Question about Kenmore 22422 Top Load Washer
My kenmore 70 series will put water in the machine and stop.
My son had put a load of clothes in the washer machine, the washer machine filled up with water and did nothing else after that. Will not go through any other cycles.
  • 1 more comment
  • Anonymous Dec 28, 2008
    I put a load of clothes in the washer machine, the washer machine filled up with water and did nothing else after that.
  • Anonymous Dec 29, 2008
    It seems the lid switch is not working. I just had to replace mine. The machine won't finish the cycle if it thinks the lid is up. The lid switch may still work, it may have just broken off from where it is attached to the lid. Good luck.
  • jesusfreak48 Jan 12, 2009
    yeah, its kinda irritating when you have a load in there and all you can do is look at it soaking in a tub of water!! i just need to finish my laundry!!
    Problem Solver:
  • 7 Answers
Sounds like ur pump is bad
Posted on Jan 07, 2009
70 series top loading washer
probably no parts for a machine that old
consider getting a new unit that is more power and water efficient
Jun 25, 2017 | Kenmore 24032\24036 Top Load Washer
I have a top loading kenmore 70 series washer. It
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Sep 13, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Kenmore 70 series filled and stopped...
Lid switch problem. Press down on lid and try to start machine. Reply.
Jun 15, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 Series washing Machine won't stop filling with water
filling and never stops and never agitates? then check level switch and hose, any hole in the clear hose to the level sw can cause this. if airtight then replace level sw.
Apr 27, 2009 | Kenmore 22422 Top Load Washer
Washer keeps filling with water...
you hae a stuck float switch, it shuts water off when it reaches a certain height, fixing it involes removing the top of the washer (not easily done)
Jan 11, 2009 | Kenmore 22422 Top Load Washer
Series 70 Washer Won't stop filling
yes and also make sure fill tube is not clogged or debreed
Jul 05, 2008 | Kenmore 22422 Top Load Washer
Kenmore 70 Series Top Loan - Fill Cycle won't stop when full
Does the water stop when you push the timer in or are you having to shut the spigots off?? If it stops when the timer is pushed in then you have a problem with the pressure switch. There are quite a few tricks to axcessing your machine's components but if you are handy ill attemt to help.
Jan 12, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
150 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
