.
Right-click "Local Area Connection" and choose "Properties".
Double-click "Internet Protocol (TCP/IP) and see that both "Obtain an IP address automatically" AND "Obtain DNS server address automatically" are selected.
Click "OK" twice and make sure that all property windows are closed.
Go to the command prompt and re-do "ipconfig /all" (No quotation marks of course).
Check the line that says DHCP server, it should be the same IP as your Default Gateway (your router).
If this does not work for you, copy the result form that command here and I have another look.
If it works, please come back and leave a comment. This might help others with the same problem.
Posted on Dec 28, 2008
Connect motorola modemsbSB6121 to Belink N600 wireless router with out losing internet signal
Step one turn on PC directly connected to ModemsbSB6121 without Wi FI router being involved.
Step two go to Command prompt type in ipconfig (press enter)
Step three note IP address of default gateway and ip address issued to P.C.
Step four type in default gateway address into browser and log into Modem.
Step five look for DHCP Server and allocate IP addresses from at least 50 for example 192.168.0.50 starting ip lease ending ip lease 192.168.0.254
Step six connect Wi Router to P.C. via ethernet cable only - remove ModemSB6121
Step Seven shutdown and restart p.c
Step Eight go to Command prompt type in ipconfig (press enter)
Step Nine note IP address of default gateway and ip address issued to P.C.
Step Ten type in default gateway address into browser and log into Wi Fi Router
Step Eleven Change IP address on Router to 2 as example 192.168.0.2. (it has to match in that modem device would have been 192,168.0.1)
(if it was 10.0.0.1 make wi fi 10.0.0.2 make sure subnet mask is the same like 255.255.255.0)
Step twelve Change DHCP Server to off
Step Thirteen may need to set default gateway to MODEM IP address for example 192.168.0.1
Step Fourteen plug modem router into Wi Fi router may need to plug into WAN port on WI FI router .
Step Fifteen shutdown and Restart Computer
Step Sixteen go to Command prompt type in ipconfig (press enter)
Step Seventeen type in PING 192.168.0.1 (if this is modem IP address and default gateway IP addess)
All this above is to avoid IP address conflicts or mismatching
Subnet mask should be 255.255.255.0
either it uses 192.168.0.1 or it uses 10.0.0.1 make sure Wi FI router is set to different address to Modem Router.
I suspect either a clash occurs or your P.C gets a different IP range from ther WI FI DHCP server.
Happy troubleshooting !
Sep 16, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
Whte is my ip addres
Open a command line (e.g. run CMD to get a 'dos' prompt) and execute:
IPCONFIG
The line with IPv4 will have your IP address
Sep 20, 2011 | Linksys Wireless-G Broadband Router
How do I reset an outconfiguration IPv4 Address back to a normal 192 ip instead of a 169 ip
Make sure you are completely connected to the wireless network.
Open an command prompt Type CMD in the run box on the start menu
In the command prompt window type IPCONFIG /release
Next type IPCONFIG /renew
Aug 23, 2011 | Hawking HWREN1 Pre-802.11n Wireless...
Can you tell me the default IP address for this unit as I have lost the pass word and need to reset the unit
If your computer is plugged into the router, you can easily get the router's IP address by going to your command prompt and typing "ipconfig" without the quotes.
Command Prompt is under Start (or Orb if using Win7 or Vista) > All Programs > Accessories
After typing "Ipconfig" and hitting return, command prompt should display something like this:
Windows IP Configuration
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . : blah.blah.comcast.net.
IP Address. . . . . . . . . . . . : 192.168.0.196
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Ethernet adapter PdaNet Broadband Connection:
The router's address is your "Default Gateway." You should be able to put that address into an Internet Explorer window and it will bring up the configuration interface.
If you find this helpful, please rate me -- trying to get my "Wiz" rating so that I can provide Premium service.
Thanks,
Chris
Jul 27, 2011 | 2wire 2700HG-B Router (2700HGB)
Intermittently, my home network and internet access ceases to function. Troubleshooting indicates the "Local Area Connection" doesn't have a valid IP connection. Resetting the router (12...
Going inot the router configuration page and reserving your computer with a specific IP address would resolve this issue, If you have never gone into the router config page, it would be reccomended that you not do this, and have a computer savvy person with networking experiance do this for you.
another solution would be releasing and renewing your IP address in the command prompt on your computer
in command prompt, type : ipconfig /release ENTER then ipconfig /renew to renew your ip address, this can be done rather than resetting the router everytime
Jul 02, 2011 | D-Link DIR-615 Wireless Router
My wireless internet stopped working. i have model #wrt54g v8. i have cable internet also. when the wireless stopped working cable company checked said everything on there part is fine. its pluged in. the...
When you plug in the ethernet cable the corresponding numbered indicator on the router should flash to indicate a LAN connection and some data flow from the router to the computer. This does not necessarily mean that there is data flow from the internet to your computer via the router. Simple check would be to use a smartphone and try and connect to WiFi on the router but restart the router first. If the smartphone is also having problems then the problem may be with your internet provider or the router. If the smartphone connects then restart the computer. If the computer still does not connect then try the following steps to refresh the computers IP address:
For Windows XP
Step 1
Click Start->Run, type cmd and press Enter.
Step 2
Type ipconfig /release at the prompt window, press Enter, it will release the current IP configuration.
Step 3
Type ipconfig /renew at the prompt window, press Enter, wait for a while, the DHCP server will assign a new IP address for your computer.
For Windows Vista& Windows 7
Step 1
Click Start on the task bar, type cmd into the search box and press Enter.
Step 2
Step 3
Type ipconfig /renew at the prompt window, wait for a while, the DHCP server will assign a new IP address for your computer.
For Windows 8 & Windows 8.1&10
Step 1
Press windows key and X key at the same time. Then click at Command Prompt.
Step 2
Type ipconfig /release at the Command Prompt window, press Enter, it will release the current IP configuration.
Step 3
Type ipconfig /renew at the Command Prompt window, wait for a while, the DHCP server will assign a new IP address for your computer.
Hope that helps.
https://fastproactiveit.com/
Proactive IT Support PC Repairs Laptop Repairs Custom Built PC Leading IT...
Sep 22, 2017 | Linksys WRT54G Wireless Router
My router shows up in my available networks menu but when i try to connect to it it says that windows cannot connect to the network. this is happening on two of my laptops
First thing you can do is a ipconfig /release /renew
to do that, go to:
Start>All Programs>Accessories>Command Prompt.
Once thats open, type in ipconfig /release
note, there should be a space between ipconfig and /release and renew
your ip address should come up with 0.0.0.0
Now type in ipconfig /renew
remember a space between ipconfig and /renew
You should see an ip address of 192.168.XXX.XXX or 10.10.XXX.XXX something like that, depending on your network settings.
if you do, you should be able to get on the internet.
If you see an address of 169.254.XXX.XXX
Then it would be best if you powered off the Modem and the Router.
First turn off the Router, Next the Modem.
Power back on in reverse order and see if it is able to connect then.
If all that fails, You can reset the router and see if it will connect then.
You should have a reset button on the back of the router.
Remember once the router is reset, you'll have to redo the security settings.
Hope this helps!
Dec 17, 2010 | Hawking (H2WR54G) Wireless Router
Wireless-G WRT54G Router: how can i fine my ip address...
To check for the local ip address of your computer:
Go to Start -> run. Type cmd. In the command prompt, type ipconfig.
To check the Internet IP address of your computer:
Go to an internet browser, in the address bar type whatismyip.com.
I hope this helps!
May 15, 2010 | Linksys Wireless-G WRT54G Router
Cannot connect although plugged in
Check the ipaddress. Type ipconfig in command prompt. Then ping a website in command prompt if u get proper ip address e.g 10.132.147.121. Try to ping www.google.com in command prompt. If u are unable to connect. Tried to release renew Ip address.
Type ipconfig /release then ipconfig /renew in command prompt. If you are able to ping google and still unable to connect to website using internet explorer, then issue with browser or with OS.
Aug 17, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
THinkpad T41 with DWL-610 does not detect Network from D-Link 614+
This article will tell you how to refresh your IP address on a network. This will only repair internet connection problems if you've changed locations and you can't connect to the Internet. This is only for Windows machines.
  1. Open the Command Prompt (from the Start button, go to Programs > Accessories > Command Prompt).
  2. In the command prompt window, type ipconfig /release
  3. In the command prompt window, type ipconfig /renew
  4. Exit the Command Prompt by typing exit
Sep 20, 2008 | D-Link AirPlus DI-614+ Wireless Router
Open Questions:
Computers & Internet Logo
432 people viewed this question
Top Hawking Computers & Internet Experts
Marvin
Marvin
Steve
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
