Question about Astar LTV-3201 32 in. LCD Television
Invalid Input-turning off seeting
32 inch astar 1080i lcd keeps having invalid input pop up which then leads to the tv switching to standard mode (channel 8 for example). Then I have the hd button to go back to whatever channel I was watching at the time. This problem occurs every 5-20mins and is also accompanied by the volume bar popping up right before the problem occurs.
  • 1 more comment
  • catjuice666 Jan 18, 2009
    i have the same problem and even covering the ir sensor did not help
  • Anonymous Jan 23, 2009
    It's not the remote, since it does it whether the remote's around or not. It acts like there's a bug in the TV that's playing with the buttons on the front.
    I did notice the remote seems to be working badly from far away but perfectly right in front of the TV, but I don't have florescent lights in this room, and I've had florescent lights in the other rooms of the house for a lot longer than this issue has been going on. We recently replaced a couple bulbs in a couple rooms near this one in the house, but as I said, this was a couple weeks ago and this issue just happened.
    What I think may be the problem is that my iso bar turns off (middle, between on and off, like it got a surge) sometime during the night while I sleep, so that when I wake up I have to turn it back on. The first morning this happened, my electric shaver turned off too. The last couple times it hasn't, it's just been the TV that is unresponsive.
  • louisemartin Mar 04, 2009
    This is really drriving me nuts what do I do about this please I tryed black tape on it and it still does it.
I have the same problem in the office, but, not at home. I believe the IR sensor is confused by office florescent lighting, which has an unperseptible 60-cycle flicker not charactoristic of home incandescent lighting. Energy saving compact florescent probably have the same effect.
I have attached a dark tube over the sensor with relative success. This cluge is an unfortunate compensation for poor engineering because of the reduced angle of reception (the remote has to be directly in front of the sensor).
Posted on Jan 08, 2009
I have a bunker hill item 62463 dvr security system and all i get on my T.V is invalid Format it will do nothing else
You need to use the TV remote, and change the input to video, or DVR ...or something. Run through the various input channels, and you will find it. Invalid format is like if my TV is set to RGB/PC input, but the screen has timed out and is in sleep mode (no display) ...it puts invalid format on the screen. Or if you go to straight TV instead the channel that's connected to the box, same thing. You have to have the right input selected. You usually need the remote for it.
Dec 02, 2017 | Computers & Internet
My TV was FINE for months after I purchased it. Making zero changes to the HD cable box which was always set on 1080i. All of a sudden I get this Invalid format error out of nowhere. Don't tell me
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 22, 2012 | LG 32LG30 32 in. LCD HDTV
My lg tv has invalid format floating on it ...what should i do
It sounds as if the output resolution of your cable box is too high for the TV to accept.
If you are using HDMI, you might need to change the output of your cable box to a lower resolution (ie 1080p down to 720p)
To do this, connect a standard composite cable from your cable box to another input on the TV. Switch your TV over to that input and go through the display settings on your cable box. Lower the resolution, and then swap back over to your other cable.
I hope this helps!
May 06, 2011 | LG 32LG30 32 in. LCD HDTV
Invalid format floating on screen on LG 32" how to resolve????
If you are using HDMI, the source resolution could be too high. Your TV is only 720p so if your equipment is set for 1080p, it will not display. Connect the composite (yellow) video lead to the TV and change to that input. Use the equipment's menu function and verify the resolution. Make sure it is set for 720p. Also try a different HDMI cable, yours may have a bad lead inside.
Apr 19, 2011 | LG 32LG30 32 in. LCD HDTV
Tv will turn on(green on light showing) but no picture. was giving us problem for 1 day with 'invalid input' flashing then blue screen all connections are tight.
Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope it help
Jun 01, 2010 | Astar LTV-40HBG 40 in. LCD HDTV
Invalid format
If you get that across all inputs or channels then your digital board is bad. If you get it only on one input such as HD cable box, HD satelitte receiver or Blu_Ray player then they are set for the wrong output on that connector. The TV most likely will only accept up to 720p or 1080i....
May 19, 2010 | Olevia LT32HVE 32 in. LCD Television
"invalid input" for hdmi
This model TV has specs for DVI, VGA, component video and S-video inputs. Are you using a DVI-HDMI cable? In that case, check your cable specs. DVI-I and DVI-D (single link and dual link) are not interchangeable and I would guess you have the wrong one connected to the HDMI for your unit.
I hope this helps.
Apr 12, 2010 | Olevia LT32HVM 32 in. LCD Television
My Astar LCD TV is possessed!
My nephew had exact same problem, I fixed it by changing 8 puffed up capacitors in the power supply. They went out of business because they copied philips tv design and were sued by them.. The model was ltv-2601(canadian model) but all including ltv-2701, used cheap capacitors. Has been good for 4 months now.
Mar 20, 2009 | Astar LTV-2701 27 in. HD-Ready LCD...
32 in Astar LCD won't recognize input signal
Hello, According what you saying not recognize any iput. Then your main board is defective.
The HDMI and the YPbPr are the same connection according the main board build. Any other question please call 323-767-6030.
Jan 08, 2009 | Astar LTV-3201 32 in. LCD Television
Hd tv doesn't work at all says invalid format
is the tv 720 or 1080. it wont work if your inputing 1080p to 720p or 1080i
Dec 11, 2008 | LG 50PC1DR 50 in. Plasma HDTV
Astar LTV-3201 32 in. LCD Television Logo
196 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
