Question about Acer Aspire 5610-4648 Notebook
What drivers do I need to download to turn my hot keys back on
I need to download driver or drivers for hot keys to be able to turn them back on the volume buttons on the way right and the small silver key in the middle of the touch pad dont work
Gateway windows 8 ne71b series lapton wifi is off
Try re-installing the wireless driver.
You can download the device drivers for your model Gateway laptop from this WEB site. Make sure you select your model laptop and the correct Windows drivers. Click on this link to download the drivers: -
http://driver-pro.com/related/english/hardware-drivers/?a=12221&gclid=COmm19XHtpwCFSMSagodPRuwnQ&hit=1
Jan 27, 2013 | HP Elitebook 2570p B8s43aw 12.5" Led...
My laptop Sony Vaio model is PCG-3C2L, i have any questions below: where can i find to download driver for the "Fn" key ? because i cannot use this key with the F1, F2, etc. i.e Fn +...
Hi There,
I think the one you need to install is the Utilities Driver like Hot key Utilities Etc.
I Found the driver that might fix your problem
Click this Link: http://esupport.sony.com/perl/swu-list.pl?mdl=VGNFJ270B#div_pos_66
Look for:
Original - Sony® Notebook Utilities and Control Device Driver - Its under Netbook Control and Utilities
Hope this helps :)
May 19, 2011 | Sony VAIO VGN-FJ270/B Notebook
The laptops hot keys at the top wont work and we cant get online with it
This is a driver issue, those hot keys on the top are recognized by your computer through drivers.
First try restarting your computer. This usually resets your drivers to normal again and might work if it was somehow disabled.
Secondly, try downloading the first driver here http://driverscollection.com/?H=Satellite%20A665-S6085&By=Toshiba This should reinstall the drivers to make those hotkeys work again.
Hope this helps, Best of luck!
Apr 11, 2011 | Toshiba Satellite A665-S6085 Laptop
I can't turn the wireless on with the FN/F8 key
You need to be more specific when you post a question: eg. laptop/pc model and Operating system.
Hot Keys including Wireless on/off are specific to a Laptop and are 'programmed' to function: re-installed the Hot (or Smart) keys driver that came with the laptop. If you don't have the installation drivers CD/DVD, you can always download it FREE from the manufacturer site.
Hope it helps and let me know if this information is useful.
Oct 03, 2010 | Computers & Internet
Cannot turn on wireless lan with fn+f2 keys
1. first turn on the "wi-fi/wireless" switch on ur laptop manually.
2. now use the key combination for wi-fi/wireless
3. if it still not working, reinstall the wi-fi/wireless driver again, and restart ur system
Jan 01, 2010 | ASUS F6A-X2 PC Notebook
Lost keys have hot wired it wont start but does turn over wants to go what do i do
Take your title to the dealer, they should be able to make you a key, also do you hot wire hot to ACC/ON hit Start, then release back to on when it turns over? It may not run if you have anti-theft.
Dec 13, 2009 | 1990 Audi 100
Wireless wont work on acer aspire 6530g
Make sure the switch is on , or the hot key is pressed to turn on the wireless.
Look on the Acer website and download that driver again and try.
Oct 16, 2009 | Acer Aspire 6530-5143 Notebook PC
Christie DS+60 projector turns off spontaneously
Here is a list of error codes for your unit:
12 Software bug. Contact dealer/factory.
13 Flash memory corrupted. Download new software.
14 Engineering only programming is complete. Call Christie, replace TIPM.
15 Attempting to download code without being in boot mode
16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory.
17 Forced boot mode. Keys held down too long.
18 Attempting to program boot mode without jumper
LAMP FAILURES
21 Lamp compartment too hot
25 Lamp 1 not installed
26 Lamp 1 Interlock: door open, lamp not installed
27 Unable to turn lamp 1 ON
28 Lamp 1 shut off unexpectedly
29 Lamp 1 driver overheated
2A Lamp 1 driver operation error (e.g. too hot can’t start)
2C Lamp 1 driver UART communications failure
30 Lamp 2 not installed
31 Lamp 2 door open
32 Unable to turn lamp 2 ON (unknown reason)
33 Lamp 2 shut off unexpectedly
34 Lamp 2 driver overheated
35 Lamp 2 driver reports operation error (e.g. too hot can’t start)
36 Lamp 2 driver UART communications failure
37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
Jan 16, 2009 | Christie DS+60 Multimedia Projector
How do you set the driver's seat for multiple drivers?
Make sure red button is in up position
His key:
Insert key
Move seat all the forward, then all the back with key off to clear the memory
move seat to middle
turn key to on
turn key to off
turn key to on.
Move seat to desired position then hold down button 1 until you hear a chime.
Remove key
Her key
repeat procedure for button 2
Oct 10, 2008 | 2004 Volkswagen Jetta
Cant find missin software fro this item
Ok i did some research for your question and here is what i found.
This product does not require any software to make it work. I checked the belkin website and they dont have any drivers or software that you can download for this item. When you check the packaging, this item does not ship with a cd or any drivers. If you need some help installing this item i have the website below, with the user manual to help you get started. Hope this helps. Let me know if you have anymore questions id like to help.
http://web.belkin.com/support/download/download.asp?download=F1DK102P&lang=1&mode=
Jan 30, 2008 | Belkin F1DK102P 2-port KVM Switch
Acer Aspire 5610-4648 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
