Question about Refrigerators
Water runs and does not stop
I have a GE fridge.  At first, the water did not dispense when I pressed the lever.  It did once then stopped again.  I looked in the back and the water line is in place and intact.  I took the filter out to see what would happen.  After I put back the filter in, now the water runs and does not stop.  I pressed the button for ice and this did not cause an interruption in the flow of water, but ice did come.  What do you think the problem is?
  • clicks4life Dec 31, 2008
    Thanks for the suggestion. I have not yet implemented it, but it makes a lot of sense. I believe this will solve the problem.
  • 115 Answers
You have a bad water valve replace it and you should be fine
Posted on Dec 29, 2008
The water dispenser on my GE fridge, model bss25jsrss, doesn't work. There is water in the lines, and the lights in the front work, but when I try to get water or ice nothing comes out.
There is a simple switch behind the push lever which activates the water/ice dispenser circuit. Sometimes these switches are poorly engineered to the lever with an adhesive or plastic rod which will break away. This is the first place I would look for a culprit.
Sep 25, 2011 | GE Refrigerators
Fridge will only dispense 6 cups at a time?
Some fridges have a safety feature built in, which turns off water if the water valve was open for a certain number of seconds, to avoid flooding. So if you need a lot of water, make sure to release water dispenser lever for a second or two every minute.
If the above is not the case, you may need to replace the water valve or a switch on the water dispenser.
The way to find out which part needs replacement is to check the voltage on the green water valve coil when the dispenser lever is pressed but it's not dispensing water. If 110v AC is present across the coil - replace valve. If there's no 100v AC - replace switch in the dispenser. Make sure to unplug the fridge before opening the dispenser.
Vlad
First Choice Appliance
Jun 03, 2010 | Whirlpool ED2KVEXVQ (217 cu ft) Side by...
Ge fridge- water dispenser in door wont work yet ice maker does.
There are a few reasons for this. Most common, is the water filter. After a period of time(literage usage) the filter eventually blocks up.Flow will not continue until a new one is installed. On occasion, the water line in the freezer ices up, but doesn't often happen. If so, you will need to defrost freezer until pipe is no longer iced up(set freezer to about -20 degrees celsius).or very possible, water solenoid at the back of the fridge has gone faulty.You will need help with this check,There will be 2 valves. Very possibly it will be the RHS one at the back. Switch water supply off at the back then go to the water solenoids at the back of the fridge.and disconnect the one pipe on the solenoid that leads into the fridge. Open fridge water tap again and ask member to quickly press water dispenser lever.Note if water squirts out for that brief period.. If not, reconnect pipe again then do the same disconnection to the second solenoid. If no water comes out then,(make sure water is open), then the water valve needs to be replaced.
Oct 04, 2009 | GE Refrigerators
GE GSS22JFMC when I press the water button it leaks
That's where the water line runs to get to the dispenser. You may have to remove the cardboard backing to see it. The line runs from the water inlet valve. That's where the supply line from the house connects to the fridge. One line goes up to the ice maker and the other goes over to the fridge side where it goes inside the fridge behind the crisper to a reservoir where the water is chilled before it goes to the dispenser. Look for the water coming out when someone else tries the dispenser. Look for a fitting that has come loose.
Oct 02, 2009 | Refrigerators
GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Nov 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GSS25L GE no water
Check the electrical connector that is next to the water pipe at the bottom of the freezer door
Aug 19, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working
So your not getting water from the dispenser either??? Yes the water filter can be the source of your problem. Let me know if the water is coming from the dispenser.
Nov 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH22JFRE WW not dispensing ice
Deb, sounds like your dispenser control board has given up the ghost. The boards come in 2 models, 4 button and 5 button. The 4 button part # is WR55X10443 (~$87.00)... the 5 button part # is WR55X10437 (~$97.00). Not too difficult to replace. UNPLUG YOUR FRIDGE!!! Remove the drip tray from the dispenser, and any screws hiding in there. Then, using a flat screwdriver and starting at the bottom of the fascia, pry the fascia away from the door and remove. Then remove the screws holding the control in place and disconnect any wiring. (Don't forget to pay close attention to WHERE the wires connect and HOW the wires are routed!) Then install the new board and rebuild. Approx. repair time for your first one is ~1 hour. Good luck!
Sep 24, 2007 | Refrigerators
No water at the door 2
hesshouse ---- thanks for the tip. I only had to leave the light on in the dispenser for less than 5 minutes and the water's running fine now!
Dec 02, 2006 | GE GSL25JFPBS Side by Side Refrigerator
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
